Hey all,
As I said before I’m newer to the truck scene. I wanted to see what mileage everyone is changing things at...here’s what I got so far
tires- every 80k?
suspension - 100k
brakes- 80k
plugs - 125k(I know gm says 160k)
Synthetic Oil every 8-10k
tranny fluid- every 40k
is this typical?
First 3 are usually done based on the wear of the part at the time. Everyone drives differently so those parts will wear differently.
All figures in miles.
Doubt you'll get 80k from your tires. Condition of tires and handling will tell you. Visually inspect them
Brakes you may get more than 80, depending on how you drive. Change when they show the signs. On my 2004, I'm still rocking original at 140k. I know many on here change before 80k. Again visually inspect them
Synthetic oil with a quality filter, generally I'd say people may stick with 5k - 7.5k max. 5k is more my preference. Some prefer 3k
Tranny fluid, I'd say you're spot on. 50k
Don't forget diff fluids.
Plenty of other opinions  will be posted, be patient
Edited by txab
  • Like 3
My maintenance on my trucks were at the high end. Lots of highway miles. Leaving my 14 GMC out I only put 28K before trade in. My mileage usually was 50-60K a year average. Since 91 a new one every two years average. Oil was extended 25k, filter half that. Amsoil. Transmission drained through the lines to the cooler. Amsoil one and done. Same with rears ends. Radiator flushed per manual. Brakes usually 80-100K,some never. All trucks got modified. Some just programmers. Some S/C. All carried stuff, some pulled, gas and diesel. If I was forced to buy new now and drive those miles. I would probably change the oil more often. Unless I bought a Toyota. Non Frankenstein engine. Tires usually BFGs high ply, load rating for my off road use. Quite on highway. Usually last my use with the truck. I has a aggressive but non abusing foot. All had loud exhaust and Amsoil drop in air filters. Or modified induction. I liked the noise until I didn’t. Just recently.
1 hour ago, meirikm said:
Hey all,
tires- every 80k?
suspension - 100k
brakes- 80k
is this typical?
I'm taking this is all in KM no Miles?
Tires will depend on inflation and rotation.  You can go 30k on a set, you can go 60k on a set.
Not sure what you would need to do suspension wise at 100,000km/60,000 miles.  Outer tie rods have grease fittings so do those every oil change.  Ball joints are sealed, replace them when they are going bad.
Brakes, again a wear related replacement situation.  If you never clean the caliper slides and pins out every year, you will get less life out of them.
Transmission fluid.  40,000km/25,000mi is a touch excessive.  GM severe use is every 45,000mi/72,000km on factory Dexron 6 which I believe is a synthetic blend.  Severe use is towing and or extreme climates so if its single digits or colder in the winter and then you still see 80-90 in the summer.
Plugs ever 100,000mi/160,000km.
Oil would be by the OLM percentage (anything 20% or less its time to change) or by a mileage you are comfortable with or by used oil analysis examination to see how good the oil can go for on a change.
Good to know about the outer tire rods..noted. I wanted to lower my truck and everyone was telling me that you normally need to do suspension every 100k or so. I do use it as a work truck but basically have 200-1000lbs in it max. I never tow with it.
tires, it’s hard to say..I’ve had some rub very bad when I lowered it that only lasted a few weeks.
I thought oil was every 10k. I’ll do every 7-8 now.
ive also had a couple injectors go on me at like 130k. A couple sensors recently as well. But that could’ve been from a cracked hose connector on my cold air intake. K&N shipped me one for free no questions asked 👍
just wondering if my truck is a lemon or if they all require maintenance as frequently. I guess I’ll suck it up lols. Seems like it’s often because I put about 50k/year on it
OLM on my 15 is 7500 regardless of how hard I drive it.
Tires are Michelin and are rated @ 70000 but usually get 50000  miles.
Still on factory plugs at 200000 and get 18-19 mpg on highway at 75.  (I dont drive 75 often though.). Also not saying that is right but it is where I am at with my truck.
Also, I use full synthetic and Wix or ac Delco filters and go 10000 on changes. I used To have the oil tested and 10000 was always good so I have Not tested in a while.
Brakes made it to 165000 but I rarely pull a trailer and my daily drive was 225 miles, mostly highway.
jusy my experience.
My plugs were fine at 125kms but I wanted to be a keener. Just want it running as good as possible. I drive a wee bit spirited so my mileage isn’t the best. I also have about 250lbs of wood and woofers plus the added weight of the chrome 24’s. My brakes squeal like pigs at 80kms. Not sure what the mileage on the pv brakes are compared to the regular wt pads and rotors.
my oil had always been golden. 👍
I think it really just depends...like, your suspension. I almost never go on a mileage point on suspension , I just inspect and replace as necessary. Same for tires and brakes.
Oil, I don't go much over 5,000 miles. Tranny around every 40,000 miles. Same with diffs and transfer case. Plugs, every 100,000 miles. Undercoat at least once a year. Wax the paint once every three months. Rotate the tires every 5,000 miles or so and get the alignment checked once a year.
This^^is just what I've always done and it seems to work.
On 4/2/2021 at 2:56 PM, meirikm said:
Hey all,
tires- every 80k?
suspension - 100k
brakes- 80k
is this typical?
Tires, like stated will depend on many things.  I got 70k out of my Michelin LTX MS2's  But 40k on Continentals on our Suburban.  Driving style and road conditions and city vs hwy make a difference.
Suspension, I don't mess with it until something needs to be replaced. Again driving terrain and such come into play here.
Brakes, well I was lucky on my 2002 Silverado.  Still had the original pads on the front brakes. The rear got replaced at 120k due to the R/R caliper sticking wearing out the pads.
Plugs i change out at 100k.  Something that just makes me feel better.  I know of some that go way longer with no issues.
Oil changes.  This is one that is up to the individual for the most part.  I go by used oil analysis to let me know how far I can go.  Right now I have been going 15k with AMSOIL Signature Series but the last two UOA's showed that I need to back it down so I'm going to test at 10K and see where I stand.
Transmission fluid change is right on.  Keep it changed out at 50k miles and life will be good for your transmission.
On 4/2/2021 at 1:56 PM, meirikm said:
Hey all,
tires- every 80k?
suspension - 100k
brakes- 80k
is this typical?
I see we are working kilometers 😉
Tires. 80k km is just under 49,709. You don't say what tire style A/T won't last as long as H/T but like said several other times your driving and maintenance habits have a world to do with this. I just retired a set of still fully useable (by tread wear) Bridgestone H/T at 125,000 miles as they dated out. I'm a maintenance fanatic and drive easy only on paved roads. So...
Suspension. Also a wear item influenced by driving style and maintenance. Replace on inspection and keep it aligned. Once a year minimum. Off road? Twice a year.
Brakes also a wear item based on use. There are guys that use up a set in 30,000 miles (48,000 km) and then there is a long list of fellows over 150,000 miles with plenty left. (250,000 km).
Plugs: Iridium plugs will be fine for 100,000 miles (160,000 km) in a motor that uses little oil. Don't forget wires.
Motor oil. Hum.... There is nothing on the market I would run more than 5,000 miles (8,000 Km) and most of them not over 3,000 miles (5,000 Km) but that is what I do.
Trans, Book suggest every 45,000 miles (72,000 km). Did my first one at 50,000 miles (80K km) and it was well past it's expiration date so I've shortened that. I do not drive hard. 40,000 km would be prudent IF you continue to use the OEM fluid and retain the thermostat. IHMO. If you tow or haul heavy I'd consider it a must.
I expect you will continue to receive advice on this topic. It is a hot button but remember it is YOUR eyes on equipment and YOU that is operating it. So your boots on the ground doing the assessments.
Edited by Grumpy Bear
    • 37's would probably fit with a 3" lift. GM only has two gear ratios for these trucks 3.73 for gas and 3.42 for diesel. And they can't be programmed for anything else at the moment. The rough country module just corrects the speedometer and odometer to adjust for tire size it's not a programming device.   You haven't said if your truck is gas or diesel, but for a gas truck the 10L1000 with 3.73 gears has a lower final drive ratio than the 6L90 it replaced would if it were swapped to 4.10s. GM used the same 3.73 gearing in 6 speed gas trucks. I don't think you'll have any issue running 37's with the 10 speed other than the reduction in mpg and towing/weight capacity which is as much of a function of the lift as the tire size.
    • Actually, it probably was the brakes.  It's weird the way the messages came across, but I took it to the dealer thinking that something was wrong with the sensor and in fact, the rear brakes were shot.  What I don't understand is why the messages never said, your brake pads are low.  First I got the message I posted above, taking about new pads being detected.  Then I got a message saying that the system needed repaired.  It never said, change your brake pads.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
