Personally have the Undercover ArmorFlex.  I had the Uncercover Flex on my Colorado and in 5 years was pretty happy with it.  Broke one prop rod hanger and the company sent a new one no questions asked.  This Armor flex is great.  Very tough, sturdy, and NEARLY waterproof.  Easier to install and easy to remove if you need for some massive load.  Big fan.
5 hours ago, Paul 2020RST said:
My Gator is a hard top.
The one in the link above looks to be a soft top. Good to know they make both types.
I have the Undercover ArmorFlex on my AT4.  It's alright.  It seems a little flemsy, but it gets the job done.  I had a G4 Elite on my last truck and I liked it much better.  It was definitely stronger and I liked being able to get access to the front of the bed.  Too bad they went bankrupt.
I went cheap this time with a soft cover, but I don’t think my one complaint is unique to soft covers.  Make sure your tailgate can go down.  I have an automatic tailgate and it gets hung up on the cover seal so I have to manually pull it down.  Not a big deal in practice, but anything that doesn’t work right bugs me.
I had the Lomax in my prior truck, and liked it but the soft cover is cheaper and easier to deal with when you want to use the bed.  It just rolls up.  The Lomax had to be removed if you needed the whole bed (versus 2/3’ds).  No matter how easy it seems to remove those types of covers, stay away.  Get one that flips out of the way but doesn’t need removed.  Removal it a pain with a tri-fold/hard cover.
I have the one from GM (was installed before I bought), has been great - does allow a little water in corners in car wash, but that is it. it is pretty stiff and I have stood on it, but not near as sturdy as the Avalanche factory one was....I have had to remove it when hauly my cruiser (have short box, needed whole bed)...it was easy to take off and put back on.
My MX4 once folded is a snap to remove, two thumb screws and pick it up, Its not heavy and I do myself.
I could do mine myself too, but it’s not easy.  You still have to get it off your truck without bumping into anything painted and you have to get it down from a truck that sits up kinda high.  Then, where do you put it?  If you’re away from home and find yourself needing your entire bed, have fun.  Where are you going to put it then?  In your cab?  Careful with that leather interior.  Even at home, storing it may lead to damaging the cover.
Don't get me wrong.  The MX4 is a sweet cover.  But, if you have to remove them, they lose a little luster.  I really like my roll up cover but I’m not gonna lie - it’s not good looking.
Edited by GN2018
I know this isn't what you asked but for me, I went soft tri-fold.  Reason being is, I need to take it off fairly regularly.  The hard ones, from my experience, at a PITA to remove/install.  I can do my soft fold in about 5 minutes
I have a semi-rigid two fold from Chevrolet for my standard bed Silverado. Can’t call it a tri fold because the last section near the cab is held in place with hand tightened screws.   Looks great. Weathertight. Light weight. Some sort of thin fiberglass under the tonnou cover. But I wouldn’t stand on it. Easy to remove. Thinking of getting a 2021/22 short bed GMC and wondering if they still have the same to fit a short bed?
Either stand it on its side edge along the side of the bed, lay it down flat in the bed, or lean it up against the front bulkhead.  Lots of possibilities, if put half a thought into it.  No need to be mellowdramatic about it.
There’s a possibility that it can go in the bed, but the assumption is that you need the bed, otherwise you would not have taken it off.  Not sure it could go up against the bulkhead because it is wider than the bed.  Nothing mellow dramatic about it.  If you think you’re going to use your full bed often and doing so requires you to remove the cover instead of flipping it or, in the case of a soft cover, rolling it, you should consider it.  That’s all I’m saying - it’s a consideration, not a deal breaker.  However if I used my full bed often, I’d probably just go with a soft cover.
When I had a trifold it wasn't a matter of using the whole bed.  It was a matter of need to use more than the full bed due to height.  We've all been there.  Regardless of what type of tonneau somebody gets there's always going to be a sacrifice to make.
Ill be looking for a cover myself in a few months. Out of all the ones mentioned here, I havent seen many say if it interferes with the auto down of the tailgate. Can anyone speak to this for the models you have on your trucks?
The BakFlip MX4 does NOT interfere with auto down or auto up of the tailgate.
Awesome. Granted I do not have auto up. Hopefully it will allow the install of a TonneauMate storage box also.
Edited by Byrds8
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
