On 3/2/2024 at 12:48 PM, Bikerjon said:
Who is gonna pay for this one?
Extended warranty. Got the truck back last week after an engine rebuild. Made it 400 miles, now the injectors took a sh*t.
Hope they cover this one too.. after this I might just dump the truck and buy a Tundra. I do not want to be on the side of the road in 120 degree AZ Summers.
Better not buy a new Tundra then.  Stick to 2021 or earlier Tundras, the new ones are having their own fair share of issues.
I prefer to just keep this truck. It's paid for (paid it off just recently), but of course it's having problems now. Nothing seems to be built to last anymore. The other option is a 2500 Gasser. I heard the L8T is a solid engine.
I hear you loud and clear.   I just paid off my 2020 last year and I REALLY DONT  want to purchase a new truck anytime soon, but at 126K miles I figure I cant complain if I get to 200K, which should be in 2 years or so.
An HD gasser is about as dead nuts reliable as you can get, if you don't mind the piss poor MPG's :)
That might be the way to go unless federal mandates f*ck that motor up too. New regs are coming for med duty trucks.
All i hear is lifter failure left and right lately.
Is there no major class action lawsuit against this?
Hopefully they issue a major fix on the 2025's?
I just bought my 2015 LTZ, 5.2 AFM. 137k miles and according to the carfax, no engine work. I changed the plugs, engine oil and did a tranny filter and fluid flush in the 2 weeks I have had the truck.
Less than 1% of trucks are affected by the lifter issues.  Granted, I don't want to be that 1%, but I can assure you that of that 1%, near 100% are getting online to complain about it when it happens to then, which will make it look a lot more frequent of an occurrence than it really is.
Exactly.
I don't know anyone that has had this problem. I know a lot of guys in GM trucks.
A not forget people come to these sites just to bash the brand and not even own a GM product. Alot are new sign-ups with 1 post or so and say " I just had the same thing happen to me" and continue bashing the truck to only not heard from again. Think about it I could join a Ford, Dodge etc forum and post something bashing the brand like engine issues etc and not even own one just to create panic on the site and rumors. Not that I don't believe all of it I just don't trust a lot of what I read on forums.
Edited by Silverado4x4
30 minutes ago, dieselfan1 said:
Exactly.
I know 4 people that had this issue including myself on my 2018 silverado 6.2 they were all around 80k to 100k kms when it happened the other 3 were 5.3s mine was the only 6.2 that had it so far. I have a 2020 1500 6.2 right now and haven't had any issues yet knock on wood it has 125k kms
I have about 550 miles on my rebuilt 6.2L going to change the oil again (did it the first 2 hours after idle). An exhaust valve spring cracked in three places on cylinder 4 on the rebuild. Replaced the valve spring last Thursday. Drove it every day so far and haven't had any issues (a little over 200 miles).
I hope I fall into the 97% that don't have a lifter failure now that this L87 has been rebuilt with updated parts.
I do not believe it is this low. Of the 4 people I know with them, 1 is a diesel, and 2 of the other three (mine included in the 2) have had a minimum of a bank of lifters replaced. Small sample size, but it is hard for me to believe the number is that low especially given the dealer stocks the parts for lifter jobs.
 Source for the 1% number?
(It's a lot higher than that)
Source for the " its a lot higher than that" number?
Most people only join a forum when they have an issue. Last time i checked there was only like 333K people on this board. Out of that number, how many had lifter failures? Between 2019 and March of 2024 there were 2,906,782 Silverado's sold(in the US, NOT INCLUDING GMC SIERRAS)  So using those numbers alone, ONLY 11.46% of SILVERADO owners are even on this board, and out of that number, how many have had lifter failures?? SO 1% is a totally plausible number.
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
