Good afternoon.  I am experiencing weird issues with my rear power windows on both drive and passenger side.
both rear windows will roll down, but not up with their own window switch in the back doors.
i can (intermittently) roll them up with the master switch on driver door.  the other day, i couldn't roll the passenger rear up at all.  i ended up opening and closing the rear door, then i could roll the window up.
any ideas on what i should start looking for?
Appreciate any help.  thank you
2011 Silverado 1500 4X4, 5.3L   100k miles
it may be broken wires in the conduit between the door and the body, most likely the drivers door as that sees the most use. slice the rubber conduit with a razor knife and inspect the wires. you may need to pull on individual wires as sometimes the wire breaks but not the insulation .if the wires broken the insulation will stretch when u give it a tug. all the windows rely on the wiring to the master switch for power. if you find broken wires solder them back together and shrink tube them
thanks for the insight.  i will investigate and report back.  it may be a few days - but I will report my findings
  • 4 months later...
so, i have yet to investigate this.  sorry for the delay.  i just have been taking my chances with the windows rolling up or down.  I am ready to explore this.  I have a question first, might seem dumb, but if I cut the rubber conduit what happens if:
  • I find the wires are fine?
  • How do I reseal the conduit once cut?
There is another post from the past couple days that has a utube video of repairing the switches. You might want to try that first
  • 2 years later...
sorry for the no reply.  yes - i did solve this problem this past summer.   I did have a broken wire in the wire harness that runs thru the driver door.  if i remember the wire was green.  that didn't fix my problem, however.  I ended up replacing ALL window switches in all 4 doors.  problem has since been gone.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
