Coolmaker Posted February 25, 2012 Posted February 25, 2012 i'll be playing with this sysconfig this evening.... i just got iGo last night so i'm excited to start customizing it! Please tell me where you got the file.. going nuts trying to get it... TIA
wottenad Posted February 27, 2012 Posted February 27, 2012 i'll be playing with this sysconfig this evening.... i just got iGo last night so i'm excited to start customizing it! Please tell me where you got the file.. going nuts trying to get it... TIA If you register on some of the iGo Primo forums out there, you'll see all of the tools that I've been referencing (it's where I got them), and a whole lot more... GSMNoeman.com igo8navigation.com navitotal.com (see the "Tips and tricks with devices and sys.txt" posts)
wottenad Posted February 27, 2012 Posted February 27, 2012 Want to see what's possible with iGo Primo's sys.txt? Here's a post I copied from navitiotal.com that lists all lines of sys.txt that can be used. I have no idea if this is a usable sys.txt file (actually, I doubt it will work in current form, and some settings look like they are definitely location-specific), but I'm posting this as a reference for all the settings possible to be used in the sys.txt file. DO NOT USE ANY SETTING YOU SEE IN THIS FILE WITHOUT BACKING UP YOUR CURRENT SYS.TXT FILE FIRST!!! [device] sdcard_name="SDMEM" type="Audiovox_USA_OE" ; identifies where the file will be used and is required for Advent OE navi units ;### general smartzoom settings ; angle: 0 = from top, 90 = horizontal but crash (max is 89) [camera] ; common settings maxdistance=1000 maxdistance2d=1000 ; 2D settings minzoom2d=200 maxzoom2d=1500 defaultzoom2d=1200 ; 3D settings minzoom=40 maxzoom=100 defaultzoom3d=80 minangle=40 maxangle=89 defaultangle=85 angleoffset=25 ;### test overview_enabled=0 ;0 1 Always North Up? overview_distance=2000 overview_zoom2d=2000 overview_zoom3d=100 overview_angle=0 ;### test speedzoom=0 ; speed dependend zoom speedzoom_use_minmax=1 ; minzoom/maxzoom speedangle=1 ; speed dependend cam angle speedangle_use_minmax=1 ; minangle/maxangle lowspeed=5 ; if minmax this speed is for min val highspeed=70 ; if minmax this speed is for max val ;### Entries presets Smartzoom (sc_Set_Presets) ;Camera Presetid 1 (low viewpoint) [camera1] ; common settings maxdistance=700 maxdistance2d=700 ; 2D settings minzoom2d=100 maxzoom2d=400 defaultzoom2d=300 ; 3D settings minzoom=40 maxzoom=90 defaultzoom3d=70 minangle=50 maxangle=89 defaultangle=85 angleoffset=20 ;### Entries when Signpost is visible (sc_AngleSignPost) ;Camera Presetid 11 (low viewpoint) [camera11] ; common settings maxdistance=700 maxdistance2d=700 ; 2D settings minzoom2d=150 maxzoom2d=600 defaultzoom2d=400 ; 3D settings minzoom=40 maxzoom=90 defaultzoom3d=90 minangle=50 maxangle=89 defaultangle=85 angleoffset=0 ;Camera Presetid 2 (normal viewpoint) ;[camera2] ;maxdistance=1000 ;Camera Presetid 3 (high viewpoint) ;[camera3] ;maxdistance=5000 ;Camera Presetid 21 (normal viewpoint) ;[camera12] ;Camera Presetid 31 (high viewpoint) ;[camera13] [camera.roundabout] enabled=0 ;(1) [camera.intersection_zoom] enabled=1 [other.fm_transmitter] fmtx_enabled=0 ;needs proper nnghal.dll ;[modules] ;IFM_TRANSMITTER="NNGHAL_FM_TRANSMITTER" ;IFM_TRANSMITTER_MANAGER="FM_TRANSMITTER_MANAGER_IMP" ;[swid] ;activation=device ;getsysentry card or device [msnd] enabled=0 ;######################################################################## [2d] carcenter_y=35 label_rendering_order="texts,shields,icons" ;(icons,shields,texts) building_draw_outline=1 ;(0) building_maxzoomlevel=500 ;(500) draw_polygon_contours=0 ;(1) drop_little_road_segments=1 ;(0) show_planned_route_arrows=1 ;(1) road_simplification_level=5 ;(5) adaptive_2d=1 ;(1) group_poi_icons=0 ;(1) max_icons_shown=20 ;(30) enable_icon_fight=1 ;(0) use_r1_roadnames_for_r2_if_missing=1 ;(0) traffic_lights=1 ;(0) mincarsize=80 ;() mincarsize_zoomlevel=2000 maxcarsize=150 ;() maxcarsize_zoomlevel=200 min2dplannedroutewidth=5 ;(5) render_during_animation=1 ;(0) ;loading_screen_text_color=0xFFFFFF ;(0) ;loading_screen_color=0xFFFF ;(0xFFFF) double_pixel_enabled=1 ;(0) [3d] disable_car_normals=1 ; mdl surface normals discard anti_alias_buildings=0 ;(0) anti_alias_landmarks=0 ;(0) anti_alias_shapes=0 ;(0) landmark_min_brightness=300 ;(700) max_pois=60 ;(97) max_pois_on_horizont=12 ;(17) use_all_building_textures=0 ;(1) render_buildings_as_shapes=0 ;(0) buildings (3dc) flat on the ground roads_as_line_stripes=1 ;(1) reduce_line_stripes=1 ;(0) asymmetric_projection=0 ;(0) diffr 3d view planned_route_visible_behind_mountains=0 ;(1) ;planned_route_track_width=8 ;(10) ;planned_route_track_contour_width=1 ;(2) ;planned_route_contour_width=2 ;(4) car_antialias_mode=edgeblur ;(supersample) edgeblur fade_around_cursor=1 ; when click on map buildings fade fade_distance_for_car=60 ;(20) fade_overlap_tolerance=50 ;(32) ;tmcroadthickness="0.5" ;(0) ;plannedroutethickness="0.2" ;(0) ;guidancestrip_thickness="0.2" ;(?) elevate_guidance_strip=1 ;(1) guidancestrip_elevation=0.08 ;(0) ;guidance_strip_switch_distance_meter=300 ;(600) ;guidancestrip_startscaledist=300 ;guidancestrip_stretch=25 ;global_ambient=0x7AE147AE ;(0x7AE147AE) ;poi_min_lod=12 ;(11) ;use_vertex_color_triangles=1 ;(1) cell_road_density=200 ;(400) ;road_polytrack_switch_pixelwidth=10 ;(12) minimum_flag_distance=5000 ;(50000) ;### visibility and render prio near_road=1 ;(1) near_road_prio=1 ;(1) far_road=1 ;(1) don't render far roads far_road_prio=10 ;(1) far_road_prio_shift=10 ;(6) shapetile=1 ;(1) shapetile_prio=4 ;(0) shapeline=1 ;(1) pois=1 ;(1) building=1 ;(1) disable buildings building_prio=15 ;(15) tracklog=1 ;(1) cell_lod_modifier=12 ;(8) level of detail? no clue ;min_task_ratio=0 min_task_processing=3 ;1 or 3 ;min_camera_height=1 ;(0) ;forced_fov=35 ;() overrides fov? [3d_config] roadsign_bitmaps=0 ;(0) 1 in igo9.ini, bmp text balloons ;are the bubbles only active in navigation mode (0) or also in drag mode(1) ;roadsign_always_framed=0 ;(0) ;roadsign_frame_space_size=4 ;(4) ;roadsign_font_size=12 ;(0) ;disable_roadsign_navigation_mode=0 ;(0) navi_mode_roadsign_dist_limit=800 ;(0) navi_mode_roadsign_zoomdist_limit=1500 ;(1500) roadsign_max_refresh_time=800 ;(400) ;rotated_roadsigns=1 ;(1) ;hide_tmc_on_road=0 ;(0) ;default_label_colors=0 ;(0) ;Sprites if [3d_config] roadsign_bitmaps=1 ;[roadsign_sprites] ;Sprite names, should be in theme folder ;main="street_name_main.spr" ;left="street_name_left.spr" ;right="street_name_right.spr" ;leg_left="street_name_leftleg_dn.spr" ;leg_mid="street_name_midleg_dn.spr" ;leg_right="street_name_rightleg_dn.spr" ;font_color=32,32,32 ;######################################################################## [debug] ;### this creates detailed running logfile for tts etc ;log_1="\Storage Card\igo8_primo\_debug.log::5" animations=0 ;getsysentry disablesmartdetour=0 ;getsysentry tmc_provider_list_plus=1 ;getsysentry skindebug=0 ;getsysentry showsuspendmessage=0 ;getsysentry "Back from Suspend" usenightmode_tunel=1 ;getsysentry petza_enabled=0 ; somethings with recording/debug? show_battery_percent=1 ; battery level text below bat icon experimental_features=1 ; extra settings in extra menu ;leak_check=1 ;looks like primo leaks ;skip_platformlock=1 ;(0) hmmm... skip_wce6_deviceid=1 ;(0) hmmm... tmc_all_stations=1 ;(0) hnr=1 ;(1) use hnr, see [route] minimum_hnr_distance_km skip_eula=1 ;skip end user lic aggr ;show_frc=0 ;0 smart_2d=1 ;0 earth=1 ;0 show_junction_view=1 ;0 see config\junctionviewXXX.ini show_gps_pos=1 show_signpost=1 show_oneway=1 ;0 show_oneway_3d=1 ;0 ;onewayarrowmode=2 ;show_hnr=1 ;show_clipboard_path=1 show_arrows_on_route=1 show_lane_info=1 show_poi_areas=1 ;(0) show_poi_boundingrects=1 ;(0) ;plannedroutethickness="0.8" ;farguidancestripthickness=2 ;tmcroadthickness="0.9" ;render_without_focus=0 ;(0) ;double_pixel_mode=0 ;(0) ; TTS settings tts_min_ready_wav=1 ;(0) tts_getaway_time=400 ;(0) tts_expected_engine_delay=1200 ;(0) reserve_memory=2097152 ;(0) default 4Mb, don't use less that 1Mb (1mb=1048576 2mb=2097152 3mb=3145728) ;memory_low_bound=1048576 ;(0) bits? kb? ;show_performance_memory=1 ;show_performance=1 ;show_rawdisplay_info=0 ;(0) handy for seeing what igo chooses as display driver monkeytest_highspeedsun=0 ;(0) ;fov=45 ;(45) for 480_272 is set to 35 in igo9.ini, affects angle/zoom bigger makes 3d car smaller logitiner=full ;(off) on full, itinerlog.csv on sdcard ;show_turn_penalty=1 ;(0) ;turn_penalty_multiplier=50 ;(100) < 100 accepts more turns in route, try 46 for ECO turn_penalty_multiplier=40 test_recalc=1 ;(0) ;# Primo 1.1 tmc_info_in_description=1 ;(0) tmc_extract_no_slipblocks=0 ;(0) tmc_extract_all_segments=0 ;(0) tmc_group_mask=xFFFFFFFF ;(0xFFFFFFFF) use_loader_thread=0 ;(0) 1 shows no roads at all ;######################################################################## [feature] signpost_nightshading=1 ;(0) signpost_coloring=1 ;(0) tmc_event_coloring=1 ;(0) tmc_traffic_side=1 ;(0) tmc_show_direction_arrows=1 ;(0) tunnel_guidance=1 ;(0) 1 causes crash ;######################################################################## [folders] app="%SDCARD%/iGO8_PRIMO" ; change this if applicable data="/Storage Card/iGO8_PRIMO" ; content="/Storage card/igo8/CONTENT" kmlpoi="userdata\poi" ;"content\userdata\poi" kmlroute="userdata\route" ;"content\userdata\route" ;user_car="mycars" tts_nua_v5="\Storage Card\igo8_primo\tts_nua_v5" tts_loq="\Storage Card\IGO8\TTS_LOQ" ;needs loqmsx.dll LoqTTS6.dll LoqTTS6_util.dll LoqDutch6.5.dll has_secondary_root=0 ; do not search for other igo8 distributions ;######################################################################## [gps] disable_advanced=0 ;default_latitude="XX.3737921" ;default_longitude="XX.9059051" read_total_timeout=50 ;(100) read_buffer_size=128 ;(256) discard_dop_level=49.0 ;? min_distance_timestamp=3000 ;(20000) ;background_navigation=1 ;(0) delay=250 ;(250) ;######################################################################## [icon_manager] extra_icons="ui_igo9\common\brand_icons" ; in igo9.ini ;######################################################################## [interface] store_demo=0 ;getsysentry show_musicplayer=1 ;getsysentry show_pictureviewer=1 ;getsysentry ;lmg_all_days=1 ;getsysentry shutdown_time=30 ;getsysentry-> now fixed in 22jul2010 version show_minimize=1 ;getsysentry show_exit=1 ;getsysentry start_navigation_time=5 ;(10) GetSysEntry show_tutorial=0 ;getsysentry small_build=1 ;getsysentry extra_settings=1 ;getsysentry ;start_state="st_MainMenu" ;getsysentry vfont_enabled=0 ;.vfont files font_quality=light ;normal lcd lcd_v light mono align_style=ascender ;ascender full capheight legacy enable_stateanim=0 ;0 uieffect_enabled=1 ;1 ;show_bugreport=1 ;0 ;bugreport_audio=0 unreachable_viapoint_as_target=1 ;0 max_distance_for_route_to_poi=2000 ;0x2700 ;screen_snap_distance=20 ;20 ;mapfontscale=100 ;100 set to 130 in skincfg.ini ;mapfontscale2d= ; ;mapfontscale3d= ; ;mapfontscale3dframed= ; ;highlighted_cityname_first=1 ;0 night_mode_altitude=1 ;0 ;make_up_exonym=1 ;1 showexitnum=1 ;1 ;builtin_themes= ; skin *.gro *.zip ;theme_day= ;theme_night= use_separated_daynight_list=0 ;0 minzoom2d=100 ;100 ;maxzoom2d= ;calculated minzoomglobe=100000 ;() 100km 2d zoom before switching to globe view blendeffect=4 ;4 ;min_doubletap_ms= ;min_doubletap_px= ;cleanup_config="config/cleanup.ini" ;laneinfo_signpost_enabled=1 ;(1) show_detailed_posinfo=1 ;0 show_tmc_config=1 ;(0) show_gps_config=1 ;(0) show_orientation=1 ;(0) show_calibration=1 ;(0) traffic_voice_recalc=1 ;(1) traffic_voice_trafficjam=1 ;(1) max_flag_distance_3d = 5000 ;(-1) always show dest flag in 3d capture_to_jpeg=1 ;(0) else bmp highlighted_cityname_first=1 ;(0) use_autohint=1 ;(0) useminaspect=1 ;(0) make_up_exonym=0 ;(1) compass_velocity=20 ;(10) ;######################################################################## [itiner] handle_via_passing_as_destination=0 ;(0) remove_reached_destination=0 ;(1) pass_destination_radius=200 ;(0) pass_destination_distance=50 ;(0) pass_via_distance=100 ;(0) show_prev_manuevers=1 ;(0) show_only_till_next_viapoint=0 ;(0) show_only_ahead_of_car=1 ;(0) displayed_warnings="1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17" ;(1,2,3,8,9,10,11,12,13,14,15,16,17) ;######################################################################## [map] set_max_bubble_labels=8 ;(5) 3d_scale_carmodel=1 ;(1) 3dcarsizemulwithfov=50000 ;(0) 3dcarsizemin=6000 ;(10000) 3dcarsizemax=18000 ;(28000) 3dcarsizemul=30000 ;(40000) 3d_max_tiltlevel=8500 ;(7800) 3d_default_tiltlevel=8500 ;(7800) zoomlimitedtilt=0 ;(0) 3d_min_zoomlevel=20 ;(30) 3d_max_zoomlevel=800 ;(600) before switch to 2D, getsysentry is 14000 ;3d_max_zfar=64 ; still used? Not in Primo tiltfactor=50 ;(150) zoomfactor=1.02 ;(?) rotfactor=20 ;(10) ;minimum_zoom_amount=70 ;() ;minimum_tilt_amount=70 ;() ;minimum_rotate_amount=15 ;() ;minimum_3d_zoom_percent=100 ;(100) max_road_segment_count=1000 ;(2000) sieve_mode=0 ;(1) 0=wireframe faded buildings, separate what? ;###housenr_corner_offset=0 ;(0) causes crash with 3dl/3dc on shade_factor_min=0.5 shade_factor_max=1.3 3d_brunnel_tunnel_shutdown=5 ;poi_iconid_near=1 ;(1) ;poi_iconid_distant=0 ;(0) ;poi_distant_distance=2000 ;(3000) ;poi_grouping_distance= speedcam_visibility=1500 ;(2500) ;car2wp_as_route=1 ;(1) ;speedwarn_icon="$speedwarn.spr" ;("$speedwarn.spr") ;tmczoommin=3000 ;(3000) ;tmczoommax=60000 ;(?) ;tmczoommini=30000 ;(30000) ;tmczoomsmall=8000 ;(8000) ;3d_tmc_road_extra_width=0 ;(0) ;auto_nightmode=1 ;(1) ;nightmode_dependent_backlight=1 ;(1) 3d_buildings=0 ;(1) 3d_landmarks=1 ;(1) raster_in_2d=0 ;(1) raster_in_3d=0 ;(0) raster_2d_high_quality=0 ;(1) shapes_in_2d=1 ;(1) show_oneway=1 ;(1) follow_gps=1 auto_set_2d_on_map=0 ;(0) auto_set_3d_on_cockpit=0 ;(0) poi_labels=1 ;(1) ;no_road_rotate_speed_min=10 ;(10) enable_rotated_move=1 ;(0) ;move_zoom_divider=15 ;(15) enable_move_cursor_on_move=1 ;(0) ;center_animation=1 ;(1) ;3d_snap_distance=50 ;(50) ;2d_snap_distance=50 ;(50) ;3d_jump_distance=500 ;(500) ;2d_jump_distance=50000 ;(50000) ;grayscale=0 ;(0) ;######################################################################## [map_update_checker] enabled=0 ;######################################################################## [mydata] cityhistory_size=1000 ;(300) max_quicklist=250 [mydata.smart_history] max_smart_items=4 ;getsysentry [mydata.tracks] auto_track_visible=1 ;(0) ;######################################################################## [navigation] gps_pos_to_road=1 ;(1) waypoint_radius=800 ;(300) waypoint visited if < 300 mtr? waypoint_radius_multiplicator=1 ;(1) track_simulation_speed=5 ;(3) ;onlyguidancetime=5 ;(0) skip to secs before next maneuvre ;onlyguidancedist=500 ;(100) when simulate skip to distance before next maneuvre autoreplan_action=AUTO ;(AUTO) pedestrian_pos_filter_enabled=1 ;(1) slowspeed_time=5 ;(5) slowspeed_limit=5 ;(5) show_city_in_next_street=1 ;(1) show_city_in_next_street_distance=1000 ;(1000) junction_view_type="NNG" ; used by UI to determine which JV type to use, other options are "NNG_NQ" or "NQ" junction_view_at_maneuver=0 ;(1) junction_view_on_highways_only=1 ;(1) junction_view_distance=150 ;(200) junction_view_distance_ramp=300 ;(400) junction_view_distance_highway=400 ;(800) simple_crossborder_warning=0 ;(0) crossborder_warning=real ;(off) simple real smart turn_direction_ding=1 ;(0) config/turndir.csv max_exit_number=9 ;(9) dead_reckoning_duration=480000 use_duration_for_tunnel=0 stop_at_tunnel_end=1 ;sim_speed_factor=2 ;(0) onlyguidancedist=100 ;(100) skip simu to last 100 mtr next maneuvre onlyguidancetime=0 ;(0) skip simu to last x sec next maneuvre ;######################################################################## [oasis] exclude_directories="PICTURE::%SDCARD%/,PICTURE::%myflashdisk%/" include_directories="PICTURE::%SDCARD%/Pictures/" [oasis.pictures] slideshow_time=3 slideshow_effect=1 slideshow_loop=1 loadhq=0 large_pict_size=1024 ;######################################################################## [other] demo_enabled=0 ;1 No demo button in navigate multiple_voice=0 ;(0) Uses english tts voice for alerts ;######################################################################## [phone] show_dialer=1 ;getsysentry show_hangup=1 ;getsysentry show_bluetooth=1 ;getsysentry ;######################################################################## [poi] use_multi_poi_icon=0 ;(1) ;### poi_grouping_disctance etc in mapstates.ini [default] userpoi_has_mypoi=1 ;(0) use_lastknowngps=1 ;(0) ; Airport, Business, Car_Dealer_Repair, Communication, Community, Finance Leisure ; Medical, Nature, Parking, Petrol_Station, Rent_A_Car, Restaurant, Shopping, Sport ; Tourist_Attractions, Transportation sort_order="Petrol_Station,Parking,My Poi,Restaurant,Shopping,Accomodation,Medical" ;("Restaurant,Accomodation,Petrol_Station,Parking,Medical") priority="Petrol_Station,Parking,My Poi,Restaurant,Shopping,Accomodation,Medical" ;("Restaurant,Accomodation,Petrol_Station,Parking,Medical") sort_by_config=1 ;(0) picturepoi_show_all_containers=1 picturepoi_has_mypicturepoi=1 ;######################################################################## [power] ;skip_suspend_process_all=1 ;getsysentry powermgm_state=1 allow_battery_full=1 ;######################################################################## [rawdisplay] gx_force_using_dll=1 ;(0) ;force_15_bpp=1 ;(0) driver=GX ;GLES GX GDI ;see multimode.ini ;stretch=1 ;stretch_x=1 ;stretch_y=1 ;######################################################################## [route] min_suspend_time=1800000 ;getsysentry trip_offset=1000 ;getsysentry ;### if you fiddle with these delete save/route.dat before starting igo planned_route_weight=1 ;(7) smaller is less nervous recalc (0 to 10) correctness=95 ;(88) route_type=ECO ;(FAST,ECO,SIMPLE,SHORT,SCENIC,MOST_FREEWAYS,LEAST_FREEWAYS) GREEN speed_profile_weight=100 ;(100) ;fixed_correctness=? ;? vehicle_type=7 ;0...6(7 8 9) car taxi bus truck emergency pedestrian bicycle (7=slow_car 8=fast_car 9=motorcycle) ;### vehicle_type=7 slow_car slow_car_speed=70 ;(80) affects routing and time slow_car_multiplactor=90 ;(80) affects routing and time ;### vehicle_type=8 fast_car fast_car_speed=120 ;(130) affects routing and time fast_car_multiplactor=100 ;(100) affects routing and time ;### vehicle_type=9 motorcycle motorcycle_speed=120 ;(130) affects routing and time motorcycle_multiplactor=100 ;(100) affects routing and time offroad_speed=20 ;(30) permit_penalty=1000 ;see [truck] charge_penalty=1000 ;(0) toll_penalty=100 ;(0) bridge_penalty=100 ;(0) in meters? tunnel_penalty=0 ;(0) uturn_penalty=5000 ;(1000) low_speed_zone_penalty=90 ;(0) straight_start_on_recalc=0 ;(0) 1 is auto recalc bug? continue_with_ferry=1 ;(0) handle_freeway_as_highway=0 ;(0) allow_offroad_waypoints=1 ;(0) minimum_hnr_distance_km=100 ;(100) use hnr if trip > 100 km auto_enable_crossborder=1 ;(0) guidance_at_highway_entry=1 ;(0) ;# Primo 1.1 ;allow_4wd=0 ;(0) ;fuel_consumption_urban= ;fuel_consumption_rural= ;engine_type= fuel_cost="1.5" [route.histspeed] enabled=0 ;(1) show=0 ;(0) use_timeslice=1 ;(0) start.lua switches it off anyway [route.histspeed.timeslice] day=0 ;(0) hour=0 ;(8) minute=30 ;(0) ;######################################################################## [scheduler] disable_smooth_anim=1 ;(0) ;######################################################################## [screen] daymode_until_no_time_sync=1 ;(0) ;preferred_orientation=0 orientation_lock=0 ;(0) ;######################################################################## [sound] ;ding=0 ;no annoying announcement ding maneuver_chimes=0 ;no annoying announcement ding wheelsound=1 ;(0) scroll list sound dynamic_volume_type=1 ;(1) ;dynamic_volume_minspeed=30 ;(90) ;dynamic_volume_maxspeed=120 ;(150) ;dynamic_volume_voicemaxspeed=100 ;(120) ;dynamic_volume_voice_volume_max=100 ;(64) ;dynamic_volume_os_volume_max=255 ;(255) ;dynamic_volume_os_amplification_step=-1 ;(-1) ;dynamic_volume_autocalc_maxvoicespeed=0 ;(0) tts_volume=255 ;(255) guidance_volume=255 ;(255) alarm_volume=255 ;(255) effect_volume=255 ;(255) mic_volume=255 ;(255) user_volume=175 ;(255) ;welcome="Broem" [sound.announcer] gps_signal_lost=1 gps_disconnected=1 [sound.speech] delay_msec_between_speeches=600 ;(0) advanced_guidance_ding=1 ;(0) ;######################################################################## ;XXXXX_sound="!proxi" ;XXXXX_tonal_type=none ;speech alert none ;XXXXX_speech="Something to say" ;XXXXX_spoken_type=none ;speech alert none ;overspeed ;section_beep ;section_start ;section_end ;approach_beep ;activated ;Primo Speedcam Types ;0 - normal speedcam ;1 - mobile cam ;2 - Traffic Light with Speed check Camera ;3 - avarage speed trap ;4 - Redlight only ;5 - ;6 - ;7 - ;8 - ;9 - ;10 - ;11 - ;12 - ;13 - ;see also [warning] [speedcam_category:0] activated_spoken_type=speech activated_speech="U nadert Flitser!" approach_beep_spoken_type=speech approach_beep_speech="Flitser 0" overspeed_spoken_type=speech overspeed_speech="Te snel. Flitser!" activated_min_speech_repeat_delay=5000 ;msecs? [speedcam_category:1] activated_speech="U nadert Flitser!" approach_beep_spoken_type=speech approach_beep_speech="Flitser 1" overspeed_spoken_type=speech overspeed_speech="Te snel. Flitser!" activated_min_speech_repeat_delay=5000 ;msecs? [speedcam_category:2] activated_speech="U nadert Flitser!" approach_beep_spoken_type=speech approach_beep_speech="Flitser 2" overspeed_spoken_type=speech overspeed_speech="Te snel. Flitser!" activated_min_speech_repeat_delay=5000 ;msecs? [speedcam_category:3] activated_speech="U nadert traject controle!" approach_beep_spoken_type=speech approach_beep_speech="Flitser 3" overspeed_spoken_type=speech overspeed_speech="Te snel. Flitser!" section_start_spoken_type=speech section_start_speech="start traject controle" section_beep_spoken_type=speech section_beep_speech="Te snel. traject controle!" section_end_spoken_type=speech section_end_speech="einde traject controle" activated_min_speech_repeat_delay=5000 ;msecs? [speedcam_category:4] activated_speech="U nadert Stoplicht Flitser!" approach_beep_spoken_type=speech approach_beep_speech="Flitser 4" overspeed_spoken_type=speech overspeed_speech="Te snel. Flitser!" activated_min_speech_repeat_delay=5000 ;msecs? [speedcam_category:10] activated_speech="U nadert Flitser!" approach_beep_spoken_type=speech approach_beep_speech="Flitser 10" overspeed_spoken_type=speech overspeed_speech="Te snel. Flitser!" activated_min_speech_repeat_delay=5000 ;msecs? [speedcam_category:11] activated_speech="U nadert Stoplicht Flitser!" approach_beep_spoken_type=speech approach_beep_speech="Flitser 11" overspeed_spoken_type=speech overspeed_speech="Te snel. Flitser!" activated_min_speech_repeat_delay=5000 ;msecs? [speedcam_category:15] activated_speech="U nadert betaalde zone!" approach_beep_spoken_type=speech approach_beep_speech="Betaalde zone" activated_min_speech_repeat_delay=5000 ;msecs? [speedcam_category:31] activated_speech="U nadert gevaarlijk punt!" approach_beep_spoken_type=speech approach_beep_speech="Gevaarlijk punt!" activated_min_speech_repeat_delay=5000 ;msecs? ;######################################################################## [strapon] discard_state_timeout=60000 ;(30000) 60 secs max_position_distance=800 ;(300) min_gps_precision=50 ;(0) gps.accuracy max_gps_precision=100 ;(0) gps.accuracy ;min_discard_prob= 0.0 ;(????) min_distance_for_move_at_low_speed=50 ;(20) max_speed_for_stop=2 ;(0) min_distance_for_switch_off_stopping=50 ;(100) min_speed_for_release_stopping_off=5 ;(10) offroad_handling=1 ;(0) debug_offroad_alert=0 ;(0) disable_heading=0 ;(0) ;######################################################################## [tmc] enable_flow_icons=1 ;(0) need $traffic_speed.spr enable_flow_events=1 ;(0) haven't seen any flowing flow_stripe_blinking_time=1000 ;(0) in msecs show_all_provider_list=1 ;(0) near_provider_distance_km=100 ;(30) auto_band_search_up=0 ;(0) auto_tuning=1 ;use_new_standard=1 ignore_sid=1 ;######################################################################## [traffic.settings] load_default_traffic_settings=1 ;config/tmcsettings.ini traffic_enabled=1 use_extra_setting_for_flow_events=1 use_speed_color_codes=1 ;flow_speed_coloring=4 ;(4) always_use_flow_coloring=1 ;(0) announce_recalc_on_auto_only=1 ;(0) detour_acceptance_mode=2 detour_spare_time_threshold=900 ; detour if 15 minutes lost due to traffic ;######################################################################## [tripcomputer] num_of_trips=3 ;######################################################################## [truck] vtr=519 ;default truck VTR max_restriction_level=0 ;######################################################################## [tts] priority="HIGH" ; CRITICAL VERY_HIGH HIGH NORMAL LOW VERY_LOW tts_buffer=32786 ;(10240=10k) 32786=32k automatic_direction_conversion=1 ;(1) announce_exit_directions=0 ;(0) 1 says first place on exit sign, 2 say road name skip_exit_numbers=0 ;(0) 1 or 2? skip_road_numbers=0 ;(0) 1 or 2 always_say_road_names=2 ;(0) 1 or 2 or 3 (Rijksweg A4) ;######################################################################## [warning] approach_beep_distances="8,16,24" ;("8,16,24") warn_distances="120:1000,100:800,80:500,50:300" ;("110:1000,80:800,60:500,40:300") speedcam_enabled=1 ;(0) speedcam_visualtype=1 ;(1) default visual type 0 or 1 speedcam_soundtype=1 ;(1) 1=warn if overspeed 2=approach speedcam_soundtype_4=2 ; () speedcam_visualtype_4=1 ;() speedcam_warning=1 ;(0) ;speedcam_check_frc=1 speedcam_max_lookahead=1200 ;(1000) speedwarn_alt_builtup_based=1 ;(0) speedwarn_alt_limit=1 ;(0) speedwarn_alt_tolerance=110 ;(100) speedwarn_alt_toltype=1 ;(0) alternative tolerance type speedwarn_tolerance=110 ;(100) speedwarn_toltype=1 ;(0) absolute or percentage speak_tts_only=0 ;(1) ;speedcam sounds (tts and non tts] are in data.zip:project_config\igo9.ini [speedcam_category:X] ;######################################################################## [warning.driveralert.settings] max_display_count=3 ;(3) show_timeout=10 ;(3) show_vehicle_pictograms=1 ;(1) preactivate_distance=100 ;(100) ;truck_policy=0 ;(0) ;show_cat= ;warn_cat= warn_method=2 ;(2) ;########################################################################
redjewel2ss Posted February 27, 2012 Posted February 27, 2012 I've tried a few different combos with sysconfig and saved them boths ways as mentioned above but everytime I reboot on the OGM-1 I can't find any changes. It still looks the same..... What am I doing wrong? i'm getting the same thing. the only thing i tweaked was the auto-run after 3 seconds. but i wait awhile, then press my NAV or DEST buttons and the Run Navigation screen pops up, and then it auto-runs. iGo takes awhile to load as well but the software is 100x better than Navmate for sure!
CPD1670 Posted March 1, 2012 Posted March 1, 2012 Is the altitude working with these mods? The Mod I posted on page one seems to have fixed the altitude problem.
parshal Posted March 1, 2012 Author Posted March 1, 2012 The Mod I posted on page one seems to have fixed the altitude problem. I can't see anything specific for altitude. Can you show me that again?
CPD1670 Posted March 1, 2012 Posted March 1, 2012 Here's Mine: [device] sdcard_name="SDMEM" type="Audiovox_USA_OE" [2d] show_planned_route_arrows="1" [3D] use_all_building_textures="1" planned_route_visible_behind_mountains="1" [interface] show_musicplayer="1" show_exit="1" extra_settings="1" show_gps_config="1" start_navigation_time="3" [map] fake2d_max_zoomlevel="3000" 3d_zfar_horizon_ratio="200" roadblockicon_maxzoom="2000" 3d_max_tiltlevel="9000" 3d_max_zoomlevel="500" 3d_max_zfar="500" shapes_in_2d="1" poi_labels="1" [navigation] show_current_city="1" [screen] daymode_until_no_time_sync="1" ; --------------------------------------------------------------------- ; | Creado con SysConfigurator 1.2.1 por Turonet para SystemPPC. | ; | www.systemppc.com - www.adslusera.com | ; --------------------------------------------------------------------- This added the ability to skip Navigation Page and go directly to the map, added Compass, Music player, Additional cockpit themes, ect... Not sure what exactly fixed the problem, but since making these changes I have not seen an issue with altitude since.
parshal Posted March 1, 2012 Author Posted March 1, 2012 What does the music player do? Where does it add the compass? I also wonder what the additional cockpit themes are.
boxer9931 Posted March 1, 2012 Posted March 1, 2012 Unless I add [gps] set_messages="0" to mine it doesn't seem to work. With this it updates every 2 to 3 seconds.
parshal Posted March 5, 2012 Author Posted March 5, 2012 Unless I add [gps] set_messages="0" to mine it doesn't seem to work. With this it updates every 2 to 3 seconds. What doesn't work if you don't add that? I updated my sys.txt with sysconfig which ended up looking very similar to CPD's. I don't see any change other than the fact that igo never runs. I have to hit run each time as if it's looking for the boot file even though it defaults to the correct location and the box is checked to autorun.
holty Posted March 5, 2012 Posted March 5, 2012 What does the music player do? Where does it add the compass? I also wonder what the additional cockpit themes are. Unless I add [gps] set_messages="0" to mine it doesn't seem to work. With this it updates every 2 to 3 seconds. Unless I add [gps] set_messages="0" to mine it doesn't seem to work. With this it updates every 2 to 3 seconds. What doesn't work if you don't add that? I updated my sys.txt with sysconfig which ended up looking very similar to CPD's. I don't see any change other than the fact that igo never runs. I have to hit run each time as if it's looking for the boot file even though it defaults to the correct location and the box is checked to autorun.
08G8V8 Posted March 5, 2012 Posted March 5, 2012 I see no difference in the operation of the iGO no matter what changes I make with the system configurator. I have even copied the exact sys.text file from CPD1670 above and still no difference. I am at a loss. I really just want the navigation loaded automatically so it is available when I want it. I guess that will be part of my routine when getting in the truck to just hit the NAV button to get it loaded.
ap0352 Posted March 5, 2012 Posted March 5, 2012 I see no difference in the operation of the iGO no matter what changes I make with the system configurator. I have even copied the exact sys.text file from CPD1670 above and still no difference. I am at a loss. I really just want the navigation loaded automatically so it is available when I want it. I guess that will be part of my routine when getting in the truck to just hit the NAV button to get it loaded. I'm in the same boat. I cannot find any changes on anything with any sys file I create and save. I don't know what the deal is...
parshal Posted March 11, 2012 Author Posted March 11, 2012 After screwing around with the sys.txt file for a while and not getting it to work I dug deeper into the .ini files in the .zip files. I figure the .ini files were overriding anything that was set in the sys.txt. I found a number of the entries that can appear in the sys.txt file in various .ini files. I was able to "fix" the gps altitude that never changed on my unit. I also found a setting that appears to turn off the user agreement when first entering the nav page. Interestingly, I also was able to cause my unit to run out of memory. It popped up a message a few minutes after it was on the nav page telling me it was running out of memory. First, the two files I modified were igo9.ini and Audiovox_USA_OE.ini. Both are located in the data.zip file in the root of the sd card (or wherever you have igo installed). In the igo9.ini, mine has the following: [gps] delay_after_pos_valid=1000 delay_after_pos_invalid=1 ;added next line 3.11.2012 -bt set_messages="0" [interface] skin="ui_igo9" newalignment=1 bilang_city=1 enable_stateanim=1 builtin_themes="SKIN~Default - night|skin_night,SKIN~Picto|default_picto,SKIN~Picto Night|default_picto_night" resultsinqueryorder=1 use_autohint=0 font_quality="light" show_tutorial=1 use_dual_names=0 theme_night="skin_night" ;added next two lines 3.11.2012 -bt recalc_voice="0" ;start_navigation_time="3" Only the lines after my comment were modified. Everything else was already there. After I got the memory error I commented out the start_navigation_time="3" line and I haven't gotten the error again. Changing that line didn't seem to do anything for me anyway. I really want the unit to go straight to the map rather than make me choose map or navigate but I haven't figured that one out yet. In the Audiovox file, I have the following: [interface] shutdown_time=0 maxzoom2d=6000000 show_exit=0 exit_on_sd_remove=1 ;next line modified 3.11.2012 -bt was drive_carefully=1 drive_carefully=0 default_anim_off=0 After making the above change I no longer get the user agreement page. Interestingly, even if I put it back to it's original setting I still don't get the page. It seems I've removed that requirement altogether.
