Never driven a truck with 3.08s. Is it really sluggish? It would be the equivalent of 3.73's in my 02 with 35's
Sent while in 'Murica...
It's not bad. Still plenty good for around town and as I just learned decent enough for desert blasting.
Reason I steered away is because they are only rated to tow 6600 lbs which is good enough for me but i know towing with the setup I just explained (35's and 3.73's) it felt like the truck was barely moving with a 5000 lb. load behind it. I wish I had 3.73's in this new '14, supposedly rated to tow like almost 12k pounds with them
Almost hit a deer. Got an awesome video of it. Posted on FB
Ryan
Ryan
I saw that, it was nuts!
Washed it since I have a 3 day weekend and no rain/snow in the outlook
Ryan
Ryan
Going to rain here tonight and tomorrow. Mine is going in the garage tonight.
I'm fat and lazy. I dont wash my own truck. I make my ex do it.
Managed to break the car wash the first time I took this truck through it [emoji23]
Maybe because it knew you were doin your ol' truck wrong by letting those things slap and scratch up your new ride!
Brand new truck: time to install a tool box in the bed. Did that after work today.
Hey somebody stole half of your toolbox.
WTF are you thinking? Hand wash 2 bucket method!
Ryan
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
