Well so much for an easy fuel pump swap in that '05 Mustang ... :banghead:
Ordered a fuel pump and it got here today. Yanked the seat up, and got the old pump out. Figured this would be an easy half-hour job. NOPE! Not in the 21st century ...
So that side of the tank was full to the brim - gas peeing everywhere once I removed the pump. Smelled like varnish - totally stale, so I siphoned the rest out (was going to anyway to make sure tank was clean). Check out the tank after it's empty, and it's a MESS of rust. Screen stuck to the bottom of the tank. It's so bad I don't think I can clean it, so I start looking for another tank. Had no idea there was a SECOND fuel pump and sender on the right side! WTF - can't anyone build anything normal today?? So now this went from a $300 pump job for the neighbor, to probably close to a grand by the time I source a tank and secondary pump. Guess she's gonna be here a while ...
I'd have junked it and bought a real '65-'72 Mustang ... but to each his own.
Stuck the camera in the tank for this shot, straight down:
Edited by Jsdirt
I ordered a full MOOG front end today! Just over $500, and should all be here by Monday.
What does that consist of? Will you diy? That's my goal for the truck as well, but while I'm doing that I should also do the power steering.... the list could be infinite.
It was long overdue but I finally wired up the replacement for the melted left side license plate light socket. I had bought cheap phillips bulbs that were really yellow but a new neighbor who happens to have an aftermarket lighting business gave me 3 led bulbs, props to him!
The right side bulb was burnt out but now both sides light up perfectly for the first time in who knows how many years.
He then offered me a low and high beam HID setup (bulbs, ballasts, etc) for $99, although from my basic knowledge I'm hesitant to put that into the stock halogen housing. Thoughts?
I'm looking at doing the same, only getting new uppers and lowers with fresh bushings and all ready to go. Cognito steering support kit and a steering stabilizer would bring it to around 10 bills.
I had to do Moog lowers at 38k, then the uppers at 50k, along with hub bearings. Rack ends & swaybar end links are still OEM. Could use new end links though.
Nice having ball joints I can put grease into. They'll probably outlast the rest of the truck. :lol:
Cognito support kit was the best steering upgrade I had done to my 02
(2) Upper control arms (new bushings and ball joints)
(2) Lower Ball joints
(2) Inner Tie rod ends
(2) Outer Tie rod ends
(1) Pitman Arm
(1) Idler Arm
(1) Idler Arm Bracket Assembly.
Yeah, I'm doing it all myself. I almost pulled the trigger on the lower control arms, but I don't want to mess with the torsion bars.....those things scare me!
(1) Pitman Arm
(1) Idler Arm
They ain't hard, just getting them back to stock height sucks lol
Does a rwd truck skip the pitman and idler arm parts?
If you don't have a steering gear then yes on the pitman arm, I'd imagine your truck doesn't have an idler arm either. You can always go to the moog website and they have everything you need
Anything with rack and pinion steering has no idler/pitman. For our trucks, that's '07 and up half tons.
Edited by Jsdirt
Lately I've been hauling a little of this, a little of that, & whatever else. Today the Beast earned a quick bath at the base carwash. Got a few layers of dirt, grit, & pollen off.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
