I'll have to try that next time. I've been using Mothers for years now, but I don't particularly care for it all that much. It works, but it takes a lot of polishing to get the wheels clean.
So does the eagle one stuff, I have both and the mothers does great. Get the meguirs buffing cone, attaches to a drill, makes it a lot easier and faster. If you clean your wheels at least weekly with the correct type of wheel cleaner the shine lasts longer and isn't so hard the next go round
Sent from my SM-N920V using Tapatalk
Today I did nothing in the shop but answer phone calls. Next few days are very promising both in clusters and FOBs. HVAC haven't been in demand quite yet, maybe I'm asking too much. What do you guys think is a fair price to redo the background bulbs to LED in one of these? Is 40USd (50$ Cdn ) too much? There's $12 USd ( 15$Cdn ) in LEDs. It takes me well into 2 hours to do one unit. As I get used to it it may take less time but for now that's where I'm at.
Edited by Coby7
I have a powerball, but I've never really loved how it works. Maybe the cone works better?
I adjusted the driver torsion arm since my passenger side sat about a half inch higher.
I also armor all most (if not all) of my weatherstripping. I will use dielectric sometimes and other times armor all- they seem to work best by taking turns.
I wiped down my tailgate (bedside) after cleaning my weedeater on it.
I put graphite all over my key and door locks.
Checked the oil level (a hair below full).
Torqued all of my wheels. I had initially torqued them a year or two ago with a torque wrench, but was low of the called for 150 ft-lbs because of antiseize. But I gave each a good tug and while I had the center caps off I wiped the hubs/wheel bearing area with some grease.
Took out my subwoofer and left it out when I was getting the factory jack from behind the passenger seat.
Put a few drops of 3-in-1 on the passenger seat rails/rivets/bearings behind the seat.
Wiped my clutch pushrod area from when I applied it yesterday as I am try to smooth it out and reduce the noise. Just trying to 'work it in' since there was already plenty on there.
Hit my parking brake cables with penetrant on the exterior and lube in the interior.
If that's the price, I'll send you mine
Got freaked out. Wife got home from work. My truck was in the street she calls me over and says your truck is all scratched up. Oh its on. I then look and a spider had made a web that looked like a long scratch on my front fender. Heart returned from my feet and all is good.
We recently bought a travel trailer and have been getting it ready for its maiden voyage. Yesterday I put the camping box in the bed of the truck and cut some chain to length to be able to lock the box in the bed of the truck. Nothing too exciting, but that's it. LOL
What colour would you like lol
I want a cool white. Same for all the other light up pieces in my interior. Weather is too unpredictable right now to rip it out and send it
I can't remember how long it took when I did SG Lou's
But not much more than a week before he had it back.
Customs and shipping
Just write on declaration "Return for warranty repair" and it zips right through. He sent it via USPS and I received it 3 days later, repaired and shipped it out that same morning and he received 4 days later.
Compared fuel economy. Kinda shocked how close they were. Pulling Identical trailers.
750 miles.
2010 GMC LMM with 817k filled 70.89 gallons
2013 Chevy LML with 430k filled 70.95 gallons
I would have figured the LMM would do better not having the shitty DEF, only the DPF.
The 2013 looks like my 2012, only mine is a long bed.
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
    • It was all part of the tiny bit of fuel savings it goes towards what was mandated by the government. Much like cylinder deactivation. That was relaxed by the recent administration. All that doesn’t help the individual buyer. But as a whole helps the manufacturer to try to reach the previous ridiculous past mileage per gallon mandate. So yes it was mandated and added cost to the vehicle.
