Sleeping in Truck
Rjbeck77
Going camping in a couple weeks, and we are between campers. Does anyone have success in sleeping comfortably in their truck?
I have laid the rear seats down in our Tahoe before, but I won't be able to take it this time.
I have a crew cab.
Any suggestions would be great.
it can be done, fold the rear seats down and get a sleeping bad. depending on the temp you might want to keep the truck running.
Dont know where you are, but its supposed to be in the 60s around here this weekend. So, if its warm enough, throw an air mattress in the bed and pitch a tarp above the truck. Ive camped in my truck once It wasnt bad, but I have a camper shell.
Huh.....how tall are you? and you said WE?
I'm 6'4" and no way I'd sleep in the cab. I would throw a tarp over the bed, foam pad/air mattress and stretch out.
I barely fit in the back of my Tahoe, no way in my CC.
They do make tents for the bed of pickups: http://www.target.co...ci_sku=13107489
I have slept in my ext cab before, and I used to sleep on the bench seat in my 1990. I wouldn't hesitate to sleep under my bedcover either. I'm 6'. I may get a topper for camping eventually.
  • 1 month later...
anything can be done... I am 6' 2" 230 and I slept in the cab of a regular cab s-10 with my feet hanging out the window. There was a lot of Jack Daniels involved though
The joys of being short. If I had/wanted to I could just fold down the rear seats and be fine. I used to take naps every now and then in my '73 regular cab spread across the two Lincoln seats and the oddball wood center glove box/console thing.
memorial weekend and fourth of july weekend we meetup in the VOUCHER LINE with hundreds even close to a thousand trucks lined up bumper to bumper.. i had to try to sleep in my drivers seat and a friend in the passenger seat.. it suuuuucked didnt sleep at all and sat in line for 14 hours.. eventually found our other friends in line and sat around drinking beer.. ill definitely be taking the subs out this year for that..
  • 4 months later...
hi everyone
when you buy vehicle care about some things which is helpful for sleeping in trucks comfortable .Be sure to get a shell that is raised up above the top of the cab. It’s not so much about the bedroom inside, it’s about the height of the door. It’s much easier to get in and out as well as fitting in road bikes easily, etc.it makes sleeping comfortable.
Here's what my friends did a few weeks ago....somehow they stayed dry too!! This was with a 5'8" box
  • 2 years later...
[emoji54] on dang! That's must be tight.
Sleep on the back seat all the time. Thought of removing the set and building a bed to gain more space, back of the seat takes up almost a foot till back of cab.
Carry a -40 sleeping bag. Slept in temps ranging from -30 to 80 without engine running. When it gets cold covering windows holds in heat. I sleep most confortablly in the 30s.
You should never get in a habit of sleeping in the drivers seat. That is the stay awake at all times seat.
They are both far too happy looking to be sleeping that close to another guy.......Pictures speak 1,000 words!
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
