what is the best NON HID bulb for these trucks? I want it as close to blue and white as you can get. Does anybody have one they recomend?
There's a thread (as linked above) that has people that have been seeking this "nervanna" for months. Most are seeking a fix for the narrow beam caused by the OEM projector with a simple bulb change and they want mega lumens as well. To top it off, they want 5000 kelvin color. And most of them don't want to spend any money either. Good luck with all that.
Look into the LED bulb thread if you need whiter color. There's just too many out there to keep track of which is better.
Edited by spurshot
I havent seen how they are physically wired up, I cant say. But i would think that they are not as they are not connected in parallel. Relay is a electrical switch to bridge a connection.
Someone used a 55w bulb halogen in the stock conmector, so why would 55w HIDs be more of a problem? Needless to say, HIDs are more effecient, so it draws the 55w at first and the voltage required to run drops after. Take loss in efficiency in the ballasts, take 10-15%, a 5-7 watt difference on top
The use of a relay to isolate the vehicle circuit is based not only on the starting amperage spike, but also to prevent the line loss of the vehicle systems from impacting the ballast function. As well, the ballast's input voltage does not drop. Input voltage will match the charging system, so ~12v when the engine is off and ~13.5v when idling. Remember that voltage, amperage and wattage are all related and easily calculated based on one another.
On a factory Sierra with the HIR bulbs, the burning filament does not care what voltage is supplied to it. The electricity flows across and the resistance creates the heat and light intensity that is reflected off the bowl and out through the projector optics. When the engine is not running, the 12v is supplied from the battery at say 55w equates to roughly 4.5a of current draw, line loss notwithstanding.
HID ballasts are much more temperamental however. The harness comes into play mostly because of how vehicles operate based on the ignition. You insert your key and turn to on, which powers the electrical system. This sends 12v to the lights, firing the ballasts and igniting the bulbs. Then you turn the key further, starting the engine. The high amperage draw from the starter motor can momentarily lower overall system voltage under the threshold that the ballasts need to sustain the arc across the capsule and the HIDs go out. You then need to powercycle the HID system in order to get them to refire. The use of a relay kit ensures that power is maintained throughout vehicle operations, as the relay will remain latched through the starting process, keeping a constant power to the ballasts.
The second point is the influx at ignition. A 35w ballast at 12v will use just under 3 amps of current to maintain the arc. Ignition however requires substantially more. Between the two ballasts you can call for 20 or more amps depending on conditions and line loss, so using the factory electrical system isn't reccomended. The TRS 30a HD relay harness as perfect for the job.
I installed my gmc specific kit tonight on my 2015 duramax from trs and when the lights turn on now, they turn on for a split second then go back off. The fogs work fine as they are supposed to with low beams. I tried reinstalling my factory headlights, and they do the exact same thing. They light for about half a second then go out. Any ideas?
What is the name on the kit? What is the rating of the ballasts? what is your wiring sequences?
It is a morimoto kit from theretrofitsource.com it is a gmc sierra specific kit. The ballast are 35watt. It hooks into the drivers side factory bulb harness, has 1 wire direct to battery positive and one wire direct to battery negative. Both ballast have a ground that is hooked to bolts under hood (chassis ground) there is a resistor (I think thats what it is) in line between each ballast and bulb.
The resistor or capacitor goes between the factory connector and the relay harness, so if you have a single side connection you would only have one of them on your system. Sounds like you have them between the harness and the ballasts and that would be your problem. If it also has issue when you go back to stock then I don't know what causes this issue.
He's referring to the inline ignitor. Unless you cut the AMP connections between the bulb and ballast, there's no place to rig in the capacitor link.
If your factory lights are doing it as well, there is an issue before the headlight harness. Check for blown fuses or a bad body ground.
Forgot the new one has an external ignitor. They released them like 2 weeks after I got mine. If it is doing it stock also, then put everything back to stock and let the dealer fix the issue, unless you easily find a loose ground or other simple fix.
Well the dealer said they dont know what's wrong, but check engine light on and remote start were out this morning. Should get it back tomorrow. Something I did when hooking up the hids freaked my truck out
If you hooked the relays directly to the battery posts and only factory wire you connected to was the headlight lead. My guess would be the issue was not caused by you. Correlation does not mean causation, could just be the timing of it freaking out making you think it was you.
My filter capacitor is between the headlight power plug and the relay. I believe it's intended to prevent the relay from seeing a frequency or fluctuation.
Spurshot you are right. The TRS ballest they just released have external igniters that go between the relay harness and the ballast, I think. Could be after the balast, but either way it is now another new thing to confuse some people.
That's the correct spot and reasoning, the OP had said "Both ballast have a ground that is hooked to bolts under hood (chassis ground) there is a resistor (I think thats what it is) in line between each ballast and bulb." but he's simply seeing the large block coming off the ballast - which is the ignitor.
The external ignitor isn't new, actually. Older ballasts were almost an inch thick, incorporating the ignitor into the ballast housing.
New ballasts are only slim because they simply have the circuit board and electrical components inside, with the ignitor inline to the bulb.
l_avnmnew-55w-super-thin-hid-lamp-ballas
No it's not new, but it is the change in the new TRS ballasts. Mine are from about 4 weeks ago and have no external igniters and OPs are newer with external because the company changed their product line.
I didn't see that he posted whether he had the Morimotos or not but you're correct - they recently implemented the new modular system allowing the ballast to switch between AMP and D2S connections with the inline ignitor.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
