Anyone having cutoff issues with the beam itself? After I installed the projectors, it's like the beam is slightly offset in the housing. Maybe a side to side issue.
If you have plug and play hids now and aren't impressed go with a full on retrofit such as the fxr
I first put in the 4300k morimoto elite kit and although it was an upgrade over stock, I did the retrofit a year later. Wished I had done it right off the bat.
I would recommend morimoto, have had their kits in my past few trucks and everything has held up good for the most part and any issues have been replaced hassle free
did you put a bi-xenon projector kit in or what projectors would you recommend?
I would recommended the fxr projectors. They are bi-xenon. I used the 2.5" projectors cause I had a set lying around but 3" is a better fit for the Sierra and probably Silverado
Fast headlights has a bracket to mount the fxrs easily too
The fxr is the bigger badder one vs the stock projector in the pic
ok cool. would i be better off getting just the adapter plate from fast headlights and getting the rest from TRS or getting the full retrofit kit from fast headlights?
ok this may be a dumb question, but when retroing a silverado, will you lose function of the factory high beam?
yes you lose factory highs, but you gain the highs back with the fxr kit. They have butterfly that switches between each other
Think fast has a package deal with fxr kit and bracket. Thought maybe there was a group buy going on here too, but check in with him and he can let you know
No you don't. Silverados have separate high beam bulbs.
ok that is why i was asking, i wasn't sure since it had a seperate light for the high beam if it would affect it. thanks!
I'm sorry, you are correct. You still have them. Hooking them up is your choice. I prefer to use the projectors with the hids as they are already warm.
If you retrofit a bixenon projector, you can add high beam splitters. Just an adaptor that will let the projector go into the high beam and have your actual high beams on at the same time.
Learn something new everyday. I had a Mr taillight kit on my Colorado that would maintain highs, lows, and fogs. Never took the time to hook up the old high beams. For one, different colors, but was sure just some new wiring would do it. I was just happy enough with the retrofit in general
Check out the 4hi and 6hi mods for these trucks. Allows the high beams to stay on with lows. I added a resistor that allows my cargo lights to come on with reverse lights for extra lighting, and my bed lights I added come on also at night. Walk out of store at night, hit unlock on my fob and my whole bed and cargo LED's come on.
That is incorrect. Sikverados use a compelty different bulb for the high beam so you don't lose your high beam function. The shutter is found on the Sierras, not Silverados.
Thanks but we have already clarified this. You dont actually lose the high beams. The bulbs are still there. Me personally didnt hook the stock high beams up when I did a FXR retrofit. The FXR kit DOES have a shutter, and since my hids are already warmed up ready to go, I hooked up my high beams from there. You still can use your high beams but I just left them disconnected.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
