My 2015 Sierra. G5-R, CBI, Hylux 35watt. When you attach the bracket to the headlight there is a little play with the screw holes so my drivers side seems like it has to be rotated counter clockwise a little bit. Over all the light output is amazing. CBI's are a little warmer than my morimoto fogs, CBB's would probably match a little better.
25ft from garage door
Edited by BlackZ71SLT
56 minutes ago, BlackZ71SLT said:
40ft from garage door
Looks great. How long have you been running these and were you happy with the seller?
Hey guys
For some reason the discount code at Fastheadlights wasn't working. I fixed it and it should be good to go now. It can be used on HID kits and Retrofit kits. Just a note, the FXR projector is being discontinued and will no longer be offered. The D2S 5.0 essentially has made it obsolete. Farewell FXR, it's been real. Lol.
Discount code is gm_forum10%
Enjoy
Sent from my SM-N950U using Tapatalk
  • Thanks 1
https://www.fastheadlights.com/product-p/buy_hid_kit.htm
This kit is much better than the Morimoto Elite kit. The Morimot kit requires a relay harness and to be honest the 35 watt igniter/ballast from Morimoto have been very unreliable. I stopped selling the Morimoto Elite system because I was going crazy with troubleshooting and processing warranty claims. The Hylux ballast is much simpler and has been far more reliable. Its asplug n play as it gets.
You can also upgrade your fog lights to the Morimoto XBLED fog lights to improve output and beam distribution. Those are listed on the site above as well. They are also plug n play.
If I already have the HID kit from TRS, can I buy just the Hylux ballasts to replace my morimoto ballasts? I’ve have them kit installed for about a year and a half and have went through 3 ballasts so far and one bulb. Plus for the price of your kit, I can get a whole new kit for the price of the parts from TRS.
Yes you can. The Morimoto bulbs work great with the Hylux. No need for the relay harness either.
For the HID kit shown on your website, are there any install videos available or an instruction sheet?  Curious how this kit is installed.  Thanks.
Just ordered the retrofit kit from Fast Headlights for my 14 LT. Also picked up a set of LT headlights to retrofit off of a buddy for cheap so I can take my time putting this all together. I'll make sure to take lots of pictures and post them when I'm done.
  • 3 weeks later...
So started this project the other day and I said I would document it. Below are the headlights I got off a friend for a good deal.
Here is the kit from Fast Headlights
First things first, remove the trim. Used a head gun and flat head to pry them off. Had to be careful about the tabs
A couple nights later I had the time to crack them open. I did 270°F for 15 minutes at first, then put them back in at 5 minute intervals after that.
All in all it took me roughly 2 hours to split the headlights. The first took me about 1.25hrs because I wanted to make sure I wouldn't mess them up. Second set went much quicker.
That's all for right now. Next step is to clean out as much of the sealant as I can and then mount the projectors and test them.
You got thr hardest part out of the way. Just be real tedious with cleaning the channel. Keep tossing it in and out of the oven to keep the permaseal hot and it will crumble. When we clean them out we get it all out. Right down to the bare plastic channel.
Thank you for the advice. Yeah this stuff is really stuck in there without some heat.
Another question I do have: when inserting the projector into the bulb hole in the housing, there is a lip on the back side of the housing that makes it almost impossible to screw on the projector nut. Do you guys usually trim this off to be able to tighten the nut?
Yes, you need to grind it down flush so you can get the nut screwed on. Dont forget to grind down enough so you can also get the bulb holder on too.
I just got a kit from fastheadlights, and when I got it all back together the lights wouldnt light. I feel like since neither side worked I must have done something wrong, but, its seems pretty idiot proof, plugs only go in one way for everything.
I've read some wires are sometimes backwards, what do i need to check? Any suggestions?
Hey Ben
It is definitely the wires being reversed. Flip thr plug over on the ballast and if it lights up you got thr issue identified. If that doesnt work then be sure that the plugs inside the headlights are fully seated. A bad connection will result in no light either.
Email me at [email protected] if you have any other trouble or need a phone call to help.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
