What about 305/55R20 trail grapplers on fuel maverick 20x9 with +01 offset on 2.5" RC level, has anyone seen that set up? I know the trial grapplers measurements are a little bit bigger than regular 305/55 measurements but if anyone has info or knows if those will work or rub let me know. I'm fine if it rubs on the inner fender plastic felt piece because that can always be trimmed i just don't want to rub on the sway bar or something I can't trim
Anyone had any ball joint issues with the 2.5 inch RC? I just ordered it and now I'm thinking maybe i should have gotten the 2" level instead. I do want to run 33s though, so i guess I'll stick with the 2.5
I want to do a leveling kit on my 4x2 but I definitely don't want the "offroad" look...just a nice level stance (maybe a tad lower in the front). I personally hate the stock LS2 tires on my 20s, will the factory 275/55/20 look odd once the level kit is installed? I really don't want a wider tire, but a more aggressive tread pattern that still rides smooth would be great. I wish my truck came with the Wranglers, I think that's a good looking tire...just didn't know what you guys recommended brand and size wise.
I would suggest a 1.5" spacer if you wanted it just a little higher but not completely level. The 275s should look fine since it's not that drastic of a change, but a 285/55 would look perfect for what you're wanting. Just a tad taller and wider. The only problem is that most tires in that size are full-blown all-terrains (Terra Grappler/Open Country, etc.) and I don't think that's what you're looking for since the Wranglers are far from that.
If you want a nice look without the large aggressive offroad or mud tires.
I have michelin 275/60R20 LTX M/S2 tires & the rough country 2" level and it looks pretty good. I think the michelin LTX A/T2 tires would look good also.
I personally would never intentionally buy goodyear wrangler tires..
Edited by 14LTZZ71
Could you post some pics of those 275/60 michelins you have on? Thanks
Here are the wheels, more pics below of the level.
Edited by 14LTZZ71
2" Rough Country Level with Michelin LTX M/S2
Edited by 14LTZZ71
Just went ahead and ordered 305/55r20 nitto trail grapplers before I can't order them for a while while Nitto is supposively moving/switching factories. they measure 33.39x12.60" if anyone knows what size offset on 20x9 and 20x10 rims would fit let me know. Preferably something that has a little bit of a lip on the rim would be better
You're gonna rub regardless. Probably best to stick around a zero offset it you want minor trimming. JMO
Thanks. Those like nice. How is the ride vs the stock tires you had on?? I know michelins are the best but the sidewall went up 1". Does it feel more heavier or drive any differently?
It feels better than the Goodyear SRA 275/55R20's thats for sure, more tire between the wheel and the ground is always better. I wish I would have got 18" wheels when I bought the truck. I"m not really a fan of the 20" wheels. If you want a slightly more aggressive look get the michelin LTX A/T2, they are great tires also.
Edit: MPG did not change
Edited by 14LTZZ71
You are going to need to stick as close to 0 offset as you can. Mine are a +1 with 33's and no real rub.
I am new to owning a truck, so can someone shed some light on the ball-bearing problem with installing a leveling kit? I hate that the front end dips down, and have been looking into installing one, but want to know what I'm getting into before I dive in.
The problem is when you put too much of a levelling kit in the front, the angle of the suspension is altered enough to wear out the balljoints prematurely… If you stay under 2.5" (I think 2" is enough) you should be ok…
Thanks for the info - I was planning on going with the 2" kit
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
