The kit provided a 2in block which gives it 1in over stock to level the back with the front. Do you think putting stock blocks back on would help? I was going to swap them out but after reading about others have the same issue with no lifts has me thinking it's not the lift
If you pulled out a 1" block and install a 2" block you are only raising 1", would not seem like it could be the problem... But by returning to the 1" would tell the story.
I had a custom shop install a level kit to my 2014 GMC Sierra 2wd, the level was 2.25in or 2.5 I believe. I added 305/55/20 nitto terra grapplers but some have mentioned the front looks higher now , I see it but when I measure its even. Is this an illusion bc the 2014 front ends are big or does it really a look off ? Andhow could it be fixed, adding block to the back?
I like your lean. I left the block out of my back that comes with rc 2.5 and I'm still 1/4 inch higher in rear. I've had a couple 2wd trucks and leveling kits always made them sit a little higher in front because of less weight. If you want to fix yours, just remove factory rear block and replace with larger block.
Edited by Aldila
Rough Country 2.5 Level with stock rear block.
any rubbing?
i just ordered that kit a couple min ago, and im ordering my rims/tires this week.
do you mean you are using the RC 2" block plus the stock block or just the stock 1" block?
Edited by EaZ8
any rubbing?
If he is doing what several others are doing. He means that he is running the 2.5" level/lift up front and did not use the taller rear block that Rough Country sends with the kit. He just left the rear completely stock
That's correct. I left the rear stock.
Well I am smiling ear to ear... Just had the RC level/lift 2.5" kit installed. Here is a pic this morning:
And this is this afternoon:
Now for some taller tires!
Did u install the 2" block in the back too? ?
Hard to say for certain, but it looks like the rear is also higher. But is the block with the kit a 2" block or just 1" ?
I believe the stock block is 1" and the kit replaces that with a 2" block.
Did u replace the stock block with the one that came with the kit?
Yes!
    Brandon 29
    Brandon 29
  • Who's Online   4 Members, 0 Anonymous, 532 Guests (See full list)
