What do you guys consider to be a reasonable price to have my truck leveled by a shop?
Also I was looking on RC site and they only offer 2/2.5" leveling? I thought there were 1 & 1.5" kits available as well, thinking 2"+ would give you the front end being higher than the rear. Or is to get you to buy the blocks for the back to fix that?
Sorry if these questions are common knowledge or sound basic, I'm trying to learn as I go :)
Thanks in advance
I got my leveling kit installed about 10 days ago for $102 and then the alignment for $80. BUT most shops I called asked for $180 for installation plus $100 for an alignment.
I bought the truck used with 20k miles and it was stock height with stock tires. I actually think it rides better - but i think a lot has to do with the new tires vs the factory tires...much smoother ride. Yet at the same time i can tell they are MT tires, kinda hard to explain. They are very quite considering they are a MT tire though - i am very impressed with that. As far as the level is concerned - i can't tell difference in the ride at all, just when i go to get out and its a longer drop to the ground ha ha.
Gas mileage was affected - how much?? 1-1.5 mpg is my guess...they are HEAVY tires compared to stock.
There is a slight rub/contact with sway bar - none on the UCA that i have seen. I try to avoid full lock steering when possible though. I will get pics later today.
Awesome, thanks for the information man. I think that I'm gonna break down and order the level/tires in the next week or so. Ill post some pics once everything is installed.
here is the swaybar rub
no rub on the a-arm that i can tell...
for reference this is my daughters 08 gmc with the same RC 2.5 level and it has the same amount of rub on the swaybar.
it has bf good rich AT 285-70-17.
Thanks in advance
local place wanted i think around $300 to install mine and i would still have to take it to alignment shop myself - so i just installed myself, then took to alignment shop.
if you just want it leveled i would go with the 2" - which just raises the front.
when i did my 2.5 the front sat about 1/2-3/4" higher in the front than the rear...then i added the rear blocks a few days later.
now the rear sit about 1" higher than the front...
Thanks for the replies guys
Im not truck/part savvy enough to do it on my own (well maybe i could watching a video it seemed kinda straight forward) but i dont possess the necessary tools.
A really good friend of mine works for a custom shop, out of curiousity i asked about their pricing and i was in shock. More than anyone has said in here. He said he'd cut me a deal though. But i think their price includes their kits so maybe thats why.
owning a truck is expensive lol geez im used to my car, i bought it and never made a mod besides HIDs
Cant wait to see my final product though
Finally decided to get a leveling kit.. Went with the 2.5" Rough Country Leveling Kit.. Also got it installed today!! So far I really like it, ride is pretty good.. Didn't put the rear block on that came with the kit yet.. Want to see if it will settle a little after I drive it and get an alinement done...
I bought the RC 2.5 kit with the rear blocks online and had my local shop install for $120 that included the alignment. I had new Toyos put on at the same time. It was well worth it to have them do it IMO.
Before
27160BD5-655E-47B7-9F5C-BE5F1B7DF708_zps
After
1FABA1A3-E2FE-437C-BD4D-D5FF0366B69B_zps
Edited by Buellrider
Before
After
Guys,
I'm looking to buy the RC 2.5" front with 3" rear blocks. I've searched and cant find a definitive answer to the tire question. I want to put the widest and tallest tire possible on the stock 20's. Can I go 295/60/20 with no rubbing or contact? If not, what is the absolute biggest tire I can run with zero issues?
Picture of my '15 DC with a 1" front end lift. Still has some rake, but surprisingly, 1" front end height adjustment makes a big difference. Stock 265/65-18 tires/wheels.
Summit Performance. Really simple, just a 1/2" thick billet alum machined spacer and Grade 8 bolts. Bolts that come with it are no longer than the factory bolts. Was able to install without touching the ball joints, all I had to do was put the front end on jackstands, loosen up the sway bar links (do both sides), took a little bit of prying up on the bottom of the shock. I put the bolts in from the bottom (just like the factory bolts) and reassembled with red Loctite on the threads as a safety measure. Have put a thousand miles on the truck since installed, still tight, no signs of movement. From what I could tell, every other level kit that uses a bottom spacer, with the exception of the Rough Country 2" kit, all are made of machined aluminum. 1" level kit only spaces the shock up 1/2", personally, this is limit of how far I'd want to shim up shock above the control arm. I think a 2" lift via a spacer will increase the sheer load on the bolts to a much higher level.
http://summitperformancecnc.com/products/1-front-leveling-lift-kit-2007-chevrolet-avalanche-suburban-1500-gmc-yukon-and-gmc-sierra-1500-2wd4wd-trucks
Edited by GRN69CHV
2.5 rc inch level kit 33 12.50 toyo at2 extremes no rubbing at all. First pic is obviously before much of anything was done to it.
  • Like 4
Looks great! What wheels/offset?
Thanks! Red dirt road thunder rd06 18 offset deep lip
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
