49.99 free shipping on ebay with u bolts
Truck looks sharp!!!
I think i will be getting toyo MTs when i do my lift.... Only on 33s right now with a level.
I need the white handles and mirrors!!!
Sent from my Note 4 on Tapashit
Thanks. I love the Toyos so far, and the white mirrors and handles definitely add a nice finishing touch to these trucks.
2.5 moto fab spacer stock rear blocks on 275/60r20 toyo at2's
FDD7724C-E4C0-4A42-917A-3E705D2EBBF7_zps
424CF2D8-1F90-4F4B-B139-73BD7AD35CE3_zps
Edited by Col 10
Had some 295/60r20 Toyo MT put on my truck this weekend. Zip tied the liner back and no rubbing besides on the sway bar at full lock. I only have a 2.5" Traxda leveling kit on the front.
BBB2E350-B994-4349-A064-87B59E63F165_zps
Looks nice.... can i see a pick from the front or back
So I am contemplating getting some 17x8.5 0 offset Method NVs wrapped in either 285/70r17 BFG KO2 or 295/70r17 Nitto Terra Grap G2s.
I am aware that the 295s might rub but I'm confused on where. Sway bar, liner or metal?
any input would be appreciated!
Will be running a 2.5" RC level as well.
Edited by Boogie651
Toyo says that's a 34.2x11.8 tire. Impressive that you fit that on stockers with a 2.5. I'm real interested in more pictures of the clearances in all the left and right lock position. Also, the actual height and width with them mounted and the truck weight on them.
Awesome truck!
Awesome truck!
Same here....
I have 305 55 20s and they rub.... I can imagine 295/60s.....
Mine is a 33x12.50x20
I'll have to take one. I haven't had the chance to take many pics yet.
Awesome truck!
Well they "fit" with a little help. I had to zip tie the liner back, but the tire gets very close to the plastic piece on the bottom of the fender beside the door. I'll get some pictures of the clearance with the liner pulled back.
Ive got a 2015 GMC sierra All terrain and am running 275/65R20 Nitto Trails with a 2.5"RC level. I rub the fender liner when turning probably 80% of the time. Also rub the sway bar at full lock every time.
I also put 295/60R20 Nitto Trails before this set. The 295 rubs like hell. Rubs on sway bar significantly, rubs on liner, rubs on metal behind liner. For those who say they do not rub, Y'all must be crazy. Truck also looked too small for the tires that big with only a level.
My buddy has a 3.5" RC lift and he is running the 295/60R20 Nitto trails. HE even rubs too, including sway bar and fender liner.
Here's a pic of my 2014 Sierra AT on 275/60R20 KO2's and Bilstein 5100's in the front set on max height. No block in the back.
2016 slt z71 2.5 rc level. I'm running 275/65/20 ko2. The only rubbing I had was full lock to the right on the liner which I zip tied. Now I have zero issues.
Here's some pics a few members asked for
Here's a picture with the wheel being held at full lock. The tire is probably within an 1/8" of the liner but it isn't touching. I'm sure if I flexed the suspension some it would rub.
That's strange that the same size rubbed so bad on your truck. Where did it rub on metal at? I wouldn't recommend the 295/60r20 for somebody that just wants to throw on a big tire and not touch anything. A 295/55r20 would be better for that. I just wanted a little more meat.
Mine are Not to Terra G2s in LT275/65R20 and mine rubbed before a zip tie on each side, but not anymore.
Sent from my SM-N910V using Tapatalk
Mine are 305 55 20s and rub just a little bit on the sway bar i think it is.
Zip tied the liner on the driver sode as well....
    TopBo
    TopBo
  • Who's Online   6 Members, 0 Anonymous, 872 Guests (See full list)
