How do you torque wrench the bolt at 3:14 in this video? It's the nut on the upper control arm with the allen key head. I know you put allen key in and then twist the nut with adjustable wrench--but can you torque that without an allen key in or will it spin?
I'm pretty saavy but I've never touched upper control arms on Chevy.
Soon as my tires come in I am going to install my Motofab 2" level blocks myself since the place I called wanted $200 bucks to do it.
To the guys who have installed this at home already:
Has anyone actually tried it the way they do it in this video? Seems a lot easier but I know that this is a not the exact same set up as our trucks.
Rough country instructions say you have to remove the factory skid plate and disconnect all the connectors for the electric power steering. Is this the way you guys have done it? If so did it make sense why you are disconnecting these electrical connections? Thanks for your responses!
Edited by webhead
I tried doing it the way in the video and it wouldn't work for me (after wasting an hour). I finally said screw it and disconnected the steering link and the upper ball joint. Made it go way faster.
So it was necessary to disconnect all three electrical connections for the power steering?
No, I don't even know what electrical connectors you are talking about.
All I did was disconnect steering link, sway bar, and upper ball joint. That way I could lower the lower arm joint and turn the whole spindle to angle to clear the bolt under the CV joint. Of course I loosens the shock bolts too LOL.
It was way faster and less of headache. I just put everything back and tightened it down. I did have to use some body weight to push upper arm and ball joint down to put the nut on. The Z71 shocks are stiff as heck!
LOL alright, thanks man.
Thank you guys, I am thoroughly enjoying every minute.
So I went with a 2.5" level lift and for tires I went with Toyo Open Country M/T 275/65r20.
Truck looks Great!!!
If you don't mind me asking, how were the Magneride sensors addressed? Or did you just have them removed? Forgive me if you already covered this question but I couldn't seem to find it in your posts.
Thanks,
Lou
Here's some pics a few members asked for
Here's a picture with the wheel being held at full lock. The tire is probably within an 1/8" of the liner but it isn't touching. I'm sure if I flexed the suspension some it would rub.
That's strange that the same size rubbed so bad on your truck. Where did it rub on metal at? I wouldn't recommend the 295/60r20 for somebody that just wants to throw on a big tire and not touch anything. A 295/55r20 would be better for that. I just wanted a little more meat.
ABCMan I think yours is the best looking lift/tire combo I've seen. You can see from my photos that your tires fill the wheel well much better than mine.
For the first 51,500 miles I ran Toyo 275/65R20 (34" tall), then switched to BFG AT/KO2 275/65R20. Since they are the same size, no surprise I had the same results in that I can turn full lock without rubbing, but just barely. Like you, I'm surprised by the poster saying he is rubbing with smaller tires. I think the issue is all level kits are not created equal. My wheel wells measure 40", which is 4" taller than stock in front. I'm guessing the ABCMan's is 1/2 to 1 inch taller, and the guy who said he rubs at full lock probably measures a little lower. So if you all have a moment, please measure your wheel well height and post it so we can all learn, thanks!
Thanks. I'm very happy with the look I ended up with. My local dealer has been putting 295/55r20 Toyos on these trucks with the level I have and they just look to small on these trucks, of course that's just my opinion, but that's why I went with the 295/60r20. I wanted 35s to start with because I had read where people said they didn't rub, but I now see where that isn't the truth.
I'm around 40-1/2" in the front and 40-1/4" in the rear.
Would be interesting to hear measurments from center of wheel to fender as opposed to ground to fender to help everyone get a comparison on actual suspension height not factoring in tire variations. Then we can compare tire sizes against that measurement. Thoughts?
Mine measures 24 1/4 front and 24 3/8 rear. From center of wheel to fender
Edited by Jibroussard
Pro comp 2.25
Bfg ko2 275/60/20
Pro comp 2.25
Bfg ko2 275/60/20
Any rubbing? thx
What is the ride quality like on the bilsteins on the max setting? I'm trying to decide if I should go with them or look at another option. Also, do you think I could fit 275/65/20s on a 2016 AT with a bilstein lift at the max setting?
Pro comp 2.25
Bfg ko2 275/60/20
Pro comp 2.25
Bfg ko2 275/60/20
Any rubbing? thx
No rubbing at all. Definitely could fit a bigger tire
Can someone direct me to a page on this forum (or elsewhere) that will clearly explain what a 1.5 inch level generated by a bottom of the shock spacer will do to my suspension? I want to raise up the front of my truck for appearance while maintaining a small rake. I want to know if I lose any suspension travel or negatively alter anything else. The Bilstein shocks make sense but the installed cost is too much for me to justify at this time. Thanks!
I had Bilstein 5100's installed for a very reasonable price. I ordered the shocks online and had them shipped free to my door in 3 days from Richmond, BC. The shocks were $150 each. Install and Alignment was another $300 so my all in cost to level my truck was $600 including alignment. I know a guy who had a Readylift 2.25" Level installed at the dealer near me for $1100. So Bilsteins aren't really more expensive to do.
    • Very true.   However.  GM did give those trucks with the single speed case Terrain Mode.  Terrain Mode mimics 4LO minus the gear reduction and torque capability.  It uses the ABS/braking system to perform the operation.  It also gives these one pedal driving (sort of) when in Terrain Mode via the active brake during throttle lift.     Does it have its limitations over a true 2 speed case?  Sure.  But it works.
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
