It's not that bad..... Just a tiny but of rubbing.
Sent from my Note 4 on Tapashit
Txjose, what tires and leveling kit are you running?
Generic 2" level i think its a pro comp
Tires are Mastercraft Courser MXTs
Just got my wheels on today.
Mayhem Warrior 18x9 18mm offset with LT275/70R18
  • Like 4
I'm wanting to put a 275 65r20 on the stock chevy 20s with a 2.5 in on the front which will bring my front to 39 in on a stock 275 55r20, is anyone running a 275 65r20 toyo open country mt with no rubbing or triming?
My 2016 All Terrain 6.2. 2.25" level with 285/55r20 toyo at2 on oem all Terrain wheels. I love it.attachicon.gifDSC_0039.JPGattachicon.gifDSC_0038.JPG
Sent from my E6853 using Tapatalk
Any rubbing? Just got the 295 and they are rubbing the sway bar
Nope not with 285. 295 are a bit wider that's likely why their rubbing.
Just purchased a 2015 silverado LS. Same as photo except I have mud gaurds.
I plan on running a 1.5" front motofab level. With this set up can I run 275/60/20 ko2s?
My buddy has a sierra with 2" front level and running 275/65/20 with no rub.
Just thought I'd check before I purchase?
I think you should be fine. My girls truck is leveled 2" with that tire and size and she has no rub but 1.5" im not sure.
Just leveled nicely with Pro Comp ZX2108 lift struts. They are designed for 2.75" lift. Thanks to some local guys at Socal suspension in El Cajon. In and out with alignment.
Next are 17" methods flat black on 285's
Edited by Csjumper2003
285 what? The next number is the most important one! lol
285/70/17 or 75/17
I think 75 will have issues
Also looked into 295s but I think there will be an issue until I get my 4.5 lift done
I see a lot running the 275/65/20 with a 2" level. So really 275/60/20 with a 1.5" should work just fine.
I guess I'll know soon enough.
Txjose thanks.
Txjose thanks.
I have a 1.5in level and really wanted a 33x11 tire. I couldn't find a for sure yes answer on here so I went with a 32.6x10.7 on stock 18s. The 33x11 will be close, if you stay on stock rims I think you will be okay though. Def interested in your outcome, pics please
I'm running 275/65R18 Terra Grappler G2s that the dealer put on my truck when I bought it without a level....no issues. Some are running the 275/70r18 and the 285/65R18 without a level, but that would be pushing it.
Edited by bcbz71
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
