Has anyone found a 2.5" lift / level that works properly in the 2017 GMC Denali with the Magneride ? I have called everywhere locally and keep getting mixed answers. I want to be sure before I start messing with it. Thanks for your help in advance !!
Here is my Sierra. 2.25" Readylift leveling kit. 20x10 wheels and 305/55r20 Toyo all terrains.4653782a64447af95191a6ce45c4eb06.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Like 4
Denali with Magneride ?
No Magneride, just an Elevation edition.
thats an all terrain
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Suspension Maxx shows this leveling kit for 2015+ 1500 Denali with Magnaride suspension.
https://www.suspensionmaxx.com/store/product/SMX-GM725M
Yup that's the one I was looking at, but rough country said if I use their Version that uses the top shim too that it may overextend and damage steering linkages ? Do I trust rough country or suspension maxx ?
I have the Rough Country 2.0" level kit on my 2017 Denali with Magneride, installed by the dealer. Zero issues, rides like factory or better. Truck is also perfectly level. No rear blocks.
http://www.roughcountry.com/gmc-leveling-lift-kit-1311.html
http://www.gm-trucks.com/forums/topic/168618-leveling-kit-for-2015-sierra-denali-magnetic-ride/?fromsearch=1
This thread has several members who have used the Suspension Maxx level kits on 15+ Sierra Denalis with no issues. One member used Ebay spacers and fabricated his own Magnaride sensor relocation bracket for less than $30. Good luck with whatever you choose.
Is this specific to 2017 Denalis? I've got the rough country 2.5 lift/level kit, any reason I shouldn't put it on my '17 with magnaride?
I searched this thread for days upon days looking at all the pictures you guys post of your rides and comments about everything before I did anything to my 2014 Z71 and I was wondering if anyone has pictures of an installed 2.5" RC Lift/level kit with and without blocks in the rear to see the difference it shows.
As long as you have the version intended for Magnaride it should be fine. The main difference is that it comes with two little brackets that adjust the magnaride sensors to account for the lift. Very straightforward. You CANNOT use a regular lift/level kit on Magnaride without these, or your truck will drive like a dump truck.
According to rough country there is nothing for 2017 Denali specifically only up to 16 which doesn't make sense to me ? What did they chance that makes such a difference in 17 ? Only difference I have found is that they went from aluminum control arms to stamped steel ?
This is the problem ... only change was the stamped control arms .. now they say you can't use the top spacer & they don't have a kit for the rear .. just 2" level kit for the front ... frustrating to say the least.
    • Glad it worked for you. I tried that 1st, about 2 years ago. Didn't help. I also tried doing a hard reset (disconnecting battery for minimum of 30 minutes). Worked a couple times, but after one summer of doing it over and over, that no longer worked.  I was fairly confident it was either the compressor or a failed actuator, but I just couldn't identify which one. Had to research which actuators do what and which last numbers are associated with each.
    • Took me FIFTEEN MINUTES to find this. Isn't that a problem? On the mainstream media I can INSTANTLY find 100 articles bashing President Trump ... but when it comes to TRUTH in American corporate news & search engines, it's carefully filtered to support ONE SIDE. A Republic cannot survive like this! Incredible! Even all the AI searchers out there failed as well! ChatGPT said it needed more details on the video that I provided a DIRECT LINK to! I thought AI was the be-all, end-all?? I had to dig it up myself. This should be FRONT PAGE NEWS!!! 🤬   Here's the statement directly from our President:     Glenn Beck's reporting on the operation:   https://glennbeck.com/watch/videos/trump-just-revealed-a-massive-military-secret-that-lowered-gas-prices   In case that link doesn't work, here's the YouTube link:     And another 15 minutes to find this clip out of Glenn Beck's video - the first few seconds is all the corporate media will allow the public to see, since the low IQ people will think Trump said " I love inflation ", and that was the end of it. Taken WAY out of context! Here's that part, plus the 2nd part about the oil smuggling operation:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
