Sharp looking rig! What are you running up front? And may just be the angle, but anything in the rear?
Sorry meant to quote you.
2" level in the front +1" block in the rear. 275/65-20 (34") tires.
Rough Country 2.5" and 35x11.50 Nitto Ridge Grapplers
Yup! Made my new setup pretty easy to decide on.
My thoughts as well.
Considering these are bigger than a 285/65/20, and everyone says those rub, I just don't see how it's feasible without some rub.
Well the air dam is removed so that helps, but it looks like he has positive offset, so that hurts. I would say that it does rub somewhere. Probably on the rear inside of the front wheel liner.
Just got my leveling kit in last night!! Cant wait till I install them over the weekend!!
I decided to go with the 2.5" kit
OK, I'll bite. Where do they rub?
it rubs the sway bar at full lock. I cut the inner fender liner so there is no rub there
Edited by THE_Engineer
anybody got picture with a 2in front and rear with stock tire size... im buying the rc 2.5 kit but i think it would look weird with stock tire at 2.5 so im thinking going with the 2in f/r like my old truck was
This is a 2" front w/ factory tires. I don't think another .5" would look that bad. when time for tires just go up to a 33
you got the 2in at the back too??... i wont put tire on for a while since i got ko2 with the truck
No, just the fronts. Thought it would give you some idea of what it would look l like. My wranglers have 23K and about 10K left. cant wait to upgrade tires.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
