What wheel size do you have? I have the same size 2.25" level in front and 3" blocks out back on my 17. I'm running 295/55R20 Nitto Ridge Grapplers on Sierra reps that have the factory offset. Minor rubbing on the plastics at full lock. I could probably zip tie them back and clear them but I'm lazy. f68d498d4c0768ca9ad6430dd085df34.jpg
Sent from my SAMSUNG-SM-G920A using Tapatalk
Have any closer shots? Looking at buying those same rims...
Looks awesome, trying to decide on the tires, hope to make a decision before weekend ends. The YOYOs look great. I think its now between the TOYOs and Terra Grapplers.
These Toyo's ride really good! It was between the Nitto Ridge Grapplers or the Toyo open Country RT for me. I ended up going with the Toyo because I got a WAY better price on them.
Thats one way to decide, haha. How well do you like em?
They ride great and look amazing. I'd definitely buy them again. They come with a 45000 mile warranty too
Here's some17de0f9778861bbc064bd3679ba95013.jpg168c4d7a1fbde4873f0bed75a2a6a2c1.jpgc5fa12df355e7577454dfa9be47bd22d.jpga7b6a250cb2d350ed2e352ccf6252ea0.jpg
Man that is a sharp looking rig. Placed my order last night for those wheels!
Thanks. I'm not a fan of fake rivets and most aftermarket wheels have them now. Plus these weren't expensive so I won't mind if they get messed up by rocks at the lease.
Thats how I feel on wheels too, hard to find one I really like.
So I was just able to confirm that on the stock 20's with the 2" blocks I am getting wheel rub against the upper control arms. Has anyone else had this issue??
Everyone that has 12" wide tires on stock or close to stock offset has UCA and Swaybar rub at full lock whether they know it, or admit it. To check, you have to have someone hold the steering wheel against the left and right stops...the steering wheel won't stay at lock without someone holding it there.
Your center caps. Are those a real molded Chevy symbol or is it just a sticker on the black center cap?
They're real molded Chevy symbols. The place I got the wheels from threw them in with the wheels.
Do the Cognito UCAs provide more or less clearance for wider tires?
I've got stock cast UCAs, but from what I see on here, Cognitos allow the same as stock cast, or maybe interfere a little more than stock cast with inner sidewall rubbing. Seems like the aluminum and stamped steel are a little wider and don't allow as wide a tire as cast.
Yes! 2017 Sierra with 2.5 RC level and 20x9+1 Fuel Mavericks wrapped in 295/55 Nitto Ridge Grapplers. Barely scuffs the wheel well liner at full lock. Several others have run a similar set up with no rubbing [emoji106]
You have any steering issues? I've been seeing something that clicks turning at low speeds?
Edited by STINSAN3
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 653 Guests (See full list)
