King coilover replacements with deaver rear mini pack and removal of the 1” block running 285/70/17 Falkens
Second picture is with 315/70/17 BFG’s same lift, with trimming. It rubs, but I have a Baja kits upper and lower kit coming next week to solve that problem.
Got anymore pictures? Truck looks good and I'm curious what it looks like with the 285/70
These are all 285/70/179537e3339233ae4e343b7026f9650321.jpg
2015 GMC Sierra 2" Rough Country Leveling kit with 20x10 Wheels and 32x11 Toyo Open Country A/T.
What's the metric size on the tires? Toyo doesn't make a 32x11 to my knowledge. Are they 275/60?
When I bought them from custom offsets it was technically 31.9x10.8, I don’t know the metric size off of the top of my head.
Hey guys,
Just picked up a 2018 1500, and looking to level the front a bit, like 1.5" to 2" tops
From what I've read so far, it sounds like with the newer models, you should be replacing the uca, regardless of what leveling kit you go with.
This true even with a slight level like a 1.5"?
I'm keeping the stock 20" wheels and tires - at least for now lol -
Just look at the side of the tire. It has the size on there
31.9x10.8" tire on a 20" wheel is a stock 275/55r20.
On 8/18/2018 at 11:21 AM, LoweredKlass said:
Hey guys,
You'd want to check with the manufacturer of the UCA kit... Most I have looked at require a wheel with more offset, or spacers.
I have stamped steel control arms, and I ended up pulling my 2" MotoFab kit because I got wheel rub on the UCA at lock, and unfortunately there are situations in my daily driving life where I end up hitting wheel lock, I didn't want to destroy the back of my wheels or front edge of my UCA.
I ended up trading in my original 2017 Sierra Elevation for a 17 Sierra SLE Z71, still had stamped control arms. I plan on waiting to do any lifting at all until I acquire a UCA kit and new wheels. YMMV of course, but I don't know if you'll get what you want without a new wheel kit if you go with an aftermarket UCA kit.
On ‎8‎/‎18‎/‎2018 at 8:21 AM, LoweredKlass said:
Hey guys,
If you are certain you only want 1.5 to 2 inches of lift, then you could go with the Bilstein 5100 struts which do not require any UCA change and actually work within the existing front suspension geometry better than any other solution I know of for staying as close to "stock" as possible and minimizing chances of voiding your factory warranties related to the suspension.  Spacers and new UCAs are well know to GM and they are cracking down on them a bit as mentioned in one of their "KB" bulletins (EDIT:  not "KB" bulletins , meant to say "TSB" and "PIT" bulletins).  The 5100 struts on your model truck will give from 1.5 to 2 inches of lift (they advertise "up to 1.85" inches).  I got 1.5 inches with mine set on the highest level (they have different height adjustments).  Others are getting 2 inches of lift but all are getting between 1.5 and 2 inches like you want.  Further, the 5100s solve the problem of driving off-road and taking dips/speedbumps way better than the stock shocks.   If you do the struts in the front, I would also do the rear 5100 shocks, which is what I did, and love them compared to stock.  I did mine at 4WheelParts (total cost about $750 for everything installed and the final wheel alignment.
Edited by TNAZ
If you are certain you only want 1.5 to 2 inches of lift, then you could go with the Bilstein 5100 struts which do not require any UCA change and actually work within the existing front suspension geometry better than any other solution I know of for staying as close to "stock" as possible and minimizing chances of voiding your factory warranties related to the suspension.  Spacers and new UCAs are well know to GM and they are cracking down on them a bit as mentioned in one of their "KB" bulletins.  The 5100 struts on your model truck will give from 1.5 to 2 inches of lift (they advertise "up to 1.85" inches).  I got 1.5 inches with mine set on the highest level (they have different height adjustments).  Others are getting 2 inches of lift but all are getting between 1.5 and 2 inches like you want.  Further, the 5100s solve the problem of driving off-road and taking dips/speedbumps way better than the stock shocks.   If you do the struts in the front, I would also do the rear 5100 shocks, which is what I did, and love them compared to stock.  I did mine at 4WheelParts (total cost about $750 for everything installed and the final wheel alignment.
Do you have a link to the kb bulletin? And are you saying the bilsteins wouldn't fall under the crack down?
Sorry, I meant to say "PIT" and "TSB", not "KB" (KB is for Microsoft Windows issues).  Anyway, it is "PIT5403B" and "TSB 09-00-89-016E".  The PIT has the real specifics.  I am a factory warranty nut and always have been because dealer work is so costly and parts these days are insane.  However, I really wanted to do some "light" modifications to make the truck more usable and better looking.  I think that technically, even the Bilstein strut would void the suspension warranty in the front if a dealer wanted a way out--this includes bigger tires too and rims with non-factory offsets (I put 33" on versus the 31.5 inch stock tires).  It probably depends on the dealer and the issue--I just don't know the enforcement frequency.  I have not been challenged yet but my thought is that I won't be having issues with the front suspension because if the Bilstein sales pitch is true, I won't be stressing suspension parts like ball joints because it works within the same exact stock spring and does not in anyway overextend the stock suspension (does preload the spring though)--this was the only product I was willing to take the calculated risk on and I saved the original struts just in case.  An even safer play would be to get a GM dealer aftermarket department to put these on--especially the dealer you bought the truck from if possible.  If you go back to the same dealer for work I think they would be more lenient and I suspect that is how most guys are doing this to be super safe or maybe it is rarely enforced.  An even safer play is to get the dealer to add the parts during the new truck purchase--that is my plan for future trucks.
Edited by TNAZ
I have a '14 I'm using a rc 2" front level and it sits dead nuts level at 38 1/2" front and rear. I'm looking to do the zone add a leaf in the rear to help with sag and give me some rake back. Anyone running this set up give some insight to how much higher the rear will sit and maybe post a few photos?? Thanks in advance pic is my leveled truck with about 1800lbs in the bed. ac45bdb3c0f8ba3e9c7ec48890841be9.jpg
Sent from my SM-J727V using Tapatalk
2018 Denali with magneride. Readylift Tubular upper control arm swap and 2.25 strut spacer Leveling. Stock rear and stock 22 wheels. Love the new stance. I still have a slight rake which is perfect for the occasional tow or heavy load.
The tubular upper control arms have a thicker profile than the stock stamped UCAs. As a result I did not need relocation brackets for the magnaride sensors.
The stiffness and ride are unchanged.c354a67ae221d0e06e9c7f398b56b30c.jpg8cf39f4bf2c3c4037c93e7331015199e.jpgfa0ecf95f152c91a818605a9b845a4a4.jpgfd100e0d2155ae641b592dc2a693c29e.jpg
Sent from my SM-T813 using Tapatalk
I had an add a leaf from a different company that was very good. It raised the rear 1 1/4”.
FYI, the front had a TGC 2.5” level in this pic. I eventually went to a 2” level and 1” rear block because I didn’t like the loss of factory ride and decreased range level of travel in the front at 2.5”. The increased clearance I ended up with is exactly what I wanted and I’m happy with the setup with the bigger LTZ stock wheels and tires.
Edited by Shredder15
Cropped pic
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   2 Members, 0 Anonymous, 500 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
