I have a 2in front leveler. Everything seems fine except on low speeds parking lot type areas I notice a banging sound and or heavier than normal vibration then the parking lot or road should give.
I put some spacers on the truck while the wheels were removed I noticed the upper control arm resting on what appears to be a stop of some sort. Having looked at some new vehicles over the weekend I notice there looks like there's about an inch space between these upper control arms and the stop. Here is a picture of what I have. The dealer installed these when the truck was new. Were they installed wrong? Should they be sitting on the stop?
Thanks for any advice or comments, I may be putting on a regular 3 inch lift anyway but I don't want to run into any more problems with a rough ride or a heavy banging rattle noise from the front end.
The first picture is a three-quarter ton at the Dealer's unmodified
The second picture is my driver side, there is really no gap between the underside of that upper arm and the stop.5570f53f30153858f5f6561e7c15637e.jpgefb3a5eaf8e572835e0767ea881f6b5b.jpg
Did u get wheel alignment after level put in?  Verify that with ur dealer cause that can cause vibration.
Level kit will reduce clearance between UCA and bump stop which means limited down travel so if u hit a speed bump bit too fast it could clunk and hit the stop.  I think my bump stop has a rubber piece un it but I dont see one in urs
On 8/27/2018 at 7:37 PM, mrskiff said:
Debaged and tinted. Could be a bit cleaner but wanted to snap some pics. 2.25" level.50e078a4c8e6c2aee21deb414d539f3e.jpgf1f35f78a668cc3db2528e2e7430f96c.jpg0de4a89495295a738e4d700b9717105e.jpg52f81c5e8f03665b91904df23e9eb464.jpg
Sent from my SM-G950W using Tapatalk
Looks great!  Looks like mine that I just had debagded and chrome deleted.
looks great!  If you wanted to completely debadge, you might consider getting some either blue or black vinyl and covering the Z in the grill...maybe even the 71 too...I color matched mine in black and personally really like it...not a tough job at all.
I have a 2014 Sierra z71 single cab short bed. Any recommendations on a leveling kit and some tires that will clear on stock 18s? And also would I have to change out any parts while I'm doing the leveling kit to avoid future problems. The truck is currently all stock . Any help? Please and thank you
I have a RC 2" front level, stock rear...I also put BFG KO2 285/65 on my stock 18" rims and for me, it is all I need and the look I wanted...no rubbing.  you can scroll though this thread though and find dozens and dozens of opinions.
Didn't care for the nose-high appearance of the truck with the 2" level so I installed the 2 inch rear block to give it a bit of rake again.  Subtle difference but just enough to fix the problem. Before and after:
80-_img_2218_e5853e5f6a94e36608f0f7f4897
80-_rearblock_624115fe5289acb3707d038cd4
What type of wheel spacers did you get? The good ones have the hub centric ring either milled or attached so you don’t get the clunking sound especially at sudden impact. Dangerous without hub rings too.
Bilstein leveling shocks up front for more budget oriented or my preferred billet aluminum front 2.25” top and lower strut mounts plus a 1” in rear. I prefer the aluminum billet spacers from 4wheelparts and then later buy Bilstein front and rear 5100’s. Reason I don’t like the leveling shock is cause you’re screwed if it goes out on you with larger tires but you’d be fine if the shock went out on you with installed billet aluminum spacers, just get new shocks. You’ve got the 14 model which doesn’t have the cursed new stamped steel UCA’s (upper control arms) that cause your tires to rub them.
Before. Already leveled with 2.25” pro comp.
After getting 285/65R18 on stock wheels and NFAB side steps for the wife.
Pretty happy with how she came out.
I’ve got same level, added a 1” billet aluminum spacer in rear and made a big difference, may help with your mpg’s too
What size tire you running and wheel
2" still has a slight rake...
It does BUT the top of the hood line is higher than the top of the bed line and it creates the illusion that the truck is nose high.  Especially when the truck is on even a very slight incline.
What brandc2" block did u go with?
No vibrations?
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
