14 hours ago, acinquegrana said:
Pinion angles don't "seat themselves".
You beat me to it, I was going to say the same thing.  How does a pinion angle seat itself?  :shakehead:
Well I finally got to a point in my schedule to take a picture of the rear blocks but I can’t get it to upload. No matter, they were used two inch blocks that were not tapered at all. I took them out and reinstalled the stock blocks for now. I have ordered the two inch blocks from RC and will install them as soon as I can. The vibration seems to be gone I believe. I haven’t really driven the truck much since I just did the swap today. I will post again later in the week to update. Thanks for all the helpful comments.
On 1/24/2019 at 11:16 AM, SSMUFF said:
Nice truck (twin).  You say you did the 2" up front only but in your signature you mention the 2.5.  Did you do the full RC 2.5 kit or did you do just the less expensive option and lift the front only?
just the front only
Reporting back that after shocks settled I have a slight rub with 295/70r17 Toyo rt’s and method 17x8.5 with a 0 offset. Shocks were set for 2.5” of lift. The rub is very minor and only at full lock in either direction. The rub is only on the felt liner and could easily be fixed with zip ties.
No. Coil overs are adjustable in place. The quicklift is just an extended strut. And IMO they ride like shit.
Ahh ok I gotcha but is it a better ride than spacers?
There’s nothing better riding than coilovers
Sent from above
I found the quicklifts to be about the same as the spacers when I did the swap in my 2012. On my 2014 I went to bilstein and found the ride to be better. On the 2014 I did the bilstein 5100's set at 1.85" with a 1/4" spacer, and I found the ride to be pretty much the same as stock.
Sent from above
Not doubting that but the CST coilovers cost 1200$ thats a little much
I know you’re not. You get what you pay for. You can get a set of Fox 2.0 setting to 2” max, approximately $900. Pop out your whole stock setup, put them in storage and enjoy your new Fox Coilovers. Bilstein adjustable front struts are the cheapest route but not as smooth as coilovers.
If you’re in a hurry and don’t want to save up then the Bilsteins is your comfortable cheapest route or save a few extra hundred and have the coilovers.
Sent from above
For those that are tracking my vibration situation. The vibration didn’t go away after removing the rear blocks and restoring the rear to stock. I plan on removing the 2.5 inch kit from the front now to see if it returns to normal. If that doesn’t work then I will take it to the dealership that I bought the truck and hope whatever is wrong will be covered by warranty. My truck doesn’t even have 5 thousand miles yet. I am now sorry that I ever messed with it. Just wanted it to set level and be able to fit a little larger tire.
did you get a front end alignment when  you lifted it?
On 1/31/2019 at 10:57 PM, Slick66 said:
Yes I had the same shop that did the install do the alignment.
When the shop did your leveling kit, did you have a 1" diff drop added as well? If not, the CV's are probably causing the vib. Simple install, takes about an 1.5hr my yourself and that well get you back close to factory angles while still maintaining the leveling kit. The diff drop spacer kits run about $40.  Just my 2 cents.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
    • There was a recall on the tailgate in general for opening on its own. Mine has a cap on it and it won’t let the tailgate open.   My tailgate has two holes in the top of the tailgate. I filled them in with silicone sealant.
