23 hours ago, rhill1 said:
Have read a good bit of this thread but its massive. Seeing if i can get some advice. Have a 2017 Sierra SLT with a 2.25" level kit in the front only. Am looking at getting BFG KO2s put on next week. Keep goin back and forth between 275/60/20 and 275/65/20. I keep reading different tires will fit and won't fit. Also the stamped upper control arm issue. The shop that put the leveling kit said they will just put a steering top on when i get the tires. Is that a decent fix or solution to the rubbing issue? What size tires would y'all that have done it recommend? From what i can gather the 17s won't clear as big a tire as the 14 and 15s. Also any advice between ko2 and toyo at2? Any help would be great
You won't be rubbing your control arm with either the 275/60 or the 275/65, they are the same width as the stock 275/55's, just taller. With the 275/65 you may rub the back of the fender, it's considerably taller then stock at 34", which might be too tall for a 2.25" level. There are plenty of people running 275/60r20s on a stock truck with no rubbing. Rubbing becomes a problem on stock offset wheels when you go wider. I've seen plenty of people, including myself, run 285's on a leveled truck with out rubbing, but once you start getting into 295's and wider, it's likely to rub.
My 2015 Silverado had the RHA bilsteins on the highest notch and barely, I mean barely rubbed with 33x12.5x20 Toyo at 2s. Got this 2016 2500hd and put a cognito level kit on it with bilsteins all around and 295/60/20 (33.9x11.6) and don't rub at all. Some one told me the 2500s wheel well is slightly bigger than the 1500s, but I dunno if it's correct or not, look into it, you could possibly fit a 34. Also, the toyos ride smoothe, are pretty quiet, and still look aggressive. Buddy of mine got 75k out of themafd355f71244765089c39645d3030b39.jpg
Unfortunately this just isn’t correct. I know it should be, because on paper they aren’t wider, but since they are taller, a different part of the sidewall is contacting the UCA’s. I’m guessing you don’t have the stamped steel control arms. I made the mistake of believing what I read on this site, and on my 18, with stamped steel arms, I rub on factory wheels with 275/60r20. I’d love it if I didn’t, but I do.
BINGO! You’re correct sir, same thing happened to me then you’ll need new wheels too. Mine was 2.25” level with new +1 offset 20x9 wheels which then allowed me to have 285/60/20 with slight rub on the inner wheel well liner.
Sent from above
Sent from above
Are all these problems y'all were having stemming from the stamped arms? What is the difference between what was on the 14-15s and the stamped steel ones besides the material? I could Google, but thats no fun. My 1500 was a 15 and had no problems with the 33x12.5x20 toyos, do the stamped steel make that much of a difference?
Angles are different and yes, major difference which them requires new wheel
Sent from above
Angles are different and yes, major difference which then requires new wheel
Sent from above
So how would you correct it, get the 14-15 style arms? Or just a lift and some spacers?
I have 285/65r18. They are 32.5x11.5 No rub. I’ve read that having 20s are different and that you’ll rub with an 11 wide. Some fix it with new control arms.
If you’re going to get a lift then it’ll just work but I’d just get new aftermarket UCA’s and be done with it. Multiple good quality aftermarket uca’s out there, everyone knows my favorite is CST. I hated my leveled truck, had new Bilsteins and still ride Rough. I’ve got the CST 4.5” lift which allows you to keep your stock wheels, your choice up to 35” tires, keeping stock width and turning radius which is extremely rare in any lift. This would be my recommendation but cheapest is $1650 just for the lift plus rear shocks $100 each plus install. If you’re doing a level I’d 100% do a coil over leveling kit with new uca’s which cost same as the super high quality CST Lift. If you’re on a budget, 2.25” front leveling blocks and you’ll need new rear shocks if you add another inch to the rear block.
Imho, don’t rush into this, you’ll 100% regret it! Save up, you never go cheap on your suspension.
Sent from above
Do your homework, do the numbers yourself. Getting new uca’s is no 100% not going to rub. You want as much space for tire flexing as possible.
Level $200 plus
Level requires new UCA’s $500 plus
New wheels $1000 plus
New rear shocks if raising rear which you’ll most likely want to do $200
This is the cost of the badass CST 4.5” lift which keeps every thing stock width not needing spacers and stock turning radius
https://www.newlevelmotorsports.com/cskc3191.html
Sent from above
I had 275/60r20s on my 2017 High Country about a month before trading it in. No level, stock wheels, no rub. Don't know what to tell you. But they weren't a problem. And yes the HC had stamped arms.
(Leveling Thread) It happens due to being leveled!
Sent from above
Sent from above
Yep, this is the key. Mine wouldn’t rub stock, but the level makes it rub
You’d be surprised as to how many people actually put out misleading wrong information out there on leveling and tire size especially 15 1/2 - 18’s. In the past, I’ve called out a bunch of BS’ers claiming their tire larger sizes on these model years didn’t rub when leveled even some saying it didn’t rub cause their tires were already on before the level, lmao! And then find them down the road on another thread talking about their rubbing issues.
People: Leveling WILL cause rubbing issues on years 15 1/2 - 18’s GM 1500’s running 20” wheels when adding anything bigger than stock size tires. Another thing, leveling will cause your truck to ride rougher than stock especially adding E rated tires which is common on larger tires like 285/60/20’s. You’ll also need to buy new offset wheels in order to get the rubbing to stop and buying new uca’s doesn’t guarantee to stop the rubbing which is why I jumped on the “much smoother than leveling” Badass CST 4.5” lift.
When you consider the cost that goes into the leveling parts, wheels, shocks/struts and labor, it’s a no brainer!
You should never “ever” go cheap on your suspension, it’s your vehicles foundation.
Most trucks that are traded in are traded in due to bad riding trucks caused by people that want the look but don’t have a quality suspension, all lifts are not equal, you get what you pay for. If you’re on s budget? Save until you can afford to do it right cause then you’ll actually not only enjoy looking at your truck but you’ll love driving it too and not need a throw up bag and Advil for the ride along
Sent from above
Sent from above
That's rich coming from the wealth of miss information I've seen you post before getting it deleted lol
Edited by Daly
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
