My 2018 Sierra has a 2.5 inch level and I’m running 315/70/r17 (metric size of 35/12.5) with very and I mean very little rub on the felt liner on the back side of the wheel well.
Are you on stock wheels? Got any pics?
54 minutes ago, jimbrown1 said:
Where did you read that?
Tire Rack has it in they’re description
I found that on the Ready Lift website as well.  I'm not sure why they would state that, unless it has something to do with shock travel.
On 7/31/2020 at 7:49 AM, Built2crash said:
Just to contribute to the post, my experience with leveling kits:
My 2013 Silverado had a 2" RC Leveling kit in it and I ran 32.5" BFG TKO2, all other components were stock.  I ran that truck for 50K miles before I upgraded. I had zero problems with that setup.
I just recently put an Eibach Pro Level kit in my 2016 GMC Sierra. that kit includes 4 new shocks and spring up front. I'm running that on the 2.5" lift setting. I have stock 18" rims with 285/65/18 BFG TAKO2 on it (32.5" tire). I'm sure I can fit 33" tires on it no problem and I'm pretty sure I could fit 33.5" with no or maybe minor trim. Also, all other components are stock. Will post pictures soon.
My brother in law has a 2018 sierra we put a 2" RC spacer in it with 33.5" BFG TAKO2's, did the nor Cal mod on it and they fit fine. We actually did the Nor Cal mod prior to testing the tires out so I cant say if they would have rubbed without the mod or not, I think they would have rubbed just eyeballing it.
In all these cases the ride quality was basically the same with the level kits installed, My eibach setup is better ride quality.
Conclusion: IMO and as others have said, stay at 3" or less for a level to save your components. Otherwise, spend the money and go 5" or 6" lift kit, this allows you to run a larger tire and saves your components and ride quality.
Hope this helps
Thank you both for the info! Very helpful as I work out what I want to do.
I have a new 19 Sierra dblcab 1500 limited. I plan on installing a 2.25 leveling kit with 3” rear block on it and run 275/65-20 ko2. I had this same setup on my 15 all terrain with zero issues for over a 100k. Now readylift’s kit includes upper control arms. They say on their website that I should replace the stamped steel ones with theirs. Anybody know why? Never changed them on my 15.
Thx
Thx
The older UCAs were compatible the stamped steel UCAs will rub the tires on anything bigger than stock.
Sent from my SM-G973U using Tapatalk
The thing is I won’t be running a wider tire. Stock on there now is a 275/55-20 and I’m just going taller
I think they also correct angles or improve on them as well, the stamped steel UCAs are garbage, another cost cutting measure I'm betting.
Any shame in replacing only the rear shocks for now ? So undecided on a leveling kit, and really hate the red shock boot with an all blue truck....
Not at all. I swapped my Ranchos out for some Bilstein 5100s. Immediately felt more controlled especially going around rough corners. The truck didn’t feel like is was going shimmy off the road.
No shame in replacing the Ranchos.  I did the same thing as Langston1726 except I went with the 5100 struts in front to replace the stock Ranchos and already had a Rugged Off Road bottom strut spacer in place.  Ride is great.  Much better than with the Ranchos.
And the 5100’s won’t jack up the rear, nor any shock shouldn’t have ride height difference?
Nope. They have a range of 0-1” lift I believe
you'll get a lot of recommendations for Bilstiens...i would also recommend you check out Eibach...they are American made and if/when you get to the front their adjustable front shocks go a little higher than bilstiens and will be closer to true level...
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
