I installed Eibach pro-truck lifted springs in the front set at 2.5 inches with an add-a-leaf in the rear on my '15 half-ton. Just put on 295/65r18 Duratracs on stock z71 wheels yesterday and it sits 39.75 inches front and 41.25 inches rear which is perfect for towing a trailer and having the truck sit level instead of rear sag. Here are some photos of the front wheel well at full turn with no rubbing whatsoever. I'll have more photos of the truck soon but I need to wash her first. This is my first ever post and have spent MONTHS researching leveling kits, lift kits, and tire size on these forums so i'd like to say thank you to you all!
have you had the Eibach kit installed long enough to be able to give it a complete review?  I think this kit is under rated and under used....
On 9/4/2020 at 4:50 PM, acinquegrana said:
Anyone run the rancho rs9000 quick lift? I have the readylift 2.25 now but want to upgrade the shocks and figure its better to have less spacers. To make up for the .25 i found a 1/2" spacer that goes ontop of the coils for $19. Steel. I could go with the oem rs9000 struts but for the same price I can just get the coils and not need a spring compressor.
Sent from my SM-G950U using Tapatalk
I've been running Rancho's Quick Lift system on my '14 All Terrain for well over 70k miles.  Simple system, easy install and rides better than stock (If I can even remember what that was like!).  I'm in the process of upgrading tires and inquired with Rancho's techs to find out it was designed to clear 32.8" x 11.5 tires.
I've had the Eibach kit for about 9,000 miles and it's been a good improvement over stock struts and shocks. Originally I had a BDS leveling kit installed but I was having issues with bad tire wear (nothing to do with the leveling kit since they started wearing poorly prior to install) and I narrowed the problem down to either worn struts or just terrible tires, plus I was at 60,000 miles so I figured it wouldn't hurt to replace the front struts and shocks. At first the Eibachs were extremely rough and the front nearly sat level with the rear even with an additional leaf spring, but it quickly settled and the ride became a lot better. Turning is so much nicer with less body roll and it takes large and small bumps well, although the added leaf makes washboard worse. The springs are heavy duty and made my repair shop a little nervous when they tried to compress the springs during install. I have it set at the lowest level (2.5 in) but you have 3 more options, one for a 3.2 in lift and the two highest settings for heavy duty situations like an after market bumper or snow plow. When everything needs replacing again i'm certain I'll go with Eibach. If its time to replace your struts and shocks and you want a level at the same time i would definitely go with the Eibach setup, and they look better than the stock Rancho.
2014 LTZ with stock wheels.  The after pic is with MotoFab 2" level kit,  Bilstein 5100 all the way around and Michelin Defenders 275/60 20 tires added.    I really like how it turned out.
Stopped by Super Trucks here in Lakewood (Denver Area) to discuss a few options for a leveling kit on my 2015 Denali. Options are limited due to MagneRide. They were cool and helped me visualize it by jacking up the front end so the distance from ground to bottom of the wheel well increased exactly 2 inches. Pretty subtle, and still a little nose-down, but I think I'll like the look better than stock -- and hopefully doesn't look too squatted when pulling our vintage Airstream. I looked through almost every post here and never saw a direct comparison before/after image so I figured share this gif I threw together.
Edited by andymcintosh
  • Like 4
2015 LTZ Midnight Edition with Eibach Pro Truck Kit set at 2.5in level with BDS add-a-leaf springs (just go to your local spring shop and have them add another leaf, don't bother buying the short BDS ones like I did) sitting on 295/65r18 Duratracs on stock wheels.
I did the superlift 4" kit which is essentially a leveling kit, but also requires lifting rear to get the level.  it used strut spacers up front , upper control arms, and rear lift blocks.  I went with the bilstien rear shock option.  I am exttremely happy with the performance of the kit.  The truck rides better, more controlled, yet smoother on road.  I was going to do the RC kit originally, but I really wanted to replace the control arms due to the weak stamped steel factory ones that came on my truck.  so the superlift kit offered that option for me.  I went with 33" tires, BF g's at's, ride nice and quiet and smooth, although alittle too quiet.  But the truck handles better than stock.
did you get new/aftermarket control arms or just stick with factory?  i thought the lowest was 2.0"
I stuck with factory. Eibach states the lift is between 1-3" depending on application, but the installation instruction sheet has the lift numbers I mentioned above.
On 7/19/2020 at 1:41 AM, MANDINGO said:
I just got my leveling kit installed and my new nitto ridge grapplers. Im happy with the look
Hi,  what size tires did you go with here?   i have been debating what i can put on those 22's
PS:  nevermind .... found it while scrolling through.   33x12.5    that's what i was looking at as well ..... looks good
Edited by giovannifh
mistake
Part number for the BDS leaf? Your overall setup it quite similar to what I’m looking to get out of my truck. I just got the eibach stage 2.0 coilovers.
Part #111209. You can find it on the BDS website under accessories, but as I said in my previous post I would suggest having a full leaf added instead of the BDS. The leaf is smaller than I thought, only extending a few inches past the overload spring. When adding weight to the truck this setup puts awkward strain in the middle of the two longer leafs so I would suggest adding a full length leaf. If that makes sense. Here's a photo of it added.
how long have you had the eibach kit?  how do you like it?  (also did you stick with Factory arms, or upgrade?)
Answer to all this is up above. Perhaps I should've quoted myself or put it all in one post instead of making it confusing for everyone.
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 746 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
