Here’s my 2018 LT Z71, got it brand new as a close out. Had it for just over a year now, hopefully by the end of this month it won’t be sitting stock anymore.
Hey All,
Newish to chevy, and forum posting, so bare with me, been following this site since I bought my new to me 16 silverado lt back in Jan-Feb of 18. Bought it stock and it's been one helluva truck since. Came from an 06 ram 2500 with the 5.7 and 35s, nice to have a truck that the wife enjoys riding in ?
The ram, was a good truck sorry to see her go. First is a before. Second is an after I lost the ol girl.
Next is the truck the day I bought her, then a slightly accurate lapse till today.
My truck pulls triple duty and hold up to it,
Horse shows 1 weekend, shows the next, and daily in between
Here's my 2019 Silverado 1500 LD. Spent yesterday evening swapping my chrome bumper with no fog lights for this color matched one with fog lights, swapping my chrome grille for this one, swapping the grille emblem for the black one, and putting in those Morimoto headlights. Had the headlight bezels painted earlier in the week with the other stuff. Had the vinyl stripes done awhile back. Really happy with how it turned out.
That looks really good!
Kind of a cross between the 18 and 19 T1 in appearance.
Edited by JimCost2014
Thanks! Wanted it unique, but not too "aftermarket" if that makes sense. Those headlights have the DRL like the newer trucks, too. Like you said kind of a cross between the 18 and new 19. I like how the grille has Chevrolet across it sort of like the newer heavy duty trucks do. I think it all blends well.
Me Too!
Defiantly a unique look in a good way! I think it will catch on with others.
How do those look with the lights on? It is unique I gotta say never seen those headlights
15 hours ago, MrNiceGuy said:
Hey All,
Welcome to the site.
Congratulations on your new truck, glad to hear you are OK.
Dodge did it's job in protecting you.
Got a foam cannon for the new power washer so I figured I would give it a try. Still have to play with the Soap to water ratio, but It worked well. Some after shots of the truck... Boy is it a fine looking rig. Too bad there wasn't any sun, it would look better.
https://youtu.be/DxfwlyeXVMU
Just took this video and not sure how to post, so hopefully it's viewable. If not here's a pic.
I've owned this truck for like a year and a half and this is pretty much the first time I've taken any pictures of it.
It's lowered 1.5 inches  in the front and 3 inches in the rear. Has a dynomax cat-back exhaust.
I also weighed the truck today just because I wanted to know how heavy it really is. So that is with running boards, tonneau cover and 3/4 tank of fuel without me in it.
My pictures are too big, so it'll be multiple posts here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
