Been using my cheap Ebay programmer for 4yrs now. Summer wheels and winter wheels
It works easy if you touch the pointer right on valve stem
Sent from my SM-G965W using Tapatalk
why even bother getting tpms? i havent had them for 2-3 years now it doesnt make the truck do anything different
The light on is annoying
Even when i had TPMS that light came on so often it might as well have just stayed lit. Any night the temp dropped that puppy would be on it the morn. Youll save a lot of te and money by learning to just live with it like just like we all live with the terrible trans tuning
Certainly is possible. Any way you can tell if they are TPMS just by looking at the valve stem? I know it actually sits inside the rim just looking for best case scenario
Wiggle the stem, if there's a sensor you'll feel it hit the wheel. If not the stem will move freely. It can have a sensor stem in it without the actual sensor screwed on it. Chances are the guy that sold them to you had the tire shop pull the sensors off the stems and put them in his new wheels to save a couple hundred dollars.
Some of us get neither TPMS lights NOR terrible trans tuning.  I've NEVER had the light come on; but then, I keep my tires slightly overfilled at 38 psi.  Never had a light even with 40* overnight temp swings.
Illuminated dash lights, like rust, are a crime.
I just got one on amazon and it worked on 2014, 2015, 2017, 2018 GM vehicles.  haven't tried it on a 2019, but I do not think they changed the TPMS systems.
  • 5 months later...
Recently discovered this PIA TPMS thing on my 2018 (and trying the release/add air method didn't work).  My 2014 Grand Cherokee relearned it all by itself, so why can't GM do it?  I mean, really?  Sorry, but I'm not paying for a freakin tool to reset my stupid TPMS every time I rotate tires.  Just one more tidbit to add to the list of things that are starting to annoy me about this truck.
On 11/11/2013 at 9:43 AM, newdude said:
If you are rotating yourself buy the tool. Will work on just about any GM with TPMS. I have the GM one and it works well.
I found the GM tool on amazon, real easy procedure.
Edited by WilliamBos
On 11/10/2013 at 12:25 PM, Steve-O-08 said:
The TPMS sensor matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the
engine off.
3. Press the Remote Keyless Entry (RKE)
transmitter's LOCK and UNLOCK buttons at the
same time for approximately five seconds. The
horn sounds twice to signal the receiver is in
relearn mode and TIRE LEARNING ACTIVE
message displays on the DIC screen.
If your vehicle does not have RKE, press the
Driver Information Center (DIC) vehicle information
button until the PRESS V TO RELEARN TIRE
POSITIONS message displays. The horn sounds
twice to signal the receiver is in relearn mode and
TIRE LEARNING ACTIVE message displays on
the DIC screen.
If your vehicle does not have RKE or DIC buttons,
press the trip odometer reset stem located on the
instrument panel cluster until the PRESS V TO
RELEARN TIRE POSITIONS message displays.
The horn sounds twice to signal the receiver is in
4. Start with the driver side front tire.
5. Remove the valve cap from the valve cap stem.
Activate the TPMS sensor by increasing or
decreasing the tire's air pressure for five seconds,
or until a horn chirp sounds. The horn chirp, which
may take up to 30 seconds to sound, confirms that
the sensor identification code has been matched to
this tire and wheel position.
6. Proceed to the passenger side front tire, and
repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat
8. Proceed to the driver side rear tire, and repeat the
procedure in Step 5. The horn sounds two times to
indicate the sensor identification code has been
matched to the driver side rear tire, and that the
TPMS sensor matching process is no longer
active. The TIRE LEARNING ACTIVE message on
the DIC display screen goes off.
9. Turn the ignition switch to LOCK/OFF.
10. Set all four tires to the recommended air pressure
level as indicated on the Tire and Loading
Information label.
11. Put the valve caps back on the valve stems.
Just had to do this myself.
Does this work for non-GM / non-factory tpms sensors?
I replaced factory wheel/tires with new as well as new TPMS sensors but they're not calibrated
