Had been searching for a hard folding tonneau cover and eventually decided on the Fold-A-Cover G4 Elite, purchased from their factory store. This will cover a couple of the criteria that I was looking for in a cover and why I chose the G4 Elite and my thoughts on the cover after installing it and having it for a grand total of 2 days so far. I will try and post an update in a couple weeks after I get some more time with it.
When searching for a cover I was wanting a hard cover that allowed quick access to the entire bed and I had to be able to pull the cover/panels off anywhere as I often end up with impromptu purchases(dang craigslist) that are large enough to need the entire bed. After initial searching I had narrowed it down to likely either the BAK Fibermax or Roll-X, however after seeing several positive comments here on the Fold-A-Cover I took another look at it as I had intially ruled it out due to not being able to get full bed access as quickly as the BAK line or some others. After reading the manual and seeing that the Fold-A-Cover did come completely off by simply removing (4) easy to access bolts I took a deeper look at this cover.
Main reasons I chose this cover as opposed to some of the other options:
  • Front and rear opening-I like to keep a couple bags with tools/straps/trailer accessories and other truck stuff with me and this way I can keep those bags strapped toward the front of the bed for easy access
  • Mounts on top of side rails-The stuff I find on craigslist generally tends to be large so getting the rails up on top of the bed means more room in the bed and less chance of damage to the rails
This cover was roughly $175 more than the other one I was strongly considering and I'm sure that I would've been happy with it, but I felt that for me the features this cover had over some of the others were worth it to me.
Installation was pretty straight forward, well documented with pictures and instructions that were clear, easy to follow and accurate for my model(2014 Double Cab). I had watched the various installation videos on their website prior to purchase(and again prior to it arriving) so I had a good idea of what to expect. I am not going to review step by step install, just my thoughts on packaging, installation process and initial impressions of the cover, if you want step by step instructions hit their website up.
Cover was shipped in (2) packages, a box with the panels and hardware and a tube with the rails. Packaging was good, panels were well protected from common shipping damage with a heavy cardboard box, foam corners and inflated air pockets. Open up the box and the cover panels come out easily and fully assembled ready to place on the truck once the rails are installed.
Installation was straight forward, hardware worked as expected without any problems. In a couple spots they could probably swap out the hex head bolts for button heads using an allen wrench to give a little cleaner look but the included hardware does the job. I did not install the additional tailgate seal yet, I had enough other things I wanted to get done the night I installed this that I put that one off for later. The lock strikes took a bit of work to get adjusted, the locks have (2) latch points in them and if your latch strike is too deep(far away from teh panel) it can get the first latch point but not have enough downward travel to completely lock, once I realized that completing the lock strike adjustment was straight forward.
First impressions, I'm happy with the cover and they appear to have done a nice job on all aspects of it. The fit/finish is very nice, everything aligns like it should. Materials are cut cleanly, no burrs, ragged cuts, offset screws etc. They put several extra items on the cover that help position it as a "polished" product that was well thought out and executed, even though they're primarily aesthetic and really don't have an impact on function. Example is the weatherstrips they used(shown below) to cover up the cable linkage used to actuate the locks, this has a bit of a functional purpose as it helps limit the ability of someone to "slim jim" the panel lock with a coat hook.
It's not water proof by any means and I'm not expecting it to be, but should definitely keep 95% or more of mother nature out, allow me to store some of the common truck stuff in the bed instead of under a seat and still allow quick conversion to full bed capacity.
Thanks for sharing your review. I am thinking of the Fold-a-Cover for my '14 also. I have seen the different videos too. One thing I can't tell from them is the stake pocket holes. Since the rails mount in the stake pockets, are all the pockets totally covered? I suppose you could opent the back panel and then have access to the hand-hold pocket for using the step in the bumper.
The rear pocket/hand hold is partially available, I took a picture of it and will try and get it uploaded over lunch. I didn't have a problem using it as a hand hold when installing the cover, but haven't tried accessing it with gloves yet....since the truck says -11 right now it should be a good time to try.
Update: Took a picture of the rear pocket showing what is available, let me know if you'd like any more!
Edited by loganb
Just wanted to follow up on this review. I also have installed a G4 Fold-A-Cover on my new 14' and with out a doubt, this is an awesome product. I also installed a Bed Rug and both complement each other very well and make for a very functional bed.
  • 8 months later...
Installed this cover on my truck too, along with the 'personal caddy'. The caddy comes in real handy for my wife when she get's groceries. I've used it for placing items under the cover that you don't want moving around. There's also a expandable metal tray built in that is also very handy to have. Love this cover!
I should install mine this weekend. Dealer said it sits up higher in rear and some do not like that...but they look good and flush to me in all pics I have seen.
If you're referring to the cover itself, it doesn't sit flush with the bed rails as some covers do. It sits about 1/2 inch above the rails.
As an update I love mine. Perfect for going camping with bikes and stuff in the bed where a non fold or tri-fold would not work. And no drain tubes or flapping.
Edited by EXSlider400
I like the center latches it has now too. Keeps the center from lifting in high winds..
I had issues with that on my Colorodo with the old design Fold-a-Cover.
You just have to make sure you lift the back panel cover up and then down to ensure the latch.
I just got this cover installed on a 2015 Silverado(should be same as 2014). How well does this keep out the rain based on your experiences? Did anyone add a tailgate seal, and how much did this help to keep out water?
Thanks in advance.
The cover is not waterproof. The folks at Fold-A-Cover mention that on the website. However, it is very good at keeping 99% of the water out. In heavy rain I'll get small puddles toward the front of the bed. But that's it. I bought the personal caddy, and that, for me, is water tight. I haven't had any water in it at all.
When I ordered my cover from Fold-A-Cover, they provided a tailgate seal kit. I didn't use it at first and I got a lot of dust in the bed over a 200 mile or so trip. I decided to install the seal and it made a huge difference in the amount of dust collected. I get very little if any now. Granted, I don't live in a very dusty climate, but I saw a difference right away. I can't say how effective it is with water as I was never in the rain with the cover on and no tailgate seal. However, with it, I don't seem to get any water in that area.
Hope that helps!
I installed a Fold-A-Cover G4 Elite w/Personal Caddy on my 2014 Sierra about four months ago, and absolutely love it. It leaked a few drops of water after the first rain, but I haven't seen a drop since. Highly recommended.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
