I believe they're Advanced Desert Design. Price is a little salty.
Umm wow. Just saw. They don't sell that style for the Chevy but at 1500 bucks. They can keep em. Wow
Sent from my Nexus 6P using Tapatalk
$1500????? You gotta be shittin me I agree they can keep em
figured I'd be the guinea pig and bought them. Unbelievable -- they are all plastic except for the metal brackets that run from the step to the body. I think the older versions were powder coated steel.
So you don't like them...?
took off my ICI magnum RT boards and installed a set of OEM ones that I had sprayed with Line-x. They encased them completely so it should last forever.
my ICI RTs are for sale now if anybody is interested.
Nice [emoji1303]
looks good . what's the price - Line-x ??
If my truck did not have thrm, I'd get a set of AMP Powerfolds. They are grest for kickjng snow/mud off my boots before getting in.
Looks good, great idea
Installed the Go Rhino RB10's last night!
looks good. any problem with install ? they set tight to rocker panels ?? where the best place to buy them . what's the going price .
Edited by tahoe08
Thanks tahoe08!
For the most part, install was pretty straight forward. The only tricky part was getting the running boards to line up perfectly straight, so that the gaps were the same in the front and the back. A little tweaking with the brackets and bolts did the trick. I would say they sit fairy tight to the rocker panels (between 1/4" to 1/2" gap). They can be adjusted to make the gap even tighter. Here is a close up picture:
I purchased mine a few weeks ago from:
http://www.autoanything.com/nerf-bars/go-rhino-rb10-running-boards
They were listed at $495, but I had a 22% off coupon code that I received via email. Also, I went through Chase Bank's online shopping portal called "Shop Through Chase" to get an additional 4% cash back (chase rewards card is required). After all discounts, my final price ended up being $370.66 shipped to my door. They did get back ordered for a couple weeks so I had to wait longer than originally expected.
Here is a 20% off coupon code if you decide to buy from them: BASIC150 (expires 8/21)
I've only had them on for a couple days so far but I would definitely recommend them.
My only complaint is with the "Go Rhino" logo that is riveted on the side of the right running board. The logo on my right running board is riveted upside down. I need to contact Go Rhino to see what they will do to make it right. Either money back or a replacement board would work for me. Here is a picture showing the upside down logo:
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
