^Do you have to sand it down before paint it?
Plasti dip rims
2014 Silverado 1500 LT V8 4x4 All-Star Edition
Looks great! What step bars are those?
Installed a High Country grille. It went pretty well and it looks sooooo good :D. THANKS Brentadams646!!!! Couldn't have done it without ya!!
Before
In progress...
Finished product!!
If anybody needs/wants the chrome LTZ grille that I took off please PM me.
Not going to happy today... I'll try and have it on Sunday if I've time:(
Painted my Grille
BC7F8A0B-98DB-4B01-BB8E-1EA734BA93E8_zps
55840EE4-4CA9-45FD-9267-720665923ECF_zps
9964DF06-736D-412E-BF47-0AA24F099BF8_zps
2DCDFF5D-F320-4478-A2CF-896398C34548_zps
that looks great - nice job
Thanks and I know a lot will laugh and not understand but Its all actually spray painted with rustoluem Silver metallic which matches great and then a lot of clear on top of it. I know some don't understand why spray paint a truck but over the years I find way more enjoyment out of my rig when I do this myself and plus Im not afraid to paint a vehicle. I completely sprayed bedliner on my xterra and bedlined my headliner and a lot of things. Call me crazy but $30 goes a long way for me :)
Edited by stevencox93
That's one of the cool things here. We can share and realize that everyone is still doing their own thing!
2 side reverse LEDs and 2 top Cargo LEDs. Looks great and an easy install.
where did you get these? Price? got pics of how they look in use? Thinking of doing this but wanted to see first.
thanks
thanks
http://www.ebay.com/itm/291037114965
2014 Silverado was not listed as compatible but they work well.
I took pics during the day and I just looked at them and they don't show the difference, but believe me when I tell you the old ones looked like a dim yellow and the new ones like a bright white.
They weren't really snug fitting in the socket but they seem to stick the the holder well enough.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
