It's sideways, I know. I'm terrible with computers, I have no idea why it keeps doing this. Anyway list of current mods;
2014 Sierra All Terrain 6.2 in Iridium metallic
Rough Country 2.5" level
Zone Offroad 1.5" body lift
Custom exhaust Aero Turbine 3030's with black MBRP tips
20x9 Fuel Krank's
285/55/20 Open Country AT2 Extreme
Smoked Tails and 3rd brake light
Beamers 6000k HID's
Rigid Fog light kit
Color matched wheel well mouldings
color matched mud flaps
AFE momentum intake
2 12" JL Audio Subs
N-Fab cab length ankle breakers
Shaved all badges and emblems
20% tint all around
...I'm running out of ideas
20x9 Fuel Krank's
Beamers 6000k HID's
Rigid Fog light kit
AFE momentum intake
2 12" JL Audio Subs
20% tint all around
Put a blower on that 6.2 lol
Sent while in 'Murica...
If I had an extra 20 g's I could just wipe my a$$ with, I would. Unfortunately that isn't the case lol
Edited by retodd709
20x9 Fuel Krank's
Beamers 6000k HID's
Rigid Fog light kit
AFE momentum intake
2 12" JL Audio Subs
20% tint all around
Running out of ideas? You must not have been around here for long! You'll get some more. A lot more. Don't worry!
Nice I like them much better black.
Sent from the future via a wifi time portal.
Did u do then yourself or have them done? How does it hold up
Plasti Dipped my stock A/T wheels black.
Did u do it yourself or have it done? How does it hold up
I'm not Gatori but I feel like I could answer your question as well, I did mine in August and have only had an issue once and that's because I missed a spot so it started peeling. I haven't had any issues other than that. Mine have held up very well. Just make sure you've got a good 4-5 coats so it's easy to remove if needed.
Just thought I'd give some input on dipped rims!
I did black and I put on about 6 or 7 coats. It seems to hold up. I've had mud on them and rocks hit em in the few days that i've had it. Only time will tell.
Its been long over due of what ive done so far: got my windows and windshield tinted, added a gibson exhaust, added floor lights, added lights to the center console that come one at night, swapped out headlights for projector lights and HID, plastidipped bowties and side emblems, rough country 2.5" lift, swapped stock tires for 275/77R18 exo grapplers, plastidipped rims (need to be redone after getting my tires)
Did u wire in the LEDs ur self? If so how did u get them to come on only at night and do u have an override switch or would it be possible the way u done it? Ur light setup up is unique and I like it!!
Yes i wired them myself, I can take some pictures later of the wires i tapped into. It is possible for you to wire a switch in to turn them off. As of right now the red lights dim with the interior dimmer switch, the white lights are only on when the doors open.
Could the white light be wired to dome switch too? So if I turn on dome lights then foot light will come on? Thanks for your help
Yes. Just tap into the dome light switch wire. I'm going to be doing mine soon
Sent while in 'Murica...[/quote
Which is what wire is what I was asking? If anyone knew?
I'm not sure exactly which wire but there is a youtube video on it. I believe it is gray but not 100% sure
    • Hi, New here.  2026 Denali HD.  Just purchased 7/2/26. I am having the same issue.  I just traded in my 2024 AT4, and the truck connected to bluetooth and Android Auto Immediately!  Now, with the new HD, it connects when it wants to, which is usually not at all.  I have to use the usb-c cable to get it to connect.  Bluetooth won't even connect without the AA. Now after saying all that, I'll take a 20 min drive with the phone plugged in.  Stop at a store, restaurant, etc....  Get back in my truck and DO NOT plug the phone in.  The truck then decides at this point, lets connect BT & AA and work perfectly, ie how it should.   I have deleted (forget phone) the phone multiple times.  I guess I'll just get used to plugging it in every time. even though I don't think its good for the phone battery to have it on charge after it hits 100%. I have searched all over.  No one else seemed to be having this issue, until I read this thread today.   thanks for reading.
    • I have an issue with my ignition hanging and I have to tilt the steering wheel to get in the off position. I have used a great key lock spray and it doesn't help resolve the issue. Is this an ignition assembly issue or something else. If anyone has a past experience with this please advise.   Thanks  Heath
    • This is a terrible GM warranty experience, two months waiting for a covered engine swap with no loaner or timeline is not allowed under GM’s courtesy transport policy.Escalate straight past regular support to a GM executive case manager, document every closed service ticket and dealer repair paperwork. File a complaint with NHTSA to force faster action, and ask for daily rental reimbursement while your truck is down. If it’s been out of service over 30 days, your state lemon law may let you pursue a full vehicle buyback.
    • 198°F isn't unusually hot for an 8L90, so I don't think temperature alone caused the issue. Since everything returned to normal after the truck sat for several days, I'd be looking at an intermittent electronic or hydraulic control problem before assuming the transmission itself has failed. The first thing I'd do is scan the Transmission Control Module (TCM), not just the ECM. GM transmissions can store manufacturer-specific or history codes that won't trigger a check engine light. I'd check: TCM history and pending DTCs Commanded vs. actual gear Line pressure Shift solenoid status Torque converter clutch (TCC) slip Transmission fluid temperature If it happens again, try to capture the data before cycling the ignition, since some intermittent faults disappear after a restart. A professional scan tool that supports full GM transmission diagnostics makes this much easier. For example, the Foxwell NT809BT can access the TCM, read manufacturer-specific transmission codes, and display live transmission data that's not available on a basic OBD-II reader: https://www.foxwelldiag.com/products/foxwell-nt809bt Hopefully it's just an intermittent control issue, but I'd definitely pull the TCM data before replacing any parts.
    • Sorry, I accidentally posted in the wrong language. I'll repost it in English.
