I think it was $800 or $850 I have had it in for about 4 months, just got around to posting it. I did install it myself and it sucked. So far i love it. I had katzkin in my last truck which was good and was way easier to install. Basically the roadwire leather is a lot tighter than the katzkin I had in my 2007 sierra and my hands hurt for days after installing it. The right tools would have probably helped!
I would think tighter would be better. They look great.
I have seen some sloppy self interior installs that looked like a kid did it but yours look great if that is any consolation for your fingers :)
tighter but still experienced ..... wait what were we talking about?
Edited by Alpine Truck Life
Thanks the front seats were easy it was the back seat that was hard to stretch due to the large area it covers
Since we're talking about seats here, does anyone else's bottom cushion slide side to side? My leather never has looked straight in the back where it almost meets up with the backrest portion of the seat. You look at the line and it always looked crooked to me
18% tint on all windows and led reverse/cargo lamps yesterday.
Aem drop in air filter today.
Airaid intake tube tomorrow.
I did the AEM today as well. I'm also doing the MIT tube tomorrow. Too funny.
MIT today. No issues. Easy install.
Edited by 3vol
I actually agree with you, I think it would look better. One concern I have/had is how dark it would be in the cab at night. It's pretty dark as it is now.
Sent from my XT1254 using Tapatalk
I did the front windshield of my wife car and truck 50% and my truck 35% and i love mine more... she thinks its dark..
Mobile Phone holder installed today with USB Cable routed into the glove box USB Input.
May I ask what Brand/Model it is. I have been looking for something similar.
Price?
Thanks.
Painted the steering wheel emblem.
looks good. decal or touch-up paint ????
Yesterday - 20% ceramic tint all around and 40% on the windshield.
Wednesday - Weathertech mudflaps.
Need to order those cargo and reverse LEDs next...
Loving it so far!
Edited by 98sonoma
It is actually just paint pins from Walgreens. I used a toothpick to do the black.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
