Looking around the insurance auctions seen this. Ouch. 49b6f154ad8aa26697aff67d0be07bc2.jpg8bea89112ad5fd289090ef7289714540.jpg493a75a6b1920c274d5792dbc640e3f5.jpg
Sent from my SM-N930V using Tapatalk
HOLY CRAP!!!! :nonod::omg::omg:
Somethin tells me whatever hit that thing wasn't your standard corolla LOL
May I ask what Brand/Model it is. I have been looking for something similar.
Price?
Thanks.
Vehicle Specific Mount is from Panavise. Requires bezel removal and will use an existing bolt. $30
The actual phone holder is from ProClipUSA - $79.99 (found a 10% coupon code online - making t $71).
They have a few models to choose from.
ProClipUSA Phone Holder
i would take that brow off and have them do a complete tint on the windows it would look so much better 35 or 50%
the front window i am talking about
So you see the difference between 35% and 50%
My Truck (Chevy) 35% -
My Wife's Car & Truck 50% -
Man those are some deep rear fender wells. I bet you could fit some 44's in there.
for sale slightly used customized Silverado LT. low mileage and no rust. paint is in great shape only a few scratches that should buff right out. lawl. Edited by Alpine Truck Life
Today I removed the lower valance.
Also installed the Airraid MIT
Here is next weekends project
  • Like 6
I got my exhaust done, magnaflow 18" muffler and custom tips. Left the rest of the exhaust factory. And then I also got my light bar put in 0988231461576dd421496e5e6bc25c01.jpg3bfd8243f4f485acfb250da65b6ea4f6.jpgc070bbf75611104a036488e36f0237d4.jpg
  • Like 4
What brand of custom tips are those ? They look nice!!
Edited by mmwest
Thanks!!! They're actually unbranded. I got them on eBay as 2 individual tips and had my shop guy fab everything up to make it like a Corsa inspired dual slant cut tip. a2fa94fbf7b5f6f9c1c744314a027cca.pngff62450917d4a3e8c2a17d11171c9f37.png
  • Like 3
my interior lighting stuff showed up yesterday in the mail!! soooo stoked!!
first thing i did was see if my illuminated cup holder idea would work
right now everything is just taped together for the mock-up and nothing is drilled, but i think it's going to look pretty sweet.
the glow tubing cost me $3.51 (CAD) and the plastic was left over from another project - so that makes me really happy!!! ...inexpensive and looks cool (at least i think it does!)
hopefully i'll have time later today to get everything properly put together
  • Like 3
Let's hear some audio clips!
I'll work on that one!! Fair warning tho, it's pretty quiet. I didn't want a loud in your face system, I just wanted better performance and a deeper tone. We'll see if the audio comes out good!
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
