Good to hear you're outta there. How far did you get? I think you have to drive to like Oklahoma to get out of it completely. This thing is a monster
We stopped in North Mississippi at my boy's house, not too far from Memphis. Oklahoma was our first option. I think we'll still catch some, but as long as it's not the direct cat 4+ we'll be alright.
Sent from my LG-H872 using Tapatalk
Should just be some rain and a bit of wind by there.
I appreciate it man. We're away from it now in North Mississippi staying with some friends. But I have friends on Facebook now scrambling to leave. I even told a few yesterday that I could get them a hotel . Most native Floridians are stubborn with hurricanes as its usually never as bad hyped. I've played outside in a bunch of category 3s. I ain't messing with this one though.
Roger that, I would be down there, but still recovering from a complete shoulder replacement from my last run in Afghanistan.
GM or Aftermarket? How about one of each?! [emoji23]. Performing a side by side drive test comparison.
The one on the driver's side actually looks the best to me although it looks to stick out farther. I'm guessing the one on the passengers side is OEM correct?
Sent from my E6810 using Tapatalk
figured out my issue with the Thinkware F770. The ignition wire was hooked up to a timed circuit, so, that is why it would go back into parked mode.
At least you figured it out. 33a25d9f3b5c4a2c0b8f88d9d0fb5c60.jpg98b61d840b792581e0102be6a8a6c747.jpgd319756e824420889ed59f90e02bbbc7.jpgde45401f34e0ea560381fe18d0611254.jpg
Sent from my Pixel XL using Tapatalk
Driver side is the aftermarket. It is power Fold while the GM on the passenger side is a DPN (Non-power Fold) mirror. I didn't have it extended all the way out. Lol.
I'll have a comparison video uploaded soon.
which aftermarket mirror is that
I really like the 1AAuto mirrors! I've been running them for about three months now with zero complaints or regrets!!
They are a solidly built mirror and up until yesterday, I like them even more when compared with a GM mirror.
I've heard reports of upper glass vibration at highway speeds but the GM mirror did that as well.
Looks good! What is the wheel tire specs ? I tried installing some 2" spacers with my 275/65/20s and stock wheels and it just wasn't happening, did some light trimming but to make it clear I would've had to cut way more off than I wanted to
Thanks [emoji120]. Tires are 285/70R17 bfgoodrich allterrain. The wheels are method race wheels 17x8.5 0mm offset. Don't like talking about all the trimming that had to be done. I get emotional thinking about it. Angle grinder in one hand and the other wiping tears away. Research the NorCal mod if you want to learn more about how much works needs to be done.
Lol yeah I've done that to a few silverados but with the fender trim on the sierras I couldn't quite figure out how to trim it and make it look good enough to where I wouldn't hate myself for doing it ?
Just put on rear wheel well covers and a front deflector, not sure if I like itbda2e1fe3d3d5f0890e1f53a7288377c.jpg
Just got done installing my kicker VSS PowerStage system. It was actually very easy and straight forward to install and setup. Not a bad upgrade and actually gave me plenty of bass for my liking.
Next is upgrading door speakers. Will probably order Kicker KS series since crutchfield.com has buy one get one half off
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
