I’m officially done with the first warranty of my truck. Just turned 36,000 this morning. Also a couple goodies came too. Heated steering wheel, and new leather shifter.
Edited by MHPrior80
Adding pics
  • Like 5
Out with the old and in with the new and improved!!b87359aef8bd0c300507bcb21b152eb2.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
  • Like 7
These finally arrived today, now I need to drop them off to get color match with my truck before I install them... 81b5e9e807d28333e008c5792a2a8d65.jpg
Sent from my SM-N950F using Tapatalk
What brand?
Sent from my SAMSUNG-SM-N920A using Tapatalk
What brand?
Infinity reference, they sound so much clearer. Gonna throw an amp on em soon and I'm sure they'll really shine then.
On 5/21/2018 at 12:39 PM, pgamboa said:
Performed the Front Seat Lateral Movement and/or Click Type Noise Bulletin. Bulletin # PI1366.
[mention=170089]justin101714[/mention] for the bulletin # and advice. Took about 30 minutes and $18. I’m still under warranty but doing it myself versus losing a day leaving it with the dealer was worth it. I can also share pics of the work everyone here emoji4.png
Does that particular Bulletin make you take the seat cushion off?
I bought the same parts for about $6 online, reached under the seat, and snapped them in place.  Added black plastic zip-ties over each end for additional holding power.  The whole thing took me about 5 minutes and I haven't had the movement since ...
The bulletin instructs you to partially remove the seat cushion so that you can remove the white pivot block and add lubricant to the section of the bar where the pivot block sits on
I added a 10 meter / 11 meter radio to my truck. I have been a huge fan of the HR2510 sense I was a teen in the late 80's when I had one. I found one for a good price in great shape on ebay and had to have it. However, there is no simple way to install it so I cut and welded myself some custom mounts to install the radio and antenna. I did my best to make it as clean of an install as I could. The radio is powered by my 2nd battery. Antenna match is spot on and so far the radio works great. I might even get my ham license again. But we will see on that.
I should add that up in the backwoods of Maine (where I live) there is often no cell service. This is the best way to keep in touch with people when you are offroad. Most times it is the only way.
Edited by MrSteam
  • Like 4
Look's good
I received my gears today from ECGS; 4.10s.
Truck goes to shop on June 11th to get moved from 3.42.
Doing the same with the Yukon’s once I get my lift done next weekend. Stoked.
Can’t wait to hear how this went for you.
I assume you did a lift to go with 4.10s?
Yukon 4.10 for me too!
I did have an RC 6” installed with 35x12.50x18.
Changed engine oil and filter. Also changed one gallon of transmission fluid.
    Tbhats2130
    Tbhats2130
  • Who's Online   2 Members, 0 Anonymous, 2,215 Guests (See full list)
