Started sound deadening on the back wall (I'm probably going to spray expanding foam in the cavity at the top)IMG_1794.thumb.JPG.73aba52ac1e840c9cb35487783a0d409.JPGIMG_1798.thumb.JPG.61233a4b4f6eded4d39b01d842049422.JPG
  • Like 4
  • Confused 1
Put running boards on. Tonno cover will be next. Contemplating a few other mods. I would love a heated steering wheel, but I don’t see that anytime in the near future.
Installed Tyger RoLock Low Profile Roll-Up. Took a chance since I couldn't find any reviews besides Amazon. Couldn't pass up 170 dollars. Looks like it's pretty good quality and sits pretty low to the rails.
Edited by Jakenbake18
Got some new pinstripes down both sides getting to a trailhead this weekend for a backpacking trip. We'll see if they buff out. 9b10729a9814f292ce818fa738c4f181.jpg
Careful the cabs have to breathe...No Joke.
Thanks and I already planned for that as seen below!
Started on the 18mm Baltic Birch hardwood plywood platform for the rear wall At the bottom it will be secured to where the center seat belt was and the stud for the tools pouch. I will add some brackets at the top secured with nutserts and I left a 3/4" gap behind with openings in the bottom corners so the vents could breath (I will also be adding 3/4" foam padding in part of the cavity) . The sub enclosure will mount behind the passenger seat and I will mount the jack and tools behind the drivers seat along with a cargo net or some type of storage compartment/tray.
Ordered some new tires Friday, should be here today I'm hoping. Went with the Falken Wildpeak AT3w in a 305/55/20 from what I have now which is a BFG AT KO2 in a 275/55/20.
Few days ago I washed, clayed, sealed and waxed my truck! It needed a good detail. 236ce1da349d2160bd637361a5dab657.heicab4b0cf20ce1527d461487187ae7e3ca.heice32f49166b8d338fae54b82112d1a1fa.jpgce3b35c429224bf5af6748f4440291cf.heic5b38e17efbb6b7d6c7650dde09232b98.jpg
Can't wait to see the wheels and tires on there.[emoji106]
Thanks! & same here man. I’m gonna color match the door handles and mirror caps eventually. Wherever I can find a good deal on em at.
OUCH! Sorry to see that. Hope it buffs out.
On 5/10/2018 at 11:05 PM, pgamboa said:
Still jealous of this cluster!!
New tires installed and they look and feel great. No rubbing yet either but we'll see 3364497d9ebf32f3e17f14f723dc71b9.jpgb43d7eb262c7df8116ef117e0f9eca63.jpg9d0ec8f5cc416aa03135109089e02da1.jpg5771faee92949c082a498621ac7dd337.jpg053d1e80a2009a31e3512fc074d8662b.jpg
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
