I don't know, I guess I'm just old school, but pouring oil into the valve cover directly has never been a problem for me.
Installed ScanSpeak ring radiator tweeters using some adapters I made from 1/4" abs. My Original plan was to install them on axis in pods on the dash or a pillars which my experimenting showed gave the best response  but decided to keep it stealth and just put them in the stock location.
Also took apart the headunit to run the RCA's and remote wire for the amp as well as hook up the bass level controller. I probably should have done it when I originally installed the headunit but it wasn't as bad as it looks.
 Not mine but a guy did this to his truck around the corner from me a little while ago. I came up after it happened but I'm guessing the big dip right behind where he stopped is what caused it as that sucker is much deeper than it appears when you come from the direction he is facing.
Swapped the reverse and cargo light bulbs out with leds.e9f89a77dfdd9c9e00d7f3892777b057.jpg8a2d4a481667e7caeaf0c8988acce256.jpg5628ecc6d5917c72b5cb4cadb0e99e3a.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Like 4
Deadening, closed cell foam and .elamine foaming the truck    prepping it for the audio system
Got some CK161's the other day.  I havent seen these wheels until a few weeks ago and have never seen them in person until I bought them.  Guess they arent popular but I got them for dirt cheap with newish tires and tpms already install.  I also installed the retrofit HID headlights a few weeks back, that I bought off a member here a while back.  Going to pull the dip off the grill back so its back to chrome later this week.
  • Like 4
I've been looking for a set of those since May 2017. But everyone I find want's an arm and a leg for them. I ended up pick up a cheap set of CK159's which I've decided I don't like and I'm going to sell lol... As much as I want CK161's I'm going to stick with 20's I think.
Truck looks good.
Pulled off the A-piller trim and front dash trim to hunt down a rattle between the dash and left A-pillar. I added some foam tape along the bottom of the pillar trim where it fits into a slot in the dash trim.
I also pulled the light sensor out of the dash, opened it, and removed some of the white goo to hopefully keep the headlights from coming on at 4:00 in the afternoon on a sunny day.
I didn’t do anything but Mother Nature decided to add some snow. I know it’s not a big deal for most of y’all but snow down here in southern Arizona isn’t something that happens often.
  • Like 4
I just got these exact same leds in the mail the other day for this same purpose, how do you like them so far?
    black cat
    black cat
  • Who's Online   4 Members, 0 Anonymous, 1,148 Guests (See full list)
