The first 2 are with just the low beams. The third is just the pods. This is also looking thru my windshield that is tinted.
e35416b414a58846698fe25a219aee93.jpge3c8e45811c2b6339a29968150e011ce.jpgbcce55e2a79acca81025ff7236de746b.jpg
You’re the reason why they make the meme about people with leds lol
I love it
I love it
Lol! I normally don't drive with the pods on that was just for the picture. Plus if I was going to blind someone with light I was use the 30" bar in the grille lol
On ‎12‎/‎23‎/‎2018 at 1:10 PM, CajunFries said:
Finally got some good floor mats. They fit amazing. Also got the back one
Good choice, they last forever.
Husky liners are the best! They were the first thing I added to my 18 Sierra Crew Cab this year and no regrets.
Wired up my Rigid pods at the A-pillars. The brackets will be here sometime this week. So right now is just a mock up.
On 12/22/2018 at 5:18 PM, STRMTRPR said:
.. added e-track bracket to tailgate so I have somewhere to strap/tie down to when carrying loads longer than the bed (eg. lumber).. installed a couple threaded inserts and bolted it on.. now I can just pop the straps in when I need a tie down point :thumbs:
Where did you get both the e-track bracket and the strap(s)?
37 minutes ago, Madcow2020 said:
Added a new bow tie.
Look's good - Thank you for your service.
Very cool, where did you get it? I will looking for the better ARMY version though... LOL ?
Did a full interior detail today. Yep it’s winter in Michigan lol944b2656903e14c410bd760de31940c4.jpg
  • Like 3
Added in-channel window visers i got on black friday for $50ish and threw in the frame plugs my fiance got me for christmas
Edited by PotvinSucks
  • Like 3
On 12/24/2018 at 12:06 AM, shadrickjm said:
A very slight rub when I'm reversing and have the wheels cracked all the way to the left
Do you know what offset your wheels are?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
