14 minutes ago, shadrickjm said:
Thanks, they’re the Go Rhino RB20’s
Here’s. Few more angle for you. 9800CFE6-E51D-4BD3-B90E-820F0DC724E5.thumb.jpeg.77bdade5e800fb514abef8e905c28fc7.jpeg
Love em.  Thinking I might replace my OEM off-roads w/with those RB20s.  But the RB20s look like they sit higher on the rocker panel than mine?
I looked at so many running boards before I made my decision on the Go Rhino’s. My first choice was Amp but couldn’t see myself paying $1300+ for running boards. They’re a very solid running board and I like how tight they fit against the cab.
This weekend I cleaned, clayed, polished and then sealed my girl.  Then woke up Monday morning to take her to the shop to get new upper control arms installed and this....
  • Sad 1
Took her back to shop to check alignment as it was pulling to the left still, all good now forgot to take pictures of her washed up ?? Will do in the morning!!!
Took mine to the dealer for the brake booster recall recalibration.
Got an oil change and new wiper blades and a few weeks back finally figured out a noise I had been hearing at certain speeds turned out to be a vibration put a hose clamp on it and so far still good087b9ba93ceb1c83459874a8a6490702.jpg4b9ce6bffede0de81d5cbbcc0c79c990.jpgad2694bce5f6f39477750ee09cb4e126.jpg
What kinda noise was it making mine
is making a loud noise when I start then goes away after it warms up
Not bad for an eBay tonneau cover. Wasn’t bad on price and looks really nice. Needed to replace the old one due to clamps rusted and basically rigged on the truck. Decent upgrade and I’m happy 3c6c3674f76403cf96113f66a6b70394.jpg0e297cca00a6cc5acc154db597652184.jpg
  • Like 4
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
