On 7/21/2020 at 8:09 AM, J.H.2015LT said:
Removed stock exhaust and installed Borla ATAK cat back exhaust.
How did your exhaust fit? Mine fit a little wonky on the hangers, kind of thought about sending it back but it wasn't a major issue. Because of this the tail pipe was sitting too close to the rear quarter panel and melted some of the black corner protection but it has since settled in and now sits at least an inch away from the bottom of the quarter panel. Just curious about your fitment since we are both using their ATAK kit.
Mine fit nicely on the hangers. The driver's side tip hangs lower than the passenger side due to how it is mounted. The only other issue is the passenger side exhaust tip is turned a little so the Borla name isn't straight up and down. No major functional issues just things I noticed. Over all it is a great set up and was easy to install.0e433515f3ede5db18bccfb86c42c919.jpgd4b1f1b75458039aac701e2ed7b1be9b.jpgd76eba317fb98b813ef2498e700110ab.jpg
picked up a K&N intake (the plastic one) for $50 on market place and installed it.
ill be swapping out the filter for the dry one asap but for now it sounds AWESOME.
I have the 6.2 and its silent when cruising but great sound when giving it some go.
bought it purely as a noise maker and dont feel/expect any gains.
  • Like 5
I picked up something new to tow. 2020 Haulmark, 6'x12'
6'6" interior height. 3500 gvw.
My 2014 H&H 6x14 developed some severe rust under the bed liner spray they spray on the frame during manufacturing. One of the hinges on the ramp door cracked and broke free. There was rust everywhere underneath the trailer . Got them (Brinkmans in Delano MN)to take it on trade in. Good riddance ya rusty POS. e30d9c9b2510837f2183c8b6fec69c89.jpg
Sent from my Pixel 3 using Tapatalk
That H&H had 200,000 miles on it and had been through war.
  • Like 4
Hey everyone,
First real post here. Leveled the truck yesterday and had it aligned at work today. Got home and put some new meats on there.
managed to fit a Hostile Sprocket 20x10 -19 offset with a 33"x11" duratrac today.
Minor plastic trimming and some wheel well bashing required and she doesn't rub at full lock anymore. Zip tied the wheel well lining back tight as well.
D05C3094-EC3D-4902-8D72-9B7696D6BC7D.thumb.jpeg.1a414e3e26db0824d4c68563524d2aa2.jpegIMG_1469-1.thumb.jpeg.05f14720a8f2059eea521cb070b56da6.jpeg
Edited by AnotherTruck
  • Like 5
Got a few things done the past couple days, so I'd say 1 thing a day for the last 3 days counts...
-Magnetic Drain plug installed - will post follow up to the effective ness of this when i do my 3K miles oil change.
( Needa 653096 ) - $4.99 on Amazon
-Stubby antenna installed, already noticed lack of HD radio reception more often on typical drive to work. Wouldn't recommend, but ill keep it for now.
-Leather Column shifter installed, end cap near tow/haul button creaks and wiggles a little. Ill try to fix that at some point. GM part number 22857352
-4" tube side steps installed, paid 250$ for em. Will replace with rock sliders later, but this mostly is to save my drivers' leather seat and help my grandparents get into my truck (often).
9ce12dd44218c7b769082eb74ce8397e.jpg79bc6577c6310c0090760f6282b4cefe.jpgcf6cda65cbcff9aff2831a881c51294c.jpg18b647859f796f58a9694184c739e9f1.jpg
  • Like 4
I will have to check out that drain plug. I've been meaning to install one but have been unsure which drain plug to get. I'm coming up on another oil change in like 1,500 miles so this will be the perfect chance to swap it out.
Which stubby antenna did you get? I went with a GoRecon stubby antenna and I have zero issues with reception, but granted I live in a very large metro area between several major cities so that could be why I have good reception. Driving out east though I had zero issues using AM/FM with the GoRecon stubby antenna.
truck looks good!
i took my steps off and have just accepted the fact that ill be buying a replacement seat cover in a couple years lol
Thanks!
I'll post a link to the antenna when I can, and i might just do a 1k mile oil change cause I get free oil from work [emoji16]
Took the steps off removed the Z71 emblems then washed,clayed,buffed then used Chemical guys Hydro Slick ceramic wax. Works pretty well also swapped the Atturos to Nitto Ridge Grapplers.5163e248dfe22f11250d9b18588f2851.jpge03e73f406348da940d68b3e6578730b.jpg183aeecfb902bedcdea6644bfe2a023e.jpg0314b777dd8e629aed9dea733969764f.jpgac3839bb31818811ff07d14bee2a7e3f.jpg5b34813fca61f70d0644b075b8e7e34a.jpg71e56295685eea966affe66ce288ea5e.jpg
  • Like 4
On 7/21/2020 at 5:09 AM, J.H.2015LT said:
Removed stock exhaust and installed Borla ATAK cat back exhaust.20200717_163904.jpg
I see you had a little help from our friend Miller Lite, don't forget to pick up the old exhaust before you mow next time.
it sounds like you are speaking from experience. Did we trash a mower blade or two after leaving "spare hardware" in the yard?
  • Haha 1
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
