This weekend, I put on some new tires and wheels, and replaced the rear brake pads. 61,500 on the odometer.  First set of rear pads.  Fronts got replaced a couple months ago.
The last set of Cooper ST Maxx tires got 60,000 miles. They still had legal tread by a bit , but I am getting ready for the hunting season.  I put the same size (305/60R18), but bought the Mickey Thompson equivalent, Baja ATZ P3.  Cooper owns Mickey Thompson and Dick Cepek.  For many years Cooper made these brands under contract.  Not all that long ago, Cooper bought them out. The tread is slightly different, but retains the same basic size cleats and voids and they were on sale for a couple hundred less than I could get the Coopers.
I replaced the Fuel Anza D557 wheels I had chromed, but had since pitted, with some good factory square window aluminum 18x8.5 take-offs.  Pix later.
Decided to give my exhaust tip a makeover.  I bought an MBRP Installer series exhaust for my 17 Silverado about a month ago.  After a month of use and a weekend driving on the beach in salty water, the tip started rusting and looking like crap.  I know its a cheap exhaust but I expected a little more life out of the components.  Anyways powder coating is one of my many hobbies so I figured why not.  Turned out pretty good and should continue to look good for the life of the exhaust.
Prior to prep
Sandblasted down to bare metal
50_C192_DE-40_C8-41_FC-_A136-_AA3_EAEDB2
Sprayed and into the oven
Final product
42771_BCA-6_C9_F-4411-_B05_F-_CACBAA6216
9105_D3_A3-_EC4_A-449_F-9528-5_EFB598_D5
  • Like 14
Question for those who have cut the lower plastic under the front license plate. What did you use to cut? Tape and a sharp knife?
are you referring to the lower valance that attaches to the bottom of the bumper?
i used tape for a line and then my multi-tool...
had some time over the last few evenings to throw some vinyl over the silver trim pieces in the truck
i still have to do the steering wheel (uugghhh....  those two pieces are such a pain to get off!) but that's it. i think the vinyl ties in really nice with the dash gauges and the interior lights
if anyone is considering doing this, an absolute MUST is rapid tac - it works sooooo well allowing you to move the vinyl around: rapid tac
  • Like 6
That looks awesome
17 hours ago, Waterfowler41 said:
Today I contemplated going a little higher with my leveling kit, bumping up to the 2.5 RC kit with 2” rear blocks....
I did a similar thing. I had added Fox PS 2.0 shocks front and back, which leveled the truck out. But I wanted it a little higher so I added ReadyLift blocks to the back. Started with 2.25" blocks, (because I am chicken), which only gave me 1" lift in the rear (39.5 -> 40.75 ground to fender well). Some of that comes from the wheels/tires (18s with 275/70).
If you don't mind me asking: what does your truck now measure from ground to fender well, and from center hub to fender well? Does "2.5" blocks from RC mean 3.5" blocks, since it swaps out the 1" factory block? Did you like the RC quality? Readylift was good, except one block had some bulge to it which made the u-bolt hard to fit.
I am just worried I am stretching out the rear Fox shocks and loosing some effectiveness. Still new to this though.
Right now I am only running the RC front 2" lower spacer.  I am due for new shocks and was going to add a rear block and upper spacer all at the same time. My understanding is the 2" rear block that comes in the kit would give me a net lift in the rear of 1" and a half inch more in the front with the upper spacer.  Here is the kit I am essentially building  (https://www.roughcountry.com/gm-leveling-lift-kit-1305-10.html).  The upper spacer is part number 1306 and the rear blocks are 6532 from RC if anyone is interested.
Edited by Waterfowler41
What year truck? Mine is a 16 z71and it unbolts. I guess it depends which air dam you are asking about also.
Sent from my SM-N950U using Tapatalk
28 minutes ago, FORGIVEN06 said:
Finally got hood swap done, really glad I did it
That's a good lookin truck!
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
