Clayed and waxed for the first time. I was surprised how much the clay picked up. I didn't expect a 2017 to be this filthy
  • Like 4
what tires are those?... stock 20?.. the grip is sick!....
i'll be looking for tires soon.. but i need them to last more than 50k.. .. my ranch has a ton of flint, and it eats them up pretty good.
attempting the LED behind the grill this weekend.. . hopefully it goes well.. .also mounting the switch in the place of the lighter plug on the console... going to try and keep it looking stock.. .. we'll see how it goes.. i'll post pics once done.
If my eyes serve me well, the picture looks to show 33x12.5x17LT(?)
Brand looks to be Nitto Ridge grappler
Thanks! They look great. I think the seller never updated for 14+ I've seen that with all different parts
What taillights are those?
Silverado emblem - is that the Red line ones ? any photo's on doors ?? be nice if they also did the other letters ( LT / LTZ )
Correct. 33x12.50r17 Ridge Grappler. I've got 6k miles on them and still look brand new
Finally got around to the reverse/cargo lamp diode mod and added some Phillips leds in both.
What lights are down by the hitch?
Installed new 20” wheels.
How's the ride with that tire setup. I got the factory 22", was debating between 20" or 18" for my winter tires.
Sent from my SM-T810 using Tapatalk
installed my new running boards,actually kinda like them only reason I got them is so my wife could get in the truck easier
Installed new overhead console with factory homelink. Woot
  • Like 3
What's the cost on that.
Sent from my SAMSUNG-SM-G935A using Tapatalk
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
