Is there another one on the market other than the Range? Is there a way to switch from AFM delete to normal mode while driving, other than stopping the truck and pulling it out when its not running?
Never mind I had one ordered.
Edited by wmgeorge64
Got my Range AFM module in and test drove this morning.  Did not do the Shudder test at the spot it happened….. But it shifts like a dream.  The Crappy 1-2  2-1 shift is gone.  It was like driving my old 2006 again. Thanks Guys and Gals for the help!!
Just got my latest OnStar diagnostic report and I guess I need to unplug the Range at that time of the month.
I just disabled the monthly reports. If there is a problem I will get a light on dash.
  • 1 month later...
I recently had 2 cylinder's AFM system replaced.  I've noticed in the couple months since that my mileage seems to have gone down a bit.  It seems to go in to 4cyl mode just as often as before, but when it does many times the MPG gauge doesn't move.  Other times it bounces back and forth between 18 and 24 like a clock ticking.  It didn't used to behave like this.  I'm driving the same roads.
Also, (and I believe unrelated) I had the cat coverter y-pipe replaced under warranty a couple weeks ago.  At least one core was rattling.  I first noticed it after the AFM repair, but it might have been doing it before... I'm not sure.
I'm just curious is anyone else noticed anything like that when there's was fixed.
  • 4 weeks later...
Hey All!  New to the forum.  I wanted to thank everyone for the valuable info in this thread.  I started operating my truck in L5  yesterday to avoid the V8-V4-V8 AFM b.s. and am very happy with the performance of the truck being run that way.  Thanks a bunch!
Yeah I spent about 6 hours on this site and immediately ordered a Range AFM disabler for my 2016 Suburban. Thank goodness for places like this.
Hello, new to this forum. Recently purchase a 2016 GMC  35K with the 5.3 engine. Just to give a different point of view from the posts i am reading. My truck shifts so smooth you cant feel unless you are watching the tach. It also changes in and out of 4 cyl mode where you cant feel it. I just took a 100 mile trip and averaged 20 MPG in 15 degree temps. So i am happy with my AFM.
My 2016 GMC Sierra SLT hit 49K this weekend and I took it in and had the transmission fluid and filter changed and it shifts so smoothly that I haven't put the Range back into the OBD. 8 speed btw.
  • 3 weeks later...
So ole Roost checking in here, had a 12 Tahoe that was destroyed by AFM and now have a 14 Silver w a 5.3. I see the range plug in looks like still the way to go ?? I'm not letting that AFM bullshyt mess up this one. I started reading first page till i saw how old it was so skipped to the back, what did i miss, same ole BS i reckin. One thing i noticed while reading this thread, is all the mpg talk, my opinion is F that, you dont buy a full size 4x4 truck w a v8 for gas mileage. You want great mpg get a 6 cyl truck w no balls, you cant have it all your gonna give up something somewhere, you guys over 40 should no this, aint nothin free. So it seems the 14's and newer drop to 4 cyl instead of 6, i think that Tahoe dropped to 6 ? Why IN THE HELL would anybody want a big truck that ran in 4 banger mode, and whats the other 4 doing at that time, smokin a ciggerette, thats bullshyt, and will cause problems sooner or later. Ford comin w a 7 plus litre motor and we're cryin about gas milage and pushing dropping to 4 for milage. There is no gas shortage i repeat there is no gas shortage, who TF cares if it gets 16-18-20 there's plenty of it for sale, i want max hp at all times, dropping down to 4 is gay as hell, give me a big block in a half ton truck, 10mpg, now then. What is wrong with you guys
I bought the Diablo tuner, ran the diablo tune, turned off AFM, turned off DOD, added 20% throttle response.   Runs great, better mileage by 2-3 mpg, sometimes more and it runs great all the time without the cylinder deactivation sounding bad and herky jerky stuff.   Shifts better too btw and left torque management on, tried it off but its better on.
Do you notice any ping when under light load? I installed the 87/89 tune was getting that. I returned to stock and just adjusted the idle up a bit and turned off AFM. I have no ping on stock tune. Curious as to what tune your running and grade/type of gas.
Bob, read that post carefully. 1.) First post 2.) He turned off both AFM and DOD. Really? C'mon man. They are the same thing 3.) He's using he DIC to report some fiction on mileage. It's physically impossible.  4.) Herky Jerky? LOL....not. 5.) Sounding bad. I know I'm half deaf but if the factory exhaust is in play you are hard pressed to hear it under any conditions. 6.) IF and it's a big if, you could HEAR ping then your knock sensors are not working as they should.
Internet is full of this crap. It's a full story below you brother.
Good point. Multitasking as I get older gets harder. Lol. As far as ping I def heard it on mine cruising about 40 to 50 when pressing accelerator slightly going up a hill Tune installed. Same stretch of road stock tune it’s not there. So for me it wasn’t worth it to keep the tune since it wasn’t my objective in the first place. Stock is fine with me.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
