Just note that my tires are 12" wide, so if you use 12.5" wide tires it will stick out a little bit more, also my guess is with -12 offset and 12.5" wide tire you will need to do some trimming on the well liner.
you so helpful... thanks again.
I did not notice you had 12" tires. so that will add another .25 outside when I use a 12.5
Wonder if I can get like a +6 or I could get a +1 and use a .25 inch spacer if I want a little more.
I have never seen a -6 offset wheel, but it depends on the brand name, but I think you will be happy with +1 and 12.5" tire, and if not you can try a spacer later on, cheers.
Hello, new to the forum, here is my set up:
18x9 Fuel Maverick +1 offset.
Goodyear Duratrac 295/65.
Rough Country 2.5" leveling kit with 1" rear block.
No rubbing at all, love it.f7c602a48021d64c795a2988befcace4.jpg73951ca2ae29d26d35ba70cd9fc802a3.jpg
Can you confirm your offset? Nothing trimmed?
And can you by any chance take a pick of the wheels turned fully both ways and show where its closest point is?
I know your not rubbing, but how close is it?
I want the +14 offset with 285/60/20..little taller but little skinnier.
Hi, yes offset is +1, in the front there is like 1" clearance and about 1/2" or less in the back of the well liner.
Front well liner
Back well liner
Depending where you live, farther out can be a nightmare for throwing shit up the side of the truck.
I have a 0 offset and bushwaskers and kick back mudflaps and it seems to be the perfect fit.
Alright everyone, fixing to order some 20x9 fuel mavericks for my silver 2014 with 2.5 RC front only level. Going with a toyo tire. Give my your opinions: 295/55 mt with+14 offset or 305/55 at2 extreme with+20 offset? It's hard to not go with AZGMCZ71's set up on his silver!
What are you guys doing for TPS when you go to aftermarket wheels?
I'm getting my new wheel/tire setup installed tomorrow. I'm having my factory TPMS sensors swapped over to my new setup.
Im sure everyone is moving them, it super easy. You don't even have to dismount the tires.
Shop that is mounting my new tires will move them for free.
You sure you dont have to pull the tires off the rims? Im gona buy new sensors
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
