Well technically speaking it varies per manufacturer. I mean by default spec a 295/55/20 is 32.8"x11.61"x20, Toyo's measurements however for their MT 295/55/20 are 33"x12.2x20. I really just wanted to see the RT in 295/55/20. I don't think ill have enough clearance to run 305/55/20s and honestly 295/55/20s will be pushing it i believe.
I mean we're talking tenths of inches here and there per manufacturer difference to default spec but it is indeed a difference. I had just read that 33x12.5x20 rub with stock offset on the 14s. Also for some reason i picture 33x12.5x20 being a fat looking tire, which i don't really want. Want a balance between the two. Like my friends 285/70/18s, granted it's a 34" tire it being 11.5" width looks perfect.
why not look at 285 size tires then?
Well having looked at a lot of 2" leveling kits I think I'll be able to clear 295/55/20s. Wanting to go 33 in diameter. Should fill up the wheel well quite nice.
i wouldn't be afraid to go 33x12.50x20 if i were you, but those should look great as well.
Guys,
I really like the Michelin LTX/MS2 275/65/20 tires.
BUT I don't want to do the body lift.
I am ok with a front level, but again, I don't want to raise the rear.
So, with just a level what is the biggest tire I can go without having to cut anything.
My goal is to get more rubber between rim and road.
Truck is a 14 Sierra Denali 1500
Thanks,
Guys,
Thanks,
Guys have been running the 275/60/20's with a 2.25-2.5" front level. Some have rubbed a little bit on the fender liner, some haven't. It's about the limit. That tire isn't very wide, but it's over 34" tall, so that's why it rubs. A safe bet would be the 275/60/20. It's the same width, but only 33" tall.
2015 CCSB 4x4 LT
7"-9" Mcgaughys lift
22x12 American force wheels
35x12.50x22 nitto trail grapplers.
Sick truck man[emoji106]
Ok just went through entire thread but looking for clarification. I have a 14 Silverado and putting a 2.5" rc leveling kit with 275/70/18 tires. Found a set of rims that are 18x9 0 offset. Will this setup work?
I'm running 285/65s on 18x9 with 0 offset. You should be fine. Your tires will be slightly taller and skinnier than mine and I still have room for more tire.
Thanks so much!
So I got a set of Hankook AT-M 305/55/R20s today with about 70 percent tread on em for 200 bucks. My question is with a 2 inch rc leveling kit will they fit and not rub? He said that he will give me my money back if they don't fit but I hate to do that really. They measure at 33.2 overall diameter but i dont know if they will hit being a wider tire? Anybody got anything?
I've got a 305/55/20 on a 2.25 inch Pro Comp level and there is no rub...I have pictures under my profile if you want to have a look.
Honestly I think they will rub a bit.
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
