I been running 35 psi on my 305-55-20 falken wildpeak. Is that a good number to stay in? I seen people running 50+. What's the difference if I put 50+?
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Are they P305/55R20's or LT305/55R20's? Typically LT tires would have 40-50 psi, sometimes more when towing or hauling a lot weight. P tires are normally less than 40 psi.
Looks like Falken might only make an LT version in 305/55R20.I'd start at 40 and adjust it from there.
Yes they are LT. Might try putting them at 40 and see what it does.
DROPKICK Edition
Anybody know where you can buy GM rims? I really like the chrome Denali rims and some of the other AT rims.
Besides that, what are some other good sites for other brands?
DROPKICK Edition
I've got the exact same tires in that size on my truck. I usually have the PSI around 35-40 and anything more than that makes the ride super harsh in my opinion. Around town I like them at 35 and when I take a long road trip I'll pump them up to 40.
DROPKICK Edition
You should not run 50 psi on any size tire. 50 is Max psi (Blow up territory). If you are running at 35 psi cold, it will go up 2-3 psi, depending on how long you drive. With added weight you will go up another 2-3 psi. So the max you can put in your tires is 40psi. rule of thumbs for me is 10psi below max recommended.
Depends on whether the tires are P-metric or LT's. His are LT load range E's with a max inflation of 65 psi. You'd be correct if he had P305/55R20's.
You Sir are correct, my bad.
The new skins are on! BF Goodrich All Terrain KO2's. LT275/70/R18 with 2" level kit. Much better.... :)
Edited by fpdsniper
What is the actual size of that tire when mounted on the truck (true height, tread width, and section width)? Would like to see some low angle front and rear pics to see the full width of the tire if you could post them.
I have a 2015 Silverado and looking to put the Nitto G2s 305/55/20 on it. My question has to do with the tire pressure sensors and the vehicle diagnostics with OnStar. If I run around 10 lbs or pressure higher will it make any sort of tire light come in or show an error with OnStar diagnostics?
No you won't have an issue. I am running 42psi in my 35" tires and everything reports as normal.
Not the OP, but here you go:
Well, here's the low angle front, anyway:
Is a BFG KO A/T 285/65r20 to much for stock all terrain rims? Looks to be about 34"x11" so guessing I will have rubbing if stock height? Found a good deal on a set and hoping they will work
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
