Thanks for the input, I might just go with the bigger tire and see how it works out. I have a friend with a 14 Silverado and he has 20x12 -44 offset with 285/55r20 trail grapplers and he just did the plastic mud flap trimming. I would assume I could fit a larger tire on a more narrow rim but I guess we will find out
I don't know if this is the right place to ask! :)
I bought factory 17" wheels like this:
https://lh3.googleusercontent.com/vOT1pLekKHYLlJMfc0vtxnMzzLCVtIFEPanwDGGandr4XkgePmyIlorE_lDrA023i3jnSQCgsVqKEwcjscK6eTAvmM2J2RTcAtvk8Q6JX_JqY0NDxK0biDWYh8tKwmSsd5TP9f1Mn47NJfCRm0C-NNRRFOZ7jYGca9MoiKGFv6DDWkFTXkFRAdB558oe7ZU0rEqts14-lnfeICBoepsrwmIurqM_Upv9jz9I2r02v6nQqdyegH96pIow_VNjyzl_z6jJ1mtr0qj76oveGuO-THGkb9RXzVU7KgGEfF106zLZaTA59ZrMzba7L2qKAKR2JoPL_isUg1zLOI6iOUKUCHJ_Vyqev0lrIS18UYLBzX8qHL_jQlfEWK8mG88S9ee1zlk8Nl5hJGOZP4trQGyViXd0d4MpB5lwhW_ZnweYHe3u4kNXnefeHzDnAU7PdKWyP-4qQL1hqoOZ3IYLEf7bX8EKrPgaMYkdLIju2k4We45H8ayECtxeYJdqQpgbT1SPBbn2Z9M7vOQUVpiYPxEZ8h2Hsogy0j9MMqS78XSDa3EqDPWMVLaZ_sheL3Yr1jAalxUG=w694-h360-no
and I can't decide which tire is the best for this kind of wheels and stock factory lift 2016 silverado! I'm looking for a quiet ride, low noise, good for sand dunes!
here is the list:
1- Yokohama Geolander A/T-S 285/65R17 116H (H = 210km/h) has more aggressive pattern and can reach 210km/h but little bit smaller
2- Toyo Open Country H/T 285/70R17 117T (T= 190km/h) has best tread life and lives very long
3- Firestone A/T 285/70R17 117T has best price with A/T pattern too
any thoughts, opinions?
guys what tire/rim size you reccomend for a 5" lift on a 2014 silverado? front fender measurement is 40" & rear is 41" 1/2
Edited by Suspension
Cooper ATPs 275/60/20 on stock AT Black Rims
Sent from my SAMSUNG-SM-N900A using Tapatalk
Nice rims!
Ryan
Here is mine. 20" Stock High Country rims with 325/60R20 BFG ATs.
  • Like 4
I have posted on here before when I just had the leveling kit installed, not sure if I have posted since I installed RCX 5". Also added .5 Lower strut tgc spacer, total 5.5" of lift. I am running a 20x10 -12 fuel Mav. with Nitto trails. Do you guys think I could run a 295/60 with lift setup?? I am thinking of going to the Toyo AT II's also. Thanks in advance! post-136138-0-64762300-1453912322_thumb.jpeg
Is anyone running hub-centric rings with aftermarket wheels? I'd love to find a set for my Methods.
Mine came with the wheels from BMF, no the tire shop didn't put them on and used the lug nuts that are supposed to align them, I have no vibration but I plan to rotate the wheels and put them on for security.
Finally was able to install my new wheels and tires.
305/55/20 Toyo AT2 Xtreme with XD Bully Matte Gray +18
2.25 inch Readylift level with 2 inch rear blocks. Not one bit of rubbing.
20160127 103747 1
20160127 103736
Edited by buckeye6
What's the set up? Looks really good! Any trimming or rubbing?
The lift is a 6in RCX with the BFGs and stock rims. Never trimmed and no rubbing even with no offset. The The Amp Research running board really give it a clean look.
I have read a lot of people saying that RCX is not a high quality lift but I'm on my third one and my Father is on his third and neither one of us has had any problem.
2.5" Level + 1.5" Body Lift
20x10 ET -24 Moto Metal MO970
33x12.50R20 Federal Couragia M/Ts
No Rubbing / No Trimming
Great setup man! Im wondering about a similar setup if you dont mind giving me your input? Its for a 2014 Silverado LTZ 4x4
2.5" Front & 1.0" Rear lift
20"x9 Fuel Offroad Nutz +1 offset
305/55 32 x12.50 Cooper Discoverer STT Pro
Do you think compromising with the offset between this setup and yours and the 20"x9 instead of the 20"x10 allow me to fit without the 1.5" body lift with little to no trimming?
Ive heard different things and I know its hard to tell until its on the truck, but any input would be appreciated! Thanks!
Gotta a question for you if you dont mind?
I like your setup. Im thinking about something very similar. Do you think there would be any issues with a 2.5" Front & 1.0" Rear lift and putting 305/55/20 +1 offset? How much clearance do you have currently? Does it rub in 4 wheel drive any? Im not against trimming but id prefer not to. Thanks!
Traded my stock rims for 20x10 fuel maverick last night. Only pic I have so far. Sitting on stock tires for now. Going to get some new tires soon.
  • Like 4
    lingyuair
    lingyuair
  • Who's Online   1 Member, 0 Anonymous, 893 Guests (See full list)
