If only y'all had something setup prior to Christmas! I was just up in Rochester, visiting family for the week. I would have definitely been willing to haul them back down to him (it'd be nice if the excess gas from Rochester/Blaine and OKC/Texas was covered though, as I would have done the Rochester/OKC part with/without wheels as I gotta get home somehow) lol
Road trip!
Road trip!
I make the drive 3-4 times a year, my whole family is up there. Good thing I consider driving "therapeutic" haha. My girlfriend hates the drive. Before we got together, the furthest she'd ever gone was southern KS (3 hours) as opposed to the 10.5-11hr drive lol.
My dad used to live down here with me, but he actually recently moved back up to be with his parents/siblings. He and I both enjoy it up there ten-fold compared to down here in OK. It's a night and day difference socially, as well as the scenery.
I'm still not particularly fond of my optional 275/55/20 chrome OEM wheels and have considered OEM 18" wheels in 275/65/18 which would be nearly identical in diameter to the chrome OEM wheels. I have read here that 18" wheels ride better than 20 or 22 inch wheels. Is there any reliability to that statement?
The more tire you have the softer the ride has potential to be. Tires are part of the suspension. Of course if you get low pros or big heavy 10 ply tires your gonna ride a bit stiffer. So yeah it's valid. Has little to do with the wheels, just how much sidewall you got on the tires
If all other factors are equal, the larger rim (less rubber) will equate to a harsher ride.
I've got the OEM 18" with non-LT 275/65r18 Nittos and the ride is the same as stock. I will say that there is plenty of room around this tire, even without a level, so I would recommend 285/65r18 if you want a beefier look.
Now I understand the statement. The 18" 275/65/18 tires put 7" between the rim and the road while the OEM 20" 275/55/20 tires put 6" between the rim and the road. The swap I was considering leaves the speedometer essentially the same without the need for a correction.
I'm looking to upgrade to the Chrome OEM wheels so if you or anyone is interested in doing a swap and maybe a couple bucks, Let me know....
I think it more depends on the tire. I drove a silverado with the 20's that had highway tires and I thought that they rode much better than my 18's with A/T tires. Not saying my 18's ride rough, just thought the H/T tires were smoother. 18's will be cheaper to replace tires on though. Even if I upgrade my wheels, I will most likely stick with 18's for money reasons, and I like more sidewall than I do rim.
Edited by Silver 5.3
Willy, where do you live and mileage?
Silver,
I should have clarified that I have all season tires OEM 20" and would want to remain all season for 18." I realize the AT tires are generaly a little rougher ride..
Silver,
Then, I would have to agree. Even though I don't have the experience, I would have to assume with the bigger sidewall that is presented on the 18 vs 20, that it would be a better ride.
After going through several posts on here and researching quite a bit (tire size, tire weights & tire dimensions, level kits, etc.) here is my setup. I was undecided between 305/55 vs 33x12.5 (bit more height vs bit more width in relation to amount of rubbing). I wanted to go aggressive as possible without losing too much comfort on ride. Mud terrains look great however eventually were not an option considering this is my daily and I never go off road. More then happy with how it looks. Love these tires + rims combo. Interestingly enough I wanted to go 20x9 +1 offset however the place I got my set from said Fuel was on backorder on that size and this rim color until February. I'm glad I went with the 20x10 since it gave me the lip on the rims and looks more aggressive. Pretty good rub initially however I trimmed the plastic piece at bottom back of front fenders along with a little tapping of the metal underneath the felt. Barely rubs at full lock in reverse. Rubs so little that once tires wear down a bit it no longer will. Hope this helps someone out there.
Fuel Maverick D528 20x10 -20 offset
305/55R20 BFG KO2
3" maxtrac level on front / stock on back
*Slight rubbing when reverse at full lock.
CF8A669A-4E65-4F79-BA56-A952DF27FE03_zps
8733058D-DD24-427E-B8B5-91AE1E8CD0B5_zps
3A31CC51-3C20-4C47-8380-37A9DCF8F4C6_zps
A5AD3732-5103-484C-8A46-19F64333FDE6_zps
F75159FA-0C94-4BF3-88D3-C156DB117BAB_zps
Is your truck 2WD? I am wondering because I have a similar setup (20x10 -24 fuel nutz w/ 305/55 mud terrains) and I barely rubbed in reverse before I did any trimming. After I trimmed the plastic and zip tied the fender liners back, no rubbing at all.
Regardless, that combo looks awesome on black. I almost went with the same wheels but a friend of mine got them on her dodge so I picked something else.
Edited by SouthPawCO
I hope to have better pictures soon.
Method NV's 18x9.
BFG KO2's LT285/65 r18 with fresh label on front right tire
Edited by The Gibson
  • Like 7
If you were local, it'd be a done deal. Pretty much what is holding me back is that I don't want to have 2 sets of wheels laying around! Did that way too much with the G8.
That would have been awesome! Maybe if he gets rid of those we can holler at you and get it done!
    • The "source" a woman, that writes the article is not a far right person. She's pretty well known "car person". She writes her own stuff, but yes it is initially posted under the Blaze, because they purchased the right to post it first, before it is posted on her own sites. It doesn't mean the info is any less valid. the article itself is not political It's not meant to discount any current actions in the Iran   Only posted the link because that's what has to be done to be legal to post the article. The Blaze is not a site I use. Lauren Fix's page pointed me there and I have to use a bypass method to look at the article since I'm not about to join the site. I've posted articles over the years from the Lefty sites, seems you didn't have a problem with that.   But you do you, keep looking at everything only through left/right lenses.   The 3 or 4 of you that participate in the some of the comments had ample chance to read everything. Other members that don't care for it, send in comments, because as they will point out, political talk is discouraged. Both "sides" complain
    • Would be cool if someone made something most people would like.   Like a plug in tune that is to the end users desire minus messing with the throttle petal factory settings. Sport, economy and WFOT.
    • I don’t. The source is a far-right fake news site perpetuated by Glenn Beck. Funny how you clean up political posts and then regurgitate garbage from politically tainted sites.
    • Not a distraction. You miss the point of the article. It's not just for today's situation. Another way AI is being used and it may explain some of the prices changes when there is no apparent event to cause a 25 cent jump out of nowhere, only to immediately, the next day, begin to drop by 2 cents and so on. These situations were happening before the Iran thing fired off.   I used to be in the retail gas/service business. Pretty much a $1 increase in WTI would increase my price by maybe .10 cents. Now WTI can go down and retailers can get hit with a .35 cent increase out of nowhere.   I thought it was interesting read, since this is being used on all products we buy now
    • We understand that intermittent AC concerns are inconvenient, @tjonesdfw, especially since they often do not show themselves when we want or need them to. We would like the opportunity to learn more about your experience with your Sierra and explore the best path of assistance moving forward. To begin, please visit: https://s.gmc.com/support-request  and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
